Question about Carrier Heating & Cooling
What s CF? - Carrier Heating & Cooling
    New Friend:
  • 3 Answers
True "CFM" stands for cubic feet per minute, however, in a shutdown scenario likely means "Clean Filter"!
Posted on Jun 23, 2014
  • 7,733 Answers
In A/C term in means Cubic Feet.So CFM is Cubic Feet per Minute.
Posted on Jul 16, 2013
Remove bios password for a panasonic toughbook cf-30k
  • Press "F2" on your keyboard when you see the Panasonic logo appear on the screen. You will immediately be prompted to enter your Panasonic Toughbook Cf-29 BIOS password. Type the word "Biostar" into the password prompt. This is your Panasonic Toughbook Cf-29 backdoor BIOS password. Press the "Enter" key to unlock your Panasonic Toughbook Cf-29 BIOS.
  • Mar 10, 2014 | Panasonic Toughbook CF-30K (CF-30K3PAQAM)...
    When isert flash card i get err2 sign
    According with the manual:
    Err 02: There is a problem with the CF card. Do one of the following: Remove and reload the CF card, use another CF card, or format the CF card.
    Try formatting the CF card in the camera, if that doesn't work use a card reader to format it in your PC then format it again in the camera. If that doesn't work try a different CF card.
    Keep us updated.
    Mar 22, 2011 | Canon Cameras
    How to update Amap EKP IV. I downloaded a zipped file to the computer. In the zipped file are two files that match files on the compac card. If I move the zipped file to the compact card will the GPS do...
    In order to update your EKP you need a CF reader, you cannot update your CF without it.
    First of all download and unzip the update files from our support section.
    Enable the show of hidden files. Create on your Desktop the folder 'Old CF'
    and copy in it all the files from the CF (is the backup folder if something goes wrong).
    Omit to copy the 'CHARTS' folder. Create on your Desktop the folder 'New CF'
    and copy in it the same files you copied in 'Old CF'. Replace the files format swx
    in 'New CF' with the ones you downloaded from internet. Ovewrite the files in the cF
    with the ones in 'New CF' (do not touch the CHART folder). Turn on the EKP and verify
    if the procedure was correctly executed. If not, reinstall in the CF the files from
    'Old CF' and repeat the procedure.
    NOTE! : this procedure can delete all user marks from the RAM. Save them first in the CF
    with File Manager.
    NOTE! For the update of 21/oct/10 you will need to update the Jeppesen cycle to !
    Feb 06, 2011 | HandHeld Entertainment AvMap EKP-IV...
    I require LAN drivers for my panasonic cf-29
    This depends on the specific model number:
    CF-29C/D -- Realtek RTL8139DL 10/100
    CF-29E/F -- Realtek RTL8139DL 10/100
    CF-29H/J -- Realtek RTL8139DL 10/100
    CF-29L/M -- Marvel Yukon 88E8053 10/100/1000
    CF-29N/P -- Marvel Yukon 88E8053 10/100/1000
    Dec 28, 2010 | Panasonic Toughbook CF-29 Notebook
    I get a memory card error even though it has a card installed
    http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a70#ServiceAndSupport
    Issue: Memory card Error
    Solution: Try a different memory card and/or Reformat memory card PowerShot A70
    Formatting a CF Card You should always format a new CF card or one from which you wish to erase all images and other data.
    caution_a70.gifPlease note that formatting a CF card erases all data, including protected images and other file types. Please check the contents of the CF card before formatting it.
    1. Turn the power on.
    2. Press the <MENU> button and select [ tools_icon.gif(Set up)] using direction_arrow_lt.gifor direction_arrow_rt.gif.
    3. Select format_icon_a70.gif(Format) using direction_arrow_up.gifor direction_arrow_down.gifand press the <SET> button.
    4. Select [OK] using direction_arrow_lt.gifor direction_arrow_rt.gifand press the <SET> button.
      • To cancel formatting instead, select [Cancel] and press the <SET> button.
      • The capacity of the CF card displayed after formatting will be less than the rated capacity of the CF card. This is not a malfunction of the CF card or camera.
    5. Press the <MENU> button.
    • If the camera does not work properly, the inserted CF card may be malfunctioning. Reformatting the CF card may solve the problem.
    • When a non-Canon brand CF card is malfunctioning, reformatting it may solve the problem.
