We just got this Whirlpool wed5521sq0 dryer. When hooked up the timer will not work and it will not produce any heat. Can anyone help me......
Does it turn or spin? Also make sure you have 220v hooked up right. I know that sounds very simple but the heater works on 1/2 of the 220 and the motor on the other half. Let me know if you need anything else.
Hmmm, the only other thing that goes wrong is a thermal fuse but that usually doesn't effect the timer and since it's new, I'm not sure. There should be a tech sheet hid in there some where. What is the model number found inside the door?
About all I can think of is a thermal fuse #7 & #15 on the diagram link on the bottom here. Do you have a way to continuity check those?
http://www.searspartsdirect.com/partsdir...
Yes it does spin. The 220 is reading 120 on one leg and 120 on the second leg, I checked that when hooking it up. Also I have noticed that the timer does not work.
The model number is wed5521sq0. I will look for the tech sheet and see what I can find.
