Question about Samsung SCX-5315F All-In-One Laser Printer
Samsung scx 5315f- over heat
I just change the fuser unit couple months ago.. and suddently.. the paper get stuck in the fuser... and burnt.. and have an over heating error on the lcd. should i just change the fuser unit again or is there anything else to change together with the fuser unit....thanks...your help is much appraciate
2 Suggested Answers
  • 192 Answers
SOURCE: samsung scx-5315f printer giving error paper jam 2 inside .
If you have taken apart the printer and checked where all the paper could have jammed up, use compressed air first on the printer. Then, check your toner cartridge. I know on my HP I had a sample toner cartridge and I put another one into the printer. It either was damaged or scratched, etc. and it caused the printer to not respond.
Posted on Sep 01, 2009
I'm using Samsung SCX-4521F printer. but after printing all words are erased from paper. what should I do to fix this problem?
Verify the fuser unit.The image dont fixing on paper.Is fusing unit problem.Verify the fuser heater lamp continuity,the thermistors and the spring at lower pressure roller.
Feb 22, 2013 | Samsung SCX 4521F All-In-One Laser Printer
Have a Samsung SCX-5315F All-In-One that has a line running down the page when you copy using the document input tray. Clean copy when using the flatbed. I have cleaned all the glass thoroughly.
It sounds like it is dirty where it feeds through and not on the flat bed glass. Try and gently lift up the top section where the paper feeds through. If it resists you may need to locate clips or screws but generally the thin strip of glass under the top feeder is easily accessible. Good Luck
Feb 18, 2010 | Samsung SCX-5315F All-In-One Laser Printer
Open heat error
There is a heating element in an assembly called the fuser which melts the toner onto the paper after it's been stuck on by the printing drum. In electronics, an open circuit is a circuit that doesn't conduct electricity. Either the heating element has a cable that's unplugged or the heating element has failed. There's a chance you can order a new fuser assembly that you can install yourself but you might need to have a pro work on it for you.
Oct 19, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Samsung scx-5315f printer giving error paper jam 2 inside .
Sep 01, 2009 | Samsung SCX-5315F All-In-One Laser Printer
Jam 01-009 code from my Samsung SCX-6345. It always jam at the fuser unit please help.. thanks..
Probably have a scrap paper stuck in the fuser or a "stripper finger" out of place, catching the paper. You'll need to remove the fuser to get a good look at things.
Aug 04, 2009 | Samsung SCX-6345N Laser Printer
Samsung scx5315f printing black smudge along edge of page
The fact that it's printing anything suggests that it is not a Toner problem. Remove the toner, and have a look at the run inside the printer, checking for any excess toner which is in there. Also, check the Drum and Imaging Unit for damage, wear and tear etc. There will also be a static strip near the imager, with a little tab which you can sweep across the unit to clean it.
Mar 05, 2009 | Samsung SCX-5315F All-In-One Laser Printer
Samsung scx-4216f
may be fuser unit thermostat problem. if it is low heat eror change it.
Jan 12, 2009 | Kyocera KM-1510 Copier
Open heat error cycle power
the thermistor in your fuser unit is faulty.
Dec 24, 2008 | Samsung SCX-6322DN All-In-One Laser...
Open heat error on samsung scx 4100
What the error message is referring to is that the fuser assembly in the back of the unit is bad and wont heat up to the required temperature. A fuser is used to melt the powdered toner into the paper.
You are probably going to have to call a service tech to verify this and have it ordered and installed as usually this is not a user serviceable part.
Dec 05, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Error code
I believe your error message is "Open Heat Error". If that's the case, your fuser unit is bad. I understand that it is a new unit, although you do no specify if is is brand new or refurbished.
Now see, the open heat error comes when the temperature sensors on fuser detect a higher temperature than normal. I f that's the case you can easily confirm that by opening the side door (as if changing the toner) and feeling the intense heat coming out. If the fuser was new, then most probably you got a bad power supply board.
This is truly bad news, because for the power supply board to get damaged, a voltage surge must have ocurred. In most cases, there is also a need to replace the main board as well, for the copier starts working erratically, and loses some of its functions (such as duplex copying).
If the unit is under warranty, call Xerox. If you plan to get it repaired, or fixed by yourself, you can buy cheaper Samsung parts, for Samsung is the real manufacturer of the unit. The Samsung model is SCX-5115 gor a non fax unit, and SCX-5315f for a fax capable unit.
Good luck.
By the way, if you happen to fix the copier, or buy a new one, the only way to TRULY protect it from voltage damage is with an Innovolt SVSS protector. This is truly new protection technology and we sell them a lot here in Puerto Rico. Price is $74.95 plus shipping.
May 28, 2008 | Xerox WorkCentre M15i Laser Printer
Samsung SCX-5315F All-In-One Laser Printer Logo
21 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
