Question about Cell Phones
How to repaire display ic of samsung c-3510 - Cell Phones
Samsung champ duos c3262 no display forums fix
many reasons are major cause for no display,blank display,scrambled display. In samsing champ duos c3262 no display problem terouble shooting.first connect with charger no charging logo on screen.open your cell phone and clean pcb and lcd connector with corbon tetra cleaner(ctc)dry normal.problem not solve then try seen lcd with lamp if display is shown but no light make light jumper or change lcd.lcd ok and new 100%working condition please be care fully check lcd connector.no display no luck final heat or replace display controller ic.
here is the light ic jumper if your lcd is black and now lights.
click on link for jumper ways by image. Samsung champ duos c3262 no display jumper Phonetolls
Jan 04, 2015 | Samsung Cell Phones
Risoh aficio sp 3510 sf
my printer richo sf 3510 sir. my problem replace required soon print cartridge show on the display
Feb 19, 2013 | Ricoh Office Equipment & Supplies
Samsung 205BW ( Black ), turns on and for a sec it displays on the top left corner a little squere where it usually says Digital/Analog input, after that nothing more on screen, power led remains lit and...
The processor ic is not doing it's job, it controls on/off functions as well display and Samsung logo, input devices and more, if you checked out the power supply, you have covered everything within limits. This item is not cost effective to repair. Judging by your description the processor ic has been totally compromised.
Jan 07, 2011 | Samsung 205BW (Silver, Black) 20.1 inch...
My Samsung HCM4216W is displaying a distorted picture what can cause this? Also, the color is diminishing. It has sort of a dip at the top of the display and the picture is more cyan in color.
Covergence ICs you can replace both of them or whole board Encompass Parts has board 1-800-638-3328 and Mats Electronics has STK ICs
1-800-628-1118 ICs are big black ICs will have part number on them STK392-020
Mar 23, 2010 | Samsung HCM4215W 42" Rear Projection...
Samsung TXN203F displaying only blue and green
Well, it depends, it is one of three possible issues, 1. bad video driver on the crt board, 2. Bad Picture tube 3. Bad video processer.
Most lkely is either 1 or 2 above. If it is no 1. the repair would be reasonable probably around 90-100 dollars. Video processer is not likely but can be the issue.
Oct 10, 2009 | Samsung TXN2034F 20" TV
SAMSUNG sp-p4231 sound, but no picture
try changing the display IC that would be the frequent cause of such problems
Jul 04, 2009 | Televison & Video
HCL 17" monitor display problem
Hi there ,
It seems that you have a vertical section problem ,It might be possible some capacitor might have gone wrong
Jan 24, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor disply movable horizontal lines.
yes you first check the supply at vertical ic 12v if present then replace that vertical ic if supply is not present then check the regulator ic in smps if faulty then replace it
Nov 20, 2008 | SAMTRON 55V 15" CRT Monitor
Samsung synhcmaster 753s monitor
The Menu button might be stuck or broken. I am not sure if there is an easy way to open it and check this button, but if you can do it, check the button.
Aug 06, 2007 | Samsung SyncMaster 753S 17" CRT Monitor
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
