Question about Refrigerators
Panasonic nrbw415vwau.. confirm this is current model, confirm dimensions and is there an air gap required at back
3 Suggested Answers
  • 2692 Answers
SOURCE: Kitchen Faucet Replacement
Option 1 ; Cap off the sprayer.  Option 2 ; Relocate the air gap as high as possible under the sink but then you have no drain under it in case it backflows (it is really a vacuum breaker ,  one way check valve) Option 3: Take back the faucet and get one of those that the spout is also the sprayer.
Posted on Jan 30, 2009
BAMOUT
  • 2478 Answers
SOURCE: Poor current produced at plug lead, air gap correct
Its a business card, like .010
Posted on Aug 10, 2012
Does anyone have the specs for this model, HxWxD
Watts (W) 1300 W
Current (A) 12 A
Volts (V) 120 V
Frequency (Hz) 60 Hz
Tub type TallTub
Plug type 120V-3 prong
Dimensions & Weight
Overall appliance dimensions (HxWxD) (in) 34 1/8 '' x 23 9/16 '' x 22 7/16 ''
Required cutout size (HxWxD) (in) 34 1/8 '' x 24 '' x 24 ''
Product packaging dimensions (HxWxD) (in) 36 13/16'' x 26'' x 28''
Length inlet hose (in) 55''
Gross weight (lbs) 123 lbs
Net weight (lbs) 118 lbs
Of course you don't mention which model you have ??
Mar 18, 2016 | Bosch SHX68P05UC Dishwasher
I have an old 24 single wall Tappan oven from around 1985 that needs to be replaced. There is no model or serial number. Where can I go to figure out the measurements of it?
Built in ovens come in three standard widths, 24, 27 and 30.
Look at the installation guide in the link for a sears for the 24 inch and confirm the width of your opening along with the depth. Make sure the new does not exceed your dimensions..
The problem is usually in the height. There is a lip that extends outside the inside dimensions so the over all width and height need not to extend beyond you cabinet. You can jack up the bottom with spacers to minimize any upper gap.
http://i.sears.com/s/d/pdf/mp-tc/10031951/prod_1502240512
Jan 13, 2016 | Tappan Ovens
How do unclog the drain on my dishwasher model 665.16902400
Unhook the drain hose for the sink connection. Clean out port connection of the sink connection..
leave the hos off until you complete Air-Gap inspecion / cleaning (next)
On most installs there is an Air-Gap on the back of the kitchen sink.
images?q=tbn:and9gcq21cbh2axzfji-fvyvbg8mgnyhpmkowhj1toxxffd2qewqkya7dbgxkvqy
Pull the outer shell cover straight up and off.
NOTE the inner nut and diverter cap installed position. (It only fits one way)
Unscrew the inner plastic nut
Remove diverter cap.
Use a flash light and wire coat hanger to clear any obstructions from the outlet. Place the end you removed from thge cink connection into a bucket and pour water into the hole where the diverter cap was. This will flush the drain portion of the Air-gap and outlet hole to the sink connection.
Next remove the dishwasher drain hose from the air gap connection. Place removed Hose in the bucket and secure it if you can not hold it.
Set diswasher to wash or cancel drain and let the residual water in the dishwasher pump into the bucket. (can make a mess if pump flow is strong.) Keep a rag in your hand. If you now have good flow... reconnect the dishwasher drain hose to the Air-Gap Connection and the Air Gap to sink connection to the sink connecton port. Task complete.
If you still have a problem after doing the above... Remove the drain hose from the dishwasher connection and check the dishwasher outlet port for obstructions. Remove any obstructions.
Ok now... if it is still not draining.. I need to confirm your model number because it is not crossing to any repair or parts data. You posted 665.16902400 is this correct? Let me know if your stil having problems. I think I can work around the model number issue but would prefer to have a good model number if you have to remove the lower wash arm and clean the sump area. (Last)
Thanks for choosing FixYa,
Kelly
Sep 03, 2011 | Dishwashers
I want to try and get the same air-con so I don't have to replace
There are many brands out there, just take a tape measure and visit the local stores.