    • CF cards formatted in another camera, computer or peripheral device may not operate correctly. When that happens, reformat the CF card with this camera.
    Aug 03, 2010 | Canon PowerShot A70 Digital Camera
    ERR CF There is a problem with the CF card. Replace the cf card
    There is cf pins are bents and its need to replace new cf unit or repaire cf unit.
    May 28, 2010 | Canon EOS Digital Rebel XTI Digital Camera
    Scandisk curropt
    You'll need a CF reader/adaptor for your computer, and software such as this
    http://www.softwarepatch.com/software/smartrecovery.html
    Just type "recover CF card data" and you'll find a host of downloads.
    Oct 18, 2007 | Canon Rebel XT / EOS 350D Digital Camera
    CF card problem
    Perform the following procedures if your camera does not detect a CF card. 1. Restart your camera. - Set the camera's power switch to and remove the batteries. - Open the CF card slot cover to make sure the CF card is securely set in the card slot. - Insert the batteries and turn the power switch . 2. Format a CF card. Format the CF card with your camera. Refer to the Camera User Guide supplied with your camera for instructions on formatting your card. 3. Check if your camera detects other CF cards (If you own multiple CF cards.) If your camera does not detect a CF card after performing the procedures 1 and 2 above, the card that wasn't detected may have a defect.
    Aug 29, 2005 | Canon EOS-20D Digital Camera with 17-85mm...
    Error 30
    The "E30" error code is displayed when reading/writing data on a CF card has failed. Especially, the error code "E30" may appears when you tried to remove a CF card while the camera was processing data. Solution To clear the "E30" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem. 3. Format the CF card with your camera Try to format the CF card with your camera. Please refer to the "Camera User Guide" for your camera for instructions on formatting CF cards. Also, please note that formatting a CF card will erase all data on the card. Once the CF card is formatted, follow the procedure described in step 2 above and use your computer's ScanDisk on your computer to check the CF card for errors. If a card error or card failure occurs when you are using computer's ScanDisk, there is something wrong with the CF card.
    Aug 29, 2005 | Canon PowerShot A310 Digital Camera
    Memory card error - E50
    Error Code "E50" (CF card formatting error) When a camera error occurs, an error code like "Exx" will be displayed, where the x's represent numbers. The "E50" error code indicates formatting a CF card has failed. Solution To clear the "E50" error, try performing the following procedure. 1. Try using another CF card. If you have another CF card, try loading it in the camera. If the error code is not displayed when the other CF card is loaded, there may be something wrong with the first one rather than with the camera. 2. Use your computer's ScanDisk utility to check the CF card for errors. Use ScanDisk to check the CF card for card error or card failure. Refer to the instruction manual for your operating system or Windows Help for further instructions. (If you are using a Macintosh, use the "Disk First Aid" program to check for card error or card failure. Refer to the instruction manual for your Macintosh OS for further information.) Be sure to back up the data on the CF card on the computer before you check the CF card. If a card error or card failure occurs when you use your computer's ScanDisk, there is something wrong with the CF card. Follow ScanDisk's on-screen instructions to solve the problem. If the same error occurs when you are using the CF card supplied with the camera, please contact the retailer where you purchased the camera or the nearest Canon service center. If the error code is displayed right after you took a picture, the image may not have been recorded. Switch the camera to playback mode to check if it was recorded. Precautions for handling a CF card: - Do not remove a CF card or disconnect the camera's power source while the camera is recording, loading, or erasing data on a CF card. - CF cards are high-precision electronic devices. Do not bend, force, or subject them to shocks or vibration. - Do not attempt to disassemble or alter a CF card. - Place the CF card in the supplied case for storage. - Moving a CF card rapidly between temperature extremes may cause condensation in the card, leading to potential malfunctions. To avoid condensation, place the CF card in a sealed plastic bag before moving it into a different temperature area and allow it to adjust slowly to the new temperature. If condensation forms on the CF card, put it aside until the water droplets have evaporated completely. - Do not use or store CF cards in the locations subject to dust or sand, high humidity, or high temperatures.
    Aug 11, 2005 | Canon PowerShot A85 Digital Camera
    Heating & Cooling Logo
    257 people viewed this question
    Top Carrier Heating & Cooling Experts
    Bill Long
    Tim Whalen
    Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
