Question about Coffee Makers & Espresso Machines
Gaggia brera - all 4 lights across the top are blinking : that's not in the manual. Cleaned internals, emptied, filled, off, on, --- nothing
5 Suggested Answers
SOURCE: Gaggia brera, coffee beans compartment is full of
I have the same problem. Not a solution, but you can still take the ground beans and brew coffee, using the pre-ground compartment.
Posted on Apr 11, 2011
  • 51 Answers
SOURCE: i have gaggia brera and after brewing a cup the
Try to descale your machine, use descaling tablets or descaling powder.
Posted on Jul 16, 2011
rickead1
  • 1998 Answers
SOURCE: Hi, we have received our Gaggia Brera today and it
Hello, are you turning to the selection knob back to its central position? once you do this the and the unit warms up the triangle should disappear
The icons displayed blink slowly to
show that the machine is warming
up.
When warm-up is complete,
the machine performs a rinse
cycle of the internal circuits.
During this phase, the icons displayed
will blink in sequence.
• When the operations described above
are completed, the icons on the display
will illuminate.
The display will appear as
shown to the side. The displayed
aroma is the factory setting
when the machine is switch on for
the fi rst time, or it is the same as the
aroma that was selected for the last
brewed coff ee.
The machine is then ready to brew
beverages if you have any further questions or the triangle does not go away please message me back for further diagnosis Thank you
Rick
Posted on Nov 05, 2011
hendriks_edw
SOURCE: gaggia brera brew group wont go back in
If you close the machine without the brew unit inside, the gears aren't aligned anymore. I tried to put the machine off and then back on. You can hear the gears turn. After a couple of repeats, I was able to put the brew unit back inside.
Posted on Jun 26, 2012
GAGGIA Brera RI9833/61 - Descaling light still on after descaling
I think that you button doesn't make a good contact. Try to press it with different pressure and on different sides slightly off center to give this a try - it may be just a bad contact that is enough to change the bean setting but not enough to reset the warning indicator through a long press. Let me know how it goes ... they may have changed the button that needs to be pressed as well (does your manual say anything different?)
Mar 05, 2016 | Gaggia Brera Coffee Maker
My Gaggia Brera made really nice foam really fast for a while. Now it stopped foaming at all. Does anybody know how to return the foam?
There is a small hole at the top of the steam wand. It is likely blocked preventing air from entering the wand. Poke out any dried milk with a needle and wash thoroughly.
Mar 18, 2015 | Gaggia Coffee Makers & Espresso Machines
My Gaggia Brera has all four warning lights blinking simultaneously. And won't make any coffee. Ideas?
hi,when you have the warning lights blinking it may you have a faulty micro switches you have one for the brewer one for the door and one for the basket or faulty boiler not heating up
Oct 13, 2014 | Gaggia Brera Coffee Maker
Gaggia brera descale stays on
try to hold the steam/hotwater button for 5-6 seconds.
Aug 15, 2014 | Gaggia Brera Coffee Maker
Gaggia unica red triangle flashing at same time as green cup
Hi there My experience tells me that when a red light flashes on a coffeemaker it is one of three things: It needs water to be able to make more coffee The "bowl" that the compressed coffee goes in ids full and needs emptying It needs cleaning I would start filling the waterholder, Then emptying the compressed coffee holder If neither works, then start the cleaning prosess Best of luck and enjoy your coffee Kolbrun
Sep 18, 2013 | Gaggia Brera Coffee Maker
Giaggia Brera descaling problem
been talking to Gaggia (Philips) and they told me that with the newer Breras, you need to ill the water tank, put the machine into standby, then press the long and short cup buttons together for 6 seconds. This will start an auto descale programme (that they didn't mention in my manual!). A small amount of water will be dispensed through the coffee nozzles, then it will stop and the warning triangle and the prime warning light will come on. Place a large container under the panarello, then turn the knob to the right to dispense water. It will dispense about 50 - 100 mls (cold) water, then stop for about a minute. Just leave it and eventually it will empty the tank. Refill it and start again, but it will stop after a few seconds. Turn the knob back to central position, then it will dispense another small amount of water from the coffee nozzles, then stop with warning lights again. Turn the knob back right to dispense water, if it stops because of empty tank, just refill it. Eventually, the machine will stop and go to standby. Turn the knob back to the centre, refill tank yet again and the machine will start normally WITHOUT that descale warning light. HOORAY !!
Jan 22, 2013 | Coffee Makers & Espresso Machines
Gaggia brera brew group wont go back in
May 13, 2012 | Gaggia Brera Coffee Maker
Brera: coffee grounds inside + internal leak
finer grind setting and non oily beans did the trick for me.......
Apr 17, 2012 | Gaggia Brera Coffee Maker
Hi, we have received our Gaggia Brera today and it won't prime. We followed all the instructions in the manual and the red triagnle keeps blinking. We're quite desperate to make it work... Any...
up.
will illuminate.
brewed coff ee.
Rick
Nov 05, 2011 | Gaggia Brera Coffee Maker
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
