Win 7driverd rabbitt 750 plotter - Office Equipment & Supplies
  • 7,733 Answers
Try this link
Posted on Jul 16, 2013
Trying to connect a lap top to the 450C designjet but don't have the proper connection to hook up
I believe this plotter has both the old centronics and a 25 pin serial connection. Your laptop MAY have a 7 pin serial connection which you can get a 7 pin to 25 pin serial cable. If your laptop does not have a serial port, you MIGHT find a USB to serial adapter cable.
Make sure you are not on Vista or Win 7 operating systems as they likely do NOT have compatible drivers for this plotter.
Jan 13, 2010 | HP DesignJet 450c InkJet Printer
My HP750 plotter just displayed the message, "Switch Power Off; Check Cartridge Path" after the last print job. I see nothing blocking the printer cartridges and can't get the message to clear. Am I...
I've seen this error on the Designjet 750 plotters. Basically the plotter puts out this error if the carriage assembley cannot move along the Y-Axis (back and forth)
The carriage moves along the Y-Axis driven by a motor with a metal gear, pushing and pulling a rubber belt. Over time the interaction between the metal and rubber causes the teeth to wear off the belt and often times the worn rubber gets stuck in the teeth of the motor gear.
So, open the cover, and look behind/below the carriage itself and find the belt which runs the width of the printer. Run your fingers along the tooth side of the belt and check for degraded teeth, aslo examine the metal base below for any debris If you find debris, this is your root cause of the error you are getting.
Unfortunately, changing the belts on these machines is quite a process; on average it takes me 3 hours to replace a belt (and I've done dozens of them) It would be best to find an experienced tech since there can be some difficulties when replacing the belt (specifically proper belt alignment, and the removal of the side covers can be tricky as well.)
If you do not have any debris, and the belt is degraded, it could be that the motor which propels the carriage could be bad or something is obstructing the movement of the carriage head (the ink supply lines, the pen path, or media could be the issue).
Aug 18, 2009 | HP PSC 750 All-In-One InkJet Printer
Incomplete Plot of PDF file
This is a common problem on the 500 range, not so common on the 1050. A quick way around the problem (using the parallel port only) is to load the HP Designjet 750c drivers. Send the drawing to the 750 using memory in computer option and it WILL print.
Jan 12, 2009 | HP DesignJet 1050c plus InkJet Printer
Driver
Taka9}I{e xyema, rge 6JI9gb gocmamb eToT e6y4uu' gpau'Bep!? cykuHax
Sep 09, 2008 | Office Equipment & Supplies
HP 755CM
**you need a good driver:
whilst ordinary printer drivers may treat plotters like very large, slow, desktop printers, our driver uses the native vector graphics capabilities of your large format plotter to render CAD and line drawings at maximum speed.
Go here
www.plotterdriver.it
Third Party Product;
and they are those recommended from HP, Autodesk and work great with Corel Draw, Power Point, Micrografx Designer, EXCELL, Lotus, Word and all vectorial-oriented Windows applications, under W95, W98, WME, NT 4.0, W2000, WinXP, Win VISTA.
You'll find all informations
Aug 08, 2008 | HP DesignJet 750c plus InkJet Printer
Flexisign pro 7.5
write to the flexsign website
your only option, im sure they have something by now
Jun 18, 2008 | Microsoft Windows Vista Ultimate Edition
jasbo
jasbo