Good Luck,
Gilshultz
Dec 03, 2009 | Panasonic Heating & Cooling
Is there an air gap required between floor and machine model LXIH. Water is collecting under machine causing floor damage
i would check your vaccum break upper rhight back corner, but no there is no such requirement for this model
Oct 23, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
How to open dell dimension
You did not mention which Dimension model you want to work on. Since there are at least 30 different models, you should obtain the correct manual.
  1. Go to Dell's Support page (link)
  2. Click on "Select Model"
  3. Select "Desktops"
  4. Select "Dimension"
  5. Choose the correct model
  6. Click on "Confirm"
  7. On the following page, look in the right pane under "Product Support" and click on the link for "Manual".
  8. On the next page click on "Get Manual"
  9. Look for a link about "Adding or Replacing Parts" - something that would lead to a description how to open the computer.
  10. Usually you can find a link that says something like "Opening the Computer Cover".
If you don't find what you are looking for - come back and let me know which Dimension model you are looking for.If you have any more questions, just come back here and leave a comment as well - I'm happy to help.
Oct 08, 2009 | Dell Computers & Internet
Took off one morning and ABS light and brake stay on and truck want idel. But brakes work fine and truck runs good. Could this be a vacum line problem? If so where should I look.
Chances are the speed pickup on the differential is either faulty or drity. I had the same thing happen to my 1998 Dodge Ram 2500. In addition to your symptoms, my speedometer stopped working below 25 mph.
this
the part number at Autzone = SU3356 . That is for ABS on rear wheels only. It is a different part number if you have 4 wheel ABS.
this is how to test if it is bad:
TESTING (1997 Models)
Resistance
  1. Raise and safely support the vehicle securely on jackstands.
  2. Ensure the ignition key is in the OFF position.
  3. Disconnect the speed sensor electrical harness.
  4. Measure resistance between the terminals on the speed sensor
  5. Resistance should be 1000-2500 ohms.
  6. If resistance is not within specification, check the harness for continuity.
  7. If continuity exists, the sensor is faulty.
Air Gap
0900c152800c0d89.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Measure and record the distance between the sensor mounting surface of the differential case and the teeth at the top of the exciter ring
0900c152800c0d8a.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Measure and record the distance from the underside of the sensor flange to the end of the sensor pole piece
  2. Remove the sensor from the differential.
  3. Measure and record the distance from the underside of the sensor flange to the end of the sensor pole piece. This distance represents dimension "B". This dimension should be 1.07-1.08 in. (27.18-27.43mm). If dimension is not within specification, replace the speed sensor.
  4. Measure and record the distance between the sensor mounting surface of the differential case and the teeth at the top of the exciter ring. This distance represents dimension "A". This dimension should be 1.085-1.120 in. (27.56-28.45mm). If dimension is not within specification, replace the exciter ring.
  5. Subtract dimension "B" from dimension "A" to determine sensor air gap. The gap should be 0.005-0.050 in. (0.127-1.27mm).
icn_arrow.gifBack to Top
Here is how to replace it:
REMOVAL & INSTALLATION
  1. Raise the vehicle.
  2. Remove the brake line mounting nut, if fitted, and remove the brake line from the sensor stud.
  3. Remove the mounting stud from the sensor and shield.
  4. Remove the sensor and shield from the differential housing.
  5. Disconnect the wire and remove the sensor.
To install:
  1. Connect the harness to the sensor. Be sure the seal is securely in place between the sensor and wiring connector.
  2. Install O-ring on sensor if removed.
  3. Install sensor on differential; housing, sensor shield, mounting stud. Tighten to 18 ft. lbs. (24 Nm).
  4. Install the brake line on the sensor stud and install the nut.
  5. Lower the vehicle.
Aug 27, 2009 | 1999 Dodge Ram
Jan 30, 2009 | Danze D316440RBT Fairmont Two Handle Wall...
Through the wall vs. window installation
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
Apr 09, 2008 | Frigidaire FAC124 wall/Window Air...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
