Question about Goodman Heating & Cooling
Trane error 166 - Goodman Heating & Cooling
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Trane xv95 converted to propane is on system lockout
There is either a problem with the ignitor or the flame sensor.
Nov 18, 2013 | Honeywell Electronic Programmable...
What is error dL f
Doorlock error.
F dl Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Possible causes/procedure:
¦ Door lock mechanism is broken or removed from door.
¦ Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
I have a service manual and more HERE
Jan 29, 2011 | Kenmore Elite 45986 Front Load Washer
Unlock lg ks20
CHEAP ~ FAST ~ RELIABLE LG UNLOCKING SERVICE:
http://cgi.ebay.co.uk/Unlock-Code-LG-BL20-OPTIMUS-GT540-GD510-KP500-O2-UK-/110675878564?pt=LH_DefaultDomain_3&hash=item19c4cbe2a4
UNLOCK: HTC ¦ LG ¦ BLACKBERRY ¦ ZTE ¦ ALCATEL ¦ SAMSUNG ¦ TOSHIBA ¦ NOKIA ¦ MOTOROLA ¦ iPHONE ¦
http://shop.ebay.co.uk/e-unlocks/m.html?_trksid=p4340.l2562
Jan 08, 2011 | LG KS20 Smartphone
Heating & Cooling Logo
236 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
