Question about Samsung Galaxy Y
White screen and not working why? - Samsung Galaxy Y
A friends laptop is only showing a white screen
Step 1:
Fix a White Screen on an LCD Monitor
b>When an LCD screen has turned completely white, there are three normal causes: the screen is defective, the video cable is not connected correctly, or the graphics card on the motherboard of the computer is faulty. You will need to troubleshoot these possibilities to determine which problem you have. If you are not experienced in working on computer equipment, you should not attempt to disassemble your LCD screen because you could easily damage it. Seek professional assistance unless you have experience working on computer hardware.
Disconnect the white LCD screen from the computer by unscrewing the blue monitor cable. Connect the working LCD screen to your computer by attaching its blue monitor cable to the same slot. If your computer display does not show on the functioning LCD screen, try rebooting your computer. If it still does not display, the problem is with your computer's graphic card on the motherboard. Seek professional repair assistance. If your computer display shows normally on the working LCD screen, proceed to Step 2. Unplug the LCD monitor with the white screen. Disassemble the rear panel of the monitor with the small screwdriver. Carefully separate the screws into piles so that you can keep track of how to reassemble the monitor. Locate the internal video cable, a gray cable with a plug on the end that connects to the main components of the screen. See the References section for photos of the video cable for assistance. http://www.laptoprepair101.com/laptop/2008/04/13/laptop-lcd-screen-turned-white/ Unplug the cable, checking for any debris or blockage. Reconnect the cable firmly. Reassemble the LCD screen. Plug it in and connect it to your computer. If the screen is still white, you have a defective LCD screen. You will need to replace it or take it to a professional repair service for assistance.
b> b> b> Without this test you'll have to guess because as I mentioned before this could either bad motherboard or bad LCD screen.
You'll have to disconnect the video cable from the LCD screen (connector 2) and the inverter board (connectors 3 and 1). After that you connect another working screen and test video. For this purpose I'm using one of my test LCD screens. My test screen is cracked and because of that you see a wide white band in the center but it still works fine for this test.
The original screen is white but my test screen works normal (except the crack of course) and I can see the image. After this test I can tell that the problem must be related to the screen. After I assembled everything back together and connected the original LCD, it's still white. CONCLUSION. In my case this problem is related to the LCD screen and it has to be replaced. b> b>
Feb 06, 2013 | Toshiba 16" Satellite A665S6095 Intel Core...
My N72 is not showing any display... just a simple white colour screen
Did your phone drop on the flow? Is it just showing white and still works ?or Display white screen and not working?
For a phone to display a white, does questions need to be answered..
If it fell on the flow it's usually a screen fault and it needs to be replaced.
If it didn't fall down, but displays white screen and nothing function,it a software faulty needs a memory restoring..
If just showing white screen and you still can make calls with it, then it's screen fault needs to replace..
Feb 11, 2010 | Nokia N70 Cellular Phone
Main screen display problem
dear,
is it completely not working.. is it white screen or something else.
if the screen is white then it can be issue directly related with the screen itself but if it doesnt show white then the problem can be with the other circuitry..
regards,
Jul 18, 2009 | Nokia 6085 Cellular Phone
White screen and power and home buttons wont work
oh yea man that happen to me u just by a new one
May 16, 2009 | Apple iPod touch
Sony screen is white.
is there screen fully white or white screen with some horizontal lines ? pls send ur feed back
Dec 10, 2008 | Sony Grand WEGA KF-50WE620 Television
Blank white screen
It seems to be ur lcd stops working..Take this to service center...
Nov 29, 2008 | Samsung J700 Cellular Phone
White screen at startup
is it not coming on at all or is it just a white screen??
Jan 29, 2008 | HP Pavillion ZV6000 Notebook
White Screen No Work
have the LCD/screen replace...take it to a mobile tech and have that done.
Dec 26, 2007 | Samsung SYNC SGH-A707 Cellular Phone
My samsung digimax 503 has a white screen!
Oh my gosh this really works! Our screen went white, we hadn't dropped it or anything. The camera still worked fine but we just couldn't see what we were taking a picture of. We tried this solution and now we can see the picture through the screen perfectly. THANKS for posting this!
Nov 09, 2007 | Samsung Digimax A503 Digital Camera
White screen
I had this problem too. My razrs screen would just go white every 15 minutes maybe, and i would have to turn it off and back on.There was a white line at the bottom of the screen also, so i went to http://direct.motorola.com/hellomoto/motosupport/source/SoftwareUpdateSummary.asp?country=&language=&web_page_name=SUPPORT&strCarrierId=US%20Cellular&strPhone=V3c&strCable=Mini%20USB%20Data%20Cable and downloaded thee software update. after it was finished the white line went away the screen never went white and it fixed everything
Sep 03, 2007 | Motorola Mobility RAZR V3
Open Questions:
See all Samsung Galaxy Y Questions
Samsung Galaxy Y Logo
14 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
