Question about Sevylor Inflatable River Xk2 Kayak
How to repair sevylor river xk2 - Sevylor Inflatable River Xk2 Kayak
3 Suggested Answers
SOURCE: sevylor river xk2 does not track well on still water
This inflatable kayak is meant to turn to facilitate maneuverability in whitewater; it needs to turn.
Try attaching piece of plastic as a skeg, perhaps the skeg from the Sevylor Tahiti will suffice (or a piece of lucite or a plastic cutting board). A skeg makes a boat track straight.
My Sevylor Colorado came with an optional skeg which I only attach on flatwater (never whitewater).
Posted on Sep 13, 2009
ambonurse
  • 15 Answers
The xk2 can be quite a challenge on smooth water. It you're not going to use it much on fast/shallow water, you can get skegs kits from Sea Eagle. They can tell you which glue you need. They will improve handling immensely, and won't slow you down much.
Posted on Nov 05, 2016
How to repair punture in both skins
Can I purchase a new bladder and if I can, where would I find it?
Jul 16, 2013 | Sevylor Inflatable River Xk2 Kayak
I have a cut 2-3in. in the iner blader (hull) of a Sevylor Colorado? Best way of repairing this ? Thanks
alrigth, for fast repair, i would use tuck tape( the red one) if you d'ont have anything else. you can also use an old bike tire tube, cut it open and take the piece you need to cover the entire cut and a little more. you want to use contact glue to make it work, to use the glue, put the glue on each pieces on the side you want to glue together. wait for about five minute(let it dry) in the meanwhile ,put the tube (the part that has the cut) on something flat, put the two covered glue surfaces together, put someting flat on top of it (just like a big sandwich) and put some wheigth on top of that, wait for 30 min and it should be repaired
May 18, 2011 | Sevylor 48 in Inflatable River Tube
I have a Sevylor Tahitik 79 Model kk79 PM purch second hand w/out instructions; I can inflate bottom without problem but cannot figure how to inflate sides. Can you help me with this?
up front under the spray shield on the sides of the main side tubes, you will see them pump yhe floor first and that will open the sides to get at the valves. mine are black Boston valves ,
May 08, 2011 | Sevylor 48 in Inflatable River Tube
WHERE IS THE AIR NOZZLE TO FILL THE SEVYLOR FLYING MANTA RAY LOCATED
All the Sevylor tubes have a valve that comes apart in to two pieces, remove the top and you can fill remove the hole thing releases the air. You need a 12 volts high volume low pressure pump with connectors, 20 bucks in Overtons. Fill it till it is stiff, put it in the water let the air cool down inside then hand fill it with the connector and human breath to stiff it up again.
Sep 07, 2010 | Sevylor 48 in Inflatable River Tube
I;ve got a hole in the bottom of my Sevelor Colorado, is there any way to fix it? other than going to someone who can vulcanise the hole.
Depending on the material type, a standard bike tyre tube rewpair kit may work very well! Just follow the instructions int he repair kit and see how you go. At any rate you are not going to cause any more damage than what is already there and there is a good chance the bike tyre tube repair kit will repair the hole (assuming it is not too large of course)
Mar 30, 2010 | Sevylor 48 in Inflatable River Tube
Protruding tube
I sell on eBay and I just went there to check for you. There is a lot of them there-not sure if its what you need exactly. Put in ebay search sevylor tube. Hope this helps burdfrenzy
Oct 17, 2009 | Sevylor 48 in Inflatable River Tube
Sevylor motor mount instructions
I dont believe a motor will mount to it. Sorry!
Sep 30, 2009 | Sevylor 48 in Inflatable River Tube
Sevylor river xk2 does not track well on still water
Aug 14, 2009 | Sevylor Inflatable River Xk2 Kayak
Rip in kayak
try underwater epoxy
Jul 15, 2009 | Sevylor XK2 - SVX200DS Kayak
Sevylor Inflatable River Xk2 Kayak Logo
78 people viewed this question
Top Sevylor Boating Experts
Fabrice Wolters
Tom Chichester
Are you a Sevylor Boating Expert? Answer questions, earn points and help others
