Question about Samsung Galaxy Y
My fone has white screen and stopped working anyone know why
I washed my blackjack and the fone works but the screen stays white. anything i can do?
there probably not because it probably got shorted out and the plain white screen is usually just the light lighting up not the screen so you will have to get a new phone sorry hope this was helpful:)
Sep 25, 2009 | Samsung BlackJack II Smartphone
See White Screen + Nokia Logo + Failed to Start contact Retailer
Try formatting your phone and see if it works.
First make sure your phone is turned off.Then press the following buttons simultaneously (at the same time:
Power button + * + 3
This will restore and reformat your phone into factory settings. Hopefully your phone will be able to start again as if it were being used the first time from the box.
Let me know if it works,
Hope I have been of assistance to you,
Cheers :)
Sep 03, 2009 | Nokia 3230
Start up problem
take the battery out for about ten minutes then put it back in... that should reset the phone. have you just added the simm card ?
Jun 26, 2009 | Nokia 5800 XpressMusic Smartphone
MY SCREEN IS COMPLETELY WHITE....I NEED TO SAVE MY NUMBERS TO THE SIM CARD BUT I CANT SEE CAN SOMEONE WALK ME THROUGH IT TO TELL ME WHAT BUTTONS TO PUSH. I HAVE A SAMSUNG A 737 SLIDER I have a Nokia 6131...
Hey..
Im guessing that your settings is set to default for this to work..
-turn fone on.
-wait for a while to load up.
-press select button(middle).
There are two ways of doing this depending if your menu is set to grid or listing.Remembering is the key for it to work.
Grids:
-arrow down once
-select
-arrow up up once
-select
-select
-turn fone off after 5minutes and transfer to working fone.
List:
-arrow down 7 times
-select
-arrow up once
-select
-select
Hope this helps..
May 05, 2009 | Nokia 6131 Cellular Phone
Frozen white screen & background
i do to and i cant get another fone as i cant afford to get a new one . mine occured wen i was reciving a video from bluetooth it froze then i took out the batttery then put it back in but wen i turned it on i had a white screen and also now wen i turn it on it dosnt turn on at all then only thing it eva showns wen it is on is a white screen. - bloody hell i wrote an essay
Dec 11, 2008 | Nokia 2630 Cell Phone (Unlocked) - Black
White screen problem
if the phone is white sreen then you should try replacing the flexcables on the phones or the LCDS
Oct 14, 2008 | Sony Ericsson W550i Cellular Phone
My w850I has been wet 4 along time wont work
ITS PROBABLY CHEAPER TO BUY A NEW PHONE WATER DAMAGE ALWAYS DESTROYS ELECTRONICS
Jan 17, 2008 | Sony Ericsson W850i Cellular Phone
Dash screen will go white.
For me, the problem was definitely the ribbon connector between the graphics chip and LCD. The YouTube video below describes how to open the dash. You only need to open the device (i.e. no need to take out the printed circuit board) and then you should re-seat the ribbon cable in the lower left hand corner back onto the PCB. Hardest part was finding a #6 torx screwdriver.
Jan 09, 2008 | T-Mobile Dash Smartphone
Mobile phone
replace the lcd screen . but chake for softwere pro also.
Sep 25, 2007 | Sony Ericsson K750i Cellular Phone
Open Questions:
See all Samsung Galaxy Y Questions
Samsung Galaxy Y Logo
16 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
