Question about Haier Heating & Cooling
AC-8000-30 Blower Wheel
AC-8000-30
How do I separate the blower wheel housing to replace the blower wheel on a Commercial Cool Portable AC?
Squirrel cage blower, centrifugal, the housing should have removable parts.
The complete side of the housing held on by screws. A round removable flange on the side of the housing held on by screws. A removable flat flange on the output of the housing, held on by screws. The fan motor comes off with the blower wheel. These are different scenarios.
Sometimes the wheel must be removed from the motor shaft before the wheel can be removed from the housing inlet or outlet after removing any flange on the way of the wheel. Handle the blower wheel with care, it is balanced.
Jul 01, 2015 | Haier 8000-BTU Commercial Cool Portable...
How to install blower wheel on Fedders wall unit AC. If the motor is removed from support, will the shaft go back far enough far enough (before the fan contacts the rear of the unit) to insert the blower...
you have to remove motor by bending evaporator or condenser back far enough to allow it. if you have clamp on blower wheel have to bend evaporator out if set screw go through notch on vanes of blower wheel to loosen.
Jul 31, 2014 | Fedders Heating & Cooling
How to change ac blower on a 2001 chevy silverado with the 5.3 liter v8
With Delphi Blower Motor
  1. If equipped, remove the sound insulator panel.
  2. Remove the blower motor insulating cover screws.
  3. Disconnect the electrical connector from the blower motor.
  4. Remove the blower motor insulating cover.
  5. Pull the retaining tab down while turning the blower motor counterclockwise in order to disengage the blower motor from the heater/ventilation module.
  6. Remove the blower motor.
With Visteon Blower Motor
  1. Remove the sound insulator panel.
  2. Disconnect the electrical connector from the blower motor.
  3. Remove the screws from the blower motor.
  4. Remove the blower motor from the HVAC module.
  5. Remove the retainer from the blower motor wheel. Discard the retainer.
  6. Remove the blower motor wheel from the blower motor.
Jul 27, 2014 | 2001 Chevrolet Silverado
AC Heater
It sound like the blower wheel of the blower motor is rubbing the inside of the housing (the smoke). Sounds like the blower wheel rubbing may have burned the inner plastic housing or has come off of the motor shaft inside. Take the blower motor and wheel back out and inspect everything closely I think you will find the problem.
Apr 13, 2014 | 2004 Ford F-250 Super Duty
AC makes a knocking noise when I turn it on.
You have a bad blower motor or blower wheel. It could also have something in blower wheel.
Jun 05, 2013 | Quasar Heating & Cooling
No heater controls no blower or ac fuses good 89 jaguar xj6
My 93 xj6 doesn't blow or anything but I found that if I kick the blower under the string wheel. It comes on. Then it's blowing cold on the dash and hot out the center counsel. Where do I kick to fix that? There are buttons that light up by the steering wheel. That look like the seat heater button. Is there a way to choose to make the thing blow cold in front and hot in back? 989-657-2563
Jun 27, 2012 | 2001 Jaguar S-Type
Need to replace ac blower motor
  • Disconnect the negative battery cable.
  • Disconnect the blower motor lead connector from the wiring harness connector.
  • Remove the blower motor cooling tube from the blower motor.
  • Remove the four retaining screws.
  • Turn the motor and the wheel assembly slightly to the right so that the bottom edge of the mounting plate follows the contour of the wheel well splash panel.
  • Lift up on the blower and remove it from the blower housing.
  • Installation the new blower motor by reversing the removal steps.
  • Connect the negative battery cable.
  • Dec 12, 2010 | 2005 Scion xB
    How do I replace the ac/heater blower moter?
    Hope this helps....please don't forget to rate...thank you:
    Removal & Installation
    1. Before servicing the vehicle, refer to the Precautions section.
    2. Disconnect battery negative cable from battery and properly isolate to prevent accidental reconnection.
    3. Disengage the wire harness connectors from the retainer.
    4. Disconnect the blower motor electrical connector.
    5. Remove the motor cooling hose.
    6. Remove the screws and remove the blower motor.
      NOTE
      Prior to removing a wheel that is to be reused, clean any corrosion from the blower motor shaft to prevent damage to the wheel mounting shaft.
    7. Remove the wheel from the blower motor as follows:
      • Remove the push clip.
      • Remove the wheel from the blower motor.
    Blower motor cooling hose
    Blower motor mounting plate
    To install:
    1. Install or connect the following:
      • Wheel to the blower motor, if removed.
      • Blower motor and securely tighten the screws.
      • Motor cooling hose
      • Blower motor electrical connector
      • Wire harness retainers
    Sep 15, 2010 | 2005 Mercury Grand Marquis
    What is the part number for a blower wheel on a carrier furnace model FC4BNF030
    Measure blower wheel or take it to AC parts house and they will match it for you. Blower wheels are pretty generic.Rusty
    Jun 05, 2009 | Heating & Cooling
    Blower for Heat/AC
    blower motor resistor is in the front (right?) wheel well.
    Oct 12, 2008 | 1987 Subaru Gl 4WD
    Heating & Cooling Logo
    49 people viewed this question
    Top Haier Heating & Cooling Experts
    Tom Chichester
    Matt
    Matt
    Level 1 Expert
    Vincent Schnittert
    Vincent Schnittert
    Level 1 Expert
    Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
