Front freezes it does it at any temperature
    New Friend:
What type of air conditioner is it there can be many reasons why it's freezing are you getting and air coming out? Is the compressor working? Is the filters dirty? Check these things out if its none of the above please provide more info on Ac
Posted on Jul 16, 2013
  • Jhonny Guns
    Jhonny Guns Jul 17, 2013
    Its a kenmore,model number....580.72082200,the compressor does work and the filter is clean
  • Richard guerra Jul 17, 2013
    Once there is air coming from the unit then it seems your air conditioner may have a gas leak. A technician will have to make a repair
2006 Silverado, with a/c running and cold on both sides for 2 hours or so then the drivers side gos hot passengers side cold at the same time.
Manual or automatic climate control ?
Have you had the HVAC control panel checked for DTC'S - diagnostic trouble codes ?
Air Temperature Sensors
The air temperature sensors are a 2-wire negative temperature co-efficient thermistor. The vehicle uses the following air temperature sensors:
• Ambient Air Temperature Sensor
• Inside Air Temperature Sensor Assembly
• Upper Left Air Temperature Sensor
• Upper Right Air Temperature Sensor
• Lower Left Air Temperature Sensor
• Lower Right Air Temperature Sensor
A signal and a low-reference circuit enables the sensor to operate. As the air temperature surrounding the sensor increases, the sensor resistance decreases. The sensor signal voltage decreases as the resistance decreases. The sensor operates within a temperature range between -40°C (-40°F) to 101°C (215°F). The sensor signal varies between 0-5 volts.
The input of the duct air temperature sensors are different from the ambient and inside sensors. The HVAC control module converts the signal to a range between 0-255 counts. As the air temperature increases the count value will decrease.
• DTC B0174 Output Air Temperature Sensor (Upper Left) Circuit Range/Performance
• DTC B0179 Output Air Temperature Sensor 2 (Lower Left) Circuit Range/Performance
• B0414 is for the left air temperature actuator.
B0408 is for the left air temperature actuator.
DTC B0989 Output Air Temperature Lower Sensors Correlation
The HVAC control module monitors the upper left and upper right duct temperature sensors when the mode switch is in the VENT or BI-LEVEL positions. The HVAC control module monitors the lower left and lower right duct temperature sensors when the mode switch is in the DEFOG, FLOOR or FRONT DEFROST positions. The duct sensors are used to measure the temperature of the air exiting the ducts to help maintain a consistent cabin air temperature. These duct sensor inputs provide the HVAC control module a way to determine if the engine needs to be started to maintain a specific air temperature. If an upper duct sensor circuit failure is detected the HVAC module will not request an engine start to help cool the cabin. A lower duct sensor circuit failure will not prevent the engine from starting.
DTC B0990 Output Air Temperature Upper Sensors Correlation
Your best bet , take it to a qualified repair shop .
May 27, 2017 | Cars & Trucks
Tip
How can test Laptop?s temperature and temperature should it be at?
<p><span>If your laptop is not working ideally it may be the cause of temperature. But most laptops naturally run hot, so a system utility that can access your laptop's internal temperature sensors can help you decide if you need to take some steps to keep your laptop cool down.</span><br /> <p><span><span> </span></span><br /> <p><span>Most CPU's maximum temperatures are around 100 degree Celsius. But you can look up temperature specifications for your specific laptop's Intel or AMD processor. Optimal operating temperature is 50 degree Celsius or below.</span><br /> <p><span> </span><br /> <p><span>Some programs will help you to test your Laptop's CPU Temperature that can show you the CPU temperature as well as other system details such as processor load, voltage, and more. And some of them can also automatically adjust the speed of your laptop's fan for better performance.</span><br /> <p><span> </span><br /> <p><b><span>Speed Fan</span></b><span>- In the case of monitoring fan speeds, voltage, and processor temperatures using your laptop's internal sensors, Speed Fan can also access S.M.A.R.T. information to set your hard disk's temperatures.</span><br /> <p><span><span> </span></span><br /> <p><b><span>Real Temp-</span></b><span> The real temp is specially designed to monitor temperature for all Intel single, dual, and core processors. In the case to showing the temperature and load the processor, it also shows the CPU's safe maximum operating temperature and how far from this maximum temperature your processor is running at. Another most important feature of Real Temp is tracking of your highest and lowest temperatures since you opened the program.</span><br /> <p><span> </span><br /> <p><span>These tips may help you to determine the exact temperature for your laptop. </span><br />
on Dec 24, 2010 | Computers & Internet
Where is a air temperature control sensor in a 2004 GMC Canyon located at
There is none on your vehicle , temperature control is by a cable .There is a evaporator temperature sensor , this is used to keep the evaporator from freezing up !
