Question about Canon ImageRUNNER 3235 Black and White Copier
COPIER IS SWITCHED ON AND DISPLAY SHUT DOWN
WHAT CAN BE THE PROBLEM? WHEN COPIER IS SWITCHED ON ITS DISPLAYING SHUT DOWN MESSAGE, AT TIMES ITS COMING ON BUT CAN NOT PRINT OUT JUST GIVES A JAM.
  • Oliver Tambamane Jul 17, 2013
    Have i commented in right place?
  • Canon Expert
  • 1,326 Answers
What is the error code displayed????
Posted on Jul 16, 2013
Testimonial: "code error was E 00007-0000 after i replaced the fuser unit that is when it started to display the shut down message, i further check the Hard Disk and the RAM there just okay, can it be up dates or what? honestly, this is my first task i have in my first work after finishing my course i did."
5 Suggested Answers
old marine
  • 2005 Answers
SOURCE: canon MF6530 copier
If your copies are clean when you scan them by opening the top and laying the original on the platen, you need to check the scanner for the ADF (automatic document feeder). It's a narrow strip of glass to the left of the scanning platen glass. Clean it with a soft cloth dampened with clear water. (Look for some type of deposit that aligns with where you see the line on the page.)
Posted on Jun 18, 2008
  • 99 Answers
SOURCE: DF will not pick and feed originals
Change pick up rollers or clean it .When is old then it can not paper feed.
Posted on Dec 09, 2009
  • 1570 Answers
SOURCE: Image Class MF-6590 Cannon copier displays message
Hi
Please try this solution.
Remove the USB cable into the printer and leave the printer on.
Remove all the cartridges.
Close the cartridge door and wait for the INSERT INK MESSAGE to appear.
Disconnect the power cable and from the power source supply.
Move the carriage using your hand from the original position to the other side of the printer and then move it back to original position. Wait for couple of minutes
Reconnect power cord and turn on the printer.
Return all the ink cartridges and close the door. Wait for the calibration process.
Print the test page to check if it working.
Reconnect the USB cable and try to print again.
Post comment if you need more help. Regards
Posted on Apr 05, 2011
kashif_abbac
  • 4 Answers
SOURCE: What's your problem?my canon NP-1215 photo copier gives completely black copy, only the page is completely black , no print coming, page is fully black ?
please check exposer lamp..nd cable.
Posted on Jun 16, 2012
System manager has been shut down and won't start. it keepa going from the vaio screen to the windows xp screen over and over then displaying message system manager has been shut down........HELP PLEASE ...
try starting up in safe mode and if you can you can go into administrative tools and reset your defaults.
right when you start it up press f8 a few times until you get boot options then click safe mode.
Sep 29, 2013 | Sony VAIO Computers & Internet
Coming with message on display maintenace required call for service
What is the error code that is being displayed? Is it displaying "Time for maintenance"? If there is no error code and the copier still works, it means the internal count has got to a factory set meter to have the drum & developer and possibly other part replaced at that time.
Oct 08, 2012 | Sharp AR-310NT Toner
De display geeft aan klep open, maar de klep is dicht voor en achter
I have the same problem
Message: door open - but closed is several times
Cannot use my printer/copier - help
Already switched it off, cleaned the green roller
but got same message: door open
O.Kraaijeveld
May 28, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Kicoh, Aficio, 2018D is not displaying the ink on paper
if there is no message in the display than you may have your drum out a little , laser path blocked or no developer left in the copier. open the front door. the unit to the right is the drum push it towards the rear of the machine. try to make copies. if this does not fix it you need a tech to look at it so you are not just putting in arts spending money you do not need too.
Oct 05, 2009 | Ricoh Aficio 2018 Copier
Canon imageRUNNER C2058 color network printer board-B1 only. Upon power up the display screen indicates "Wait...".
The printer Board B1: you must shut it down by hitting the Options button and then selecting Function >Shut down > Shut down sytem>OK. Then power the machine off with the main switch. If the Customer has not been shutting off the machine properly and you get the please wait message you might try reloading system software first before replacing the hard drive.
Or = remove and reseat the printer board, if that doesn't work then you'll have to reformat the HDD unit and reload system software from a laptop. If the problem remains, the printer board may need to be replaced.
The Color Network Printer Board -B1 has a shut down function. It is for preventing corruption of the HDD. Be sure to turn off the main power switch after performing shutdown.
To properly shut down the Color Network Printer Board -B1:
1. Press the Option key on the control panel if the copier is in copier mode.
2. Make sure that the LCD reads Idle.
3. Select Functions on the LCD.
4. Select Shut Down from the Functions screen.
5. Select Shut Down System from the Shut Down screen.
6. The message 'It is now safe to power off the system' appears on the screen.
7. Power off the main power switch located on the lower right side of the copier.
* Note- After powering off the copier, wait at least five seconds before powering the copier back on.
Jan 25, 2009 | Canon imageRUNNER C2058 Led Printer
Phone won't work
our phones were working fine. now after an eight hour electrical shut down, no dial tone.
Jun 15, 2008 | GE 21028GE3 Cordless Phone
Cant get rid of blinking error message, nothing works
H4-00 is a fuser related service code. you need to get into the simulation programs and run sim 14 to reset the code. Make sure there is no paper jammed in the fuser. (The hot part on the right side inside the door)
Dec 02, 2007 | Sharp AL-1655CS Copier
Canon ImageRUNNER 3235 Black and White Copier Logo
60 people viewed this question
old marine
old marine
