CS REMOTE CARE is a program that will email the service center problems with the machine IF you have that set up with your maintenance company if not its not going anywhere
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1. Turn main power switch OFF.
2. Turn main power switch ON while pressing the Menu/Select key.
3. Keep pressing the Menu/Select key until the LED turns OFF on the control Panel.
4. Check to make sure that "Trouble Reset" is displayed on the control Panel
after LED turns OFF.
5. Pressing the Menu/Select key.
6. Check to make sure that "OK" is displayed and the it has been reset.
7. Turn main power switch OFF and ON again, and make sure that the machine properly
starts.
Good Luck and Thank You for using Fixya.
WheatlandServices
