Samsung SyncMaster SA450 Resolution problem. Have
Samsung SyncMaster SA450 Resolution problem. Have a Sa450, which isn't displaying the resolution correctly. Have tried both DVI and VGA, and on multiple computers. Is this a known issue, with any form of firmware update available to resolve the issue? Or do I have to send it in for repairs?
Struggling to connect my Goodmans Freeview+ HD recorder (HDMI output) to either the DVI (female) or VGA (female) input of my Samsung LE27T61B TV which is HD ready with a resolution of 1366 x 768.
They are different protocols. You have to have a converter than changes the protocol (protocol is like a language...it needs to be translated to a different language). They are available from eBay or amazon but they don't always work very well. Best thing to do is get a unit with the correct connections.
Jul 14, 2016 | Samsung Televison & Video
Samsung Syncmaster 305t Not displaying full resolution with Dual Link DVI cable.
2560 x 1600 at 60 Hz support . if may v sync 75Hz need to check the adjust.
Nov 05, 2015 | Samsung Computers & Internet
Samsung sa450 goes out when signal
thanks, It worked for me to.
Samsung sa450 no has no picture white a cable on.
the firmware fix the problem
Jan 18, 2013 | Samsung 24" Sa450
I have a Samsung SuncMaster 940BW 19'' LCD Monitor. It's a geat Monitor in my humble opinion in everything, except that since i got it i have one problem with it, and it wasnt possible for me...
This is a common problem with monitors when changing resolution. What probably happened is you may have tried to change the resolution, or an application changed the resolution, to an incompatible resolution.
For example, if you have a tiny little screen it can't display that huge resolution that a 32 inch monitor has. So, your monitor is stuck in that wrong resolution.
To fix this problem, you need to boot into Safe Mode. Restart your computer, and as it is booting up tap F8 a bunch of times, and then select Boot into Safe Mode.
When it boots up, right click on the desktop, click Properties (Windows XP) or Screen Resolution (Windows 7). When the window pops up, click Settings (if on Windows XP, if on Windows 7 skip to next step). From this window, change the resolution back to the basic 800 x 600 screen resolution.
Now, reboot your computer normally. You should be able to see the desktop. Now, you can do the same thing that you did in safe mode and turn up your resolution. BUT, when you change it, if the screen goes BLANK again, DO NOT press anything. After 15 seconds it should go back, and you can try a lower resolution.
Hope this helps! Thanks for using FixYa.
Aug 27, 2011 | Samsung Syncmaster 940BW LCD Monitor
My samsung syncMaster 753s moniter does not support resolution of xp what i do further
Your monitor can easily support Windows XP resolutions. The problem almost certainly lies in your video settings. You need to lower your screen resolution and/or refresh rate.
If you can not start Windows due to this problem, you will have to start Windows in VGA compatibility mode. Follow these steps:
  1. When your PC starts up, press F8 a few times
  2. This will bring up a menu whereby you can select VGA mode from the list
  3. Once you are logged into Windows, right click anywhere on the desktop & select "properties"
  4. Then go to display settings & select a resolution of 1024 X 768.
  5. Go to advanced settings and make sure your refresh rate is no more than 70 to 75Mhz
  6. Restart Windows normally & your display should be correct.
Let me know if you have any further questions.
Best wishes,
Graemevm
Mar 30, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
I have a samsung 2033SW monitor which flickers very frequently displaying that "your optimal resolution is 1600x900.Follow the above settings to set".Though I have set the resolution to 1600x900...
- You can test the monitor by using another CPU, if still the same then the problem is monitor, but if it's working well then the problem is your CPU, to make it sure then you can try another monitor on your CPU. - check if the hardware connection is well attach, you can pull & re- plug the hardware just to make sure. - the monitor is need a DVI connection (white or gray) to run properly, if you use AGP connection ( blue ) on your VGA card that might the problem, so you can also try upgrade your VGA card. - other ways is to install the latest driver for your VGA card.
Jan 14, 2011 | Samsung Syncmaster 2033SW Monitor
I want to run a software which requires a screen resolution of 1280 x 768 but my Samsung SyncMaster 740nw supports up to 1280 x 700 screen resolution. Is there anything that I can do? Please guide.
Have you tried adjusting the screen resolution in Control Panel - Display - Settings and moving the slider on Screen resolution?
Normally a monitor such as Samsung LCD would be able to display a higher resolution.
If you cannot adjust the Screen resolution in Display - Settings then it may be that the correct video driver was not installed or is corrupted.
To check if the video diver is OK, go to Control Panel - System - Hardware - Device manager and click on Display adapter. Check that your display adapter is OK and working. If you see a yellow ? against the video adapter or a standard VGA adapter was installed then you need to re-install the video driver for your model graphics card.
Oct 30, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Monitor don't work with my CPU
first check your system resolutions on settings of display settings. what is the resolution of screen. and check monitor supported resultion information is there on monitor manual. adjust display resolution if necessary. then connect new monitor.
First you check whether the new monitor displays your system starting screen. mean before booting into windows. some text in black color.
Jun 22, 2010 | Samsung SyncMaster 743B 17 inch LCD...
My samsung syncmaster 2233sw shows multiple displayes when i take it to its max res. i use win xp sp2 and have nvidia 8600gt gfx card. the monitor works well on lower res but only shows this problem when i...
Typically this is a driver issue on the host (PC) side. DVI or VGA connection? Update the video driver. Some video drivers (especially older laptops) can't correctly send that resolution.
Jun 04, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
CHECK SIGNAL CABLE
Typically this happens when the resolution of the display is out of range of the monitor. Normally this is when the resolution is too high. Have you changed the resolution settings? Also, not to be crass, but if there a video card in the system, be sure that you are connected to the correct VGA connector. With an extra card in the system, the onboard VGA connector is not used.
Keep us posted,
Dan
Jan 23, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Computers & Internet Logo
192 people viewed this question
David Payne
David Payne
