Whirlpool Washer 4213632 Rev. B the washer turn knob broke where do I get a spare part?
  • 14 Answers
SOURCE: dryer will not dry
the half load button must be selected before the drier will work.select half load and then turn the knob to the asterix type symbol.turn on and that will hopefully do it.
Posted on Dec 29, 2007
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
ginko
  • 19396 Answers
SOURCE: Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Posted on Nov 20, 2008
    • 34 Answers
    SOURCE: removing timer knob from whirlpool
    If you look at the back of the timer lined up with the center of the Knob there is a black or gray plastic part pull that out about an inch then the kbob will come off
    Posted on Jan 03, 2009
    • 56 Answers
    SOURCE: we have a Whirlpool washer stylemaster 4213632
    Probably a bad timer. $100 + for part alone.
    Posted on Jun 13, 2009
    The nob on the front broke off
    Knob broken off?
    Sorry, this Washer Forum does not supply service centre numbers, engineers, spares or prices; it is just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
    You will either have to search in telephone directories OR stay on line and search for '(make) washer service' for instance or '(make) washer spares' and hope that you can find someone reasonably local.
    Sorry again ;-0(
    If this has assisted you please consider a 4 thumbs up for the rating.
    Thanks and good luck!
    John C
    Jul 04, 2011 | Kenmore HE2 Plus Front Load Washer
    Washer Knob broke
    You can use the knob to turn the washer to the correct cycle, and then use a pair of long nose pliers to gently pull the center hub out to start the washer. This is of course only a work around. I'll post more if I figure out how to fix this as well.
    Jan 21, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
    The washer control knob came off in my hand..how to reattach?The white sharp things behind the knob..some are broken? Can I glue it? With what kind of glue or are there replacement parts?
    Most likely the knob itself just broke. You would do better to replace the knob than glue it because if you glued it and ever had to replace the timer then you might cause more damage getting the knob back off.
    Nov 19, 2009 | Whirlpool LTE6234D Top Load Stacked...
    Will not drain or go into spin cycle
    Definetly the lid switch has been knocked out of place or has gone bad.
    Aug 26, 2009 | Whirlpool Washing Machines
    Hi. My water level knob is very hard to turn and the water level is not correct when filling the washer. Any thoughts?
    if it has been quite some time since you turned the knob it is possible that it is starting to sieze up, you may have to replace the switch behind the knob
    May 09, 2009 | Whirlpool WTW5560SQ Top Load Washer
    Baffle broke off
    Hi, one of our baffles broke recently and I ordered a replacement kit from http://www.appliancepartspros.com/
    Here is the link that will take you directly to the page:
    http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Baffle-kit--3-pack-item-number-AP3769371.aspx
    Dec 30, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    44 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
