Question about Ovens
Westinghouse oven pol667s
Trips safety switch after 10mins on fan bake at 250 celsius from cold
  • 139 Answers
SOURCE: AEG double oven- fan assisted not heating up
you oven element has failed.
it is located at the back of most electric ovens sometimes at the top,,
the insulation of the element has failed and when you come to remove it you will see visually see the damage... its easy to replace as there are only wires attached to it and only a few screws to undue to get to it..
hope this helps cheers
the washdoctor
Posted on Aug 24, 2008
  • 4 Answers
SOURCE: lights grill and fan work but oven isnt heating up
On our oven, we have to reset the clock before the oven will work. I think it's because of the automatic timer features.
Yours is a slightly different model, but on ours we have to press the two buttons with arrows on, at the same time as turning the clock dial. Once this is done, the oven should work again.
Good luck.
Posted on Jan 07, 2009
protek480
  • 1714 Answers
SOURCE: Cold Whirlpool AKZ451!!
You may have had a surge during the storm. Check main control board in console for damage.
Posted on Sep 01, 2009
barkencoa
  • 3463 Answers
SOURCE: Whirlpool double oven has a loud fan when baking
There will be some noise from the fan, but it should not be excessive, if it is really loud, then this is an indication that the fan is failing, and should be replaced ASAP.
Posted on Mar 12, 2010
SOURCE: Oven not heating
blue waffle is nice and i like to pop fish up my **** go to google and type in lol fish and then click im feeling lucky and do the same with blue waffle xx good look it could help your oven.
Posted on Mar 31, 2010
How to switch on oven westinghouse kimberly 509
If the oven does not work on bake or broil settings then there has to be a problem with the circuit, either on the control board or the thermostat. If only the bake element does not work then the element itself most likely needs to be replaced. There are ways to isolate further but takes some basic electrical knowledge and tools. Note that I am not recommending that you do the following linked procedure - merely pointing out an information source. https://www.youtube.com/watch?v=uZNyEqXCNOA
Mar 08, 2016 | Westinghouse Kimberley 509 Ceramic Oven
Cannot switch off oven fan.
WARNING
Go back to the switchboard and turn the oven OFF, (Switch the fuse off at the switchboard)
Your Oven sounds like it has shorted out.
DO NOT TOUCH IT
It could be live, Electricity can cause serious injury and even death,
Get a Registered electrician to check this for you. DO NOT use it.
Looks like you might be ordering out for dinner tonight :-)
Take Care
Feb 09, 2014 | Ovens
What dose 180 degrees Celsius Fahrenheit mean so I can bake
Hi Nancy,
180 degrees Celcius is about 360 degrees Fahrenheit.
Jan 29, 2014 | GE JKP30WMWW 27" Built-in Single Electric...
Convert celcius to farenheit
180 degrees c is equal to 350 degrees f (356 to be precise)
I am trying to install my oven element. I am replacing old one. Oven is Westinghouse Model POL667S
tand pull the elelment out about 3". The element should lead back to a small plate at the back of the onen. Remove the two screwsi at the back of the oven.
Pull the element out about 3" and this will expose the connecting
wires, dissconnect them and remove the element. To install the new one, Just
do the removal procedure from last to first.
Nov 30, 2010 | Ovens
Oven will not heat past 100 degrees. Circuit breaker is not tripped. All other parts of the oven work fine.
Hello there:
It won't bake or even heat up correctly or If your oven won't bake, check these: Bake igniter Other causes Bake igniter Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself. The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame. Other causes Other reasons that your oven may not bake are: The clock settings are incorrect (if you have timed baking or a self-cleaning oven). The thermostat is defective. The safety valve that prevents accidental gas flow is defective. The selector switch is defective.
Jul 24, 2010 | GE JGRP17 Gas Single Oven
Thermador SC301T heating elements not working (top and bottom). elements look fine, oven turns on but elements stay cold.... any help would be appreciated. thanks, Tony
Its the thermal safety switch. When it trips - it cuts any power from reaching BOTH elements. Open the oven door - at the top wehere the oven latch is - remove the long black panel. In the middle - on the right is a small cylindrical switch...push down on the top - in the very center...it will rest the switch (like a circuit breaker) and then reassemble. Just did it on mine (2nd time) and it fired right up. Good luck
Jul 09, 2009 | Thermador SC302T Electric Double Oven
Hotpoint sy36 oven
the electric went off wasnt sure why at the time but when i reset the trip fuse my oven stopped heating up so somethingobviously blew in the oven to cause the the elctrics to trip,
does anyone know how to replace the heating element, also the fan on the top isnt working either
Jun 16, 2008 | Hotpoint SY36 Style Line Stainless Steel...
Oven fan keeps running even after off and door open
3 to 4 hours is a long time. Get to the fans (behind the control panel) and check the screens for dust. Chances are the screens are clogged with dust and need to be cleaned so the fans can move air for cooling better. I had this problem on my GE JTP14, and after cleaning just one fan it can keep up with cooling the electronic area while the oven is running. It runs much less often.
Safety first! cut the breaker before removing anything with a nice conductive screwdriver! Hope this helps!
Jan 01, 2008 | GE Profile JTP18 Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
