Question about Compaq Presario 1800 Notebook
Compaq 1800 dvd must be missing or some thing, put in dvd or cd it reads but nothing happens on screen
  • 944 Answers
Open "my computer" and try to open the CD or DVD from there by double clicking it, or right clicking and selecting "open". If this works, you have merely turned off the "autorun" feature. If you need help to turn this back on, please ask again. If no luck, right click on "my computer" and select "properties", select the "hardware" tab and select "device manager". you should be able to see your dvd drive. right click on it and select properties and post back what it says. All the above assumes windows XP, but should be similar for others.
Posted on Aug 28, 2007
SOURCE:
I put a cd in my cd/dvd drive on my Compaq Presario SR5050NX and cannot read the data. This has always worked previously. I have a lot of cd's with pictures on them that I use frequently, and also have...
1. Check whether it happens same for other discs too.
2. If yes then your drive is faulty and you can do nothing other than replacing the drive and if no then that only particular is corrupted.
Apr 04, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
BOOTMGR is missing with windows 7 after recovery disk was tried with not completing. It gave me an erroe code 0xe0ef000e
Hi there, possible reason for this is that windows is not successfully installed. try to run the recovery cd again and if same thing happened then there is something wrong with your recovery disk. thanks!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 06, 2010 | Compaq Presario CQ60-220US PC Laptop
It just wont read somwe dvds
Your dvd drive might be bad, As a computer repair tech e see this is the problem to most bad dvd/cd drives.
Mar 29, 2010 | Compaq Presario CQ60-212US Notebook
Dvd writer/cd writer combo on a compaq presario has jst stopped working. when i put a dvd or cd into the drive nothing at all happens other than the green light appears on the front of the cd driver. no on...
1st of all insert the correct cd or dvd without scratch and then check it otherwise open you pc case and check your id or sata cable correctly connected or change your id or sata cable
Nov 18, 2009 | Video Game Consoles & Games
Some keys in the keyboard not working
Hello
The easist way and cheapest is to buy a exernal keyboard for your laptop.The keyboard is broken and you cant repair it, to buy a new laptop keyboard it very expensive.
The cd driver is also very expensive to buy, so I suggest that you buy a external one with dvd and everything.
Also check if the "CD" that the drive doesent read is DVD media.? CD drivers cant read DVD media, then you need to have a DVD driver.
Jul 10, 2009 | Compaq Presario 1800 Notebook
Only shows compaq on screen
I work with Compaq computers now and usually your problem points to the hard drive. I know Compaq's will stay on that screen if the hard drive has failed. Try another hard drive would be my suggestion.
Hope this helps.
Mar 02, 2009 | Compaq Presario 5000 PC Desktop
Dvd-cd rw drive
This means that your CD-rom drive does not read the CD, it could be that the CD is a different format (DVD, for example) or the lens is dirty or Your drive is faulty. see if your drive is compact or dvd and try the right formats. Try clean your CD-drive lens. If all this does not fix the problem, your drive is faulty. And needs repair.
Oct 31, 2008 | Compaq Presario s4020wm (DK214AR#ABA) PC...
CD ROM CR-589
Hi, A couple of possibilities: With a known good DVD with files inserted into your Compaq CR-589, double click in your My Computer, double click in your CD/DVD. 1. If it opens and displays the content, then there is nothing wrong with your DVD but the auto start feature of your OS was disabled, enable auto start; 2. If in My Computer or in Device Manager, the DVD doesn't show up, then it can be hardware problem, IDE/power cable problem, bios did not recognize DVD device, replace if and as needed; 3. If the DVD is in My Computer but will not display the files or contents, possibly defective DVD, replace. Hope this worksa out for you. Pls post again how things turn up. Good luck and kind regards.
Aug 05, 2007 | Compaq 32X IDE CD-Rom Drive (opal)...
Open Questions:
See all Compaq Presario 1800 Notebook Questions
Compaq Presario 1800 Notebook Logo
51 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