Air Temperature Control The air temperature control regulates the HVAC system air temperature in any mode. An air temperature control cable mechanically links the air temperature control to the air temperature door.
Evaporator Temperature Sensor The evaporator temperature sensor will not allow an A/C request to the body control module (BCM) at temperatures less than 0°C (32°F).
Sep 14, 2015 | GMC Cars & Trucks
My 1998 gmc jimmy slt has a heating problem. The heater wont turn off. As long as the car is on the heater is on full blast. The fans work and everything knob wise works but the heater is always on.
The air temperature valve electronic actuator positions the temperature door according to the temperature setting of the temperature control on the temperature control knob. For the full COLD temperature setting, the temperature control returns approximately 12 volts to the air temperature valve electric actuator. When the temperature setting is changed to full HOT, the temperature door is moved to the warm position and the output drops to about 0 volts. For a temperature setting in the mid range, the temperature door is positioned according to the voltage supplied through the temperature control switch.
Temperature Control Inoperative
Inspect the HVAC I fuse 21.
Is the fuse open?
Go to Step 20
Go to Step 3
  1. Disconnect the air temperature valve sensor.
  2. Turn the ignition switch to the RUN position.
  3. Move the headlamp switch to the PARK position.
  4. Using the J 35616-A , connect a J 39200 Digital Multimeter (DMM) between cavity 8 (CKT 733) of the air temperature valve motor connector and ground.
  5. Move the temperature control knob from the HOT position to the COLD position.
Does the voltage vary smoothly and continuously within the specified range?
0-12 V
Go to Step 4
Go to Step 9
Using the J 35616-A , connect a J 39200 DMM between cavity 10 (CKT 341) of the air temperature valve motor connector and ground.
Does the voltage equal the specified value?
B+
Go to Step 5
Go to Step 7
5
Using the J 35616-A , connect a J 39200 DMM between cavity 10 (CKT 341) and cavity 7 (CKT 1850) of the air temperature valve motor connector.
B+
Go to Step 6
Go to Step 8
6
Replace the air temperature valve motor.
Aug 31, 2015 | GMC Cars & Trucks
Freeze protection temperature in wrong
go into menu then find freeze protect it will ask which auxillaries to be selected select with an x in front then set temp for freeze protect
Mar 19, 2014 | Pool & Spa
Maytag MFI2569VEM chills to the point that everything in the refrigerator section will freeze, regardless of the temperature setting on the front panel.
these tipe of units have an electronic board that controls basicly everything thats your problem you need to replace the electronic board. some times a temperature sensor wired to the elect. board fails but most of the time the board is the problem
Feb 10, 2014 | Maytag Refrigerators
I have cleaned out the refrigerator and it still doesn't cool enough to freeze the ice and the bottom isn't cooling enough either even after putting the temperature up.What can I do next?
Have you cleaned off the fins at the bottom of fridg? look on back at bottom and bottom front. Take off covers and see if fins are dusty if so vacume off be careful not to damage fins.
Jul 07, 2012 | Refrigerators
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
F10 oven code frequently beeps,often after cooking is over and oven is coolind down at different temperature settings tempermental some times it works sometimes it does not.
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
Jul 15, 2011 | Frigidaire Ovens
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
