Question about Altec Lansing MX5021 System
Altec lansing v-2121
Pls. show me a schematic diagrams
5 Suggested Answers
  • 11 Answers
SOURCE: Altec Lansing VS 4121
It is unlikely that this is a problem with your speakers more likely that it is a problem with the DVD player itself. I would recomend trying another DVD player.
Regards, Andrew
Posted on Sep 17, 2008
SOURCE: Can the Altec Lansing VS3251 5.1 work with a Xbox?
Because this system is made to work with the PCs, it has a 3.5 mm stereo input. The 360 has rca cable outputs. Fortunately, the signal is the same and all you need is a 3.5 mm to rca y adapter that you can find at radioshack or any local electronics store.
Posted on Apr 16, 2009
  • 515 Answers
SOURCE: Doesn't power on when you
Did you notice the plug to the wall outlet and make sure the wider blade is plugged into the longer slot? Is the other end of the power cable connected right to the speaker? Is the LED lit after you pushed the power button? Is it too dark but lit? Is there a surge protector not turned on? If you saw LED light on but hear no sound, there might be problems with the computer or devices connected to it or we can diagnose further.
Posted on Jan 13, 2011
SOURCE: Altec Lansing ADA995 does not work
This is my Dell Altec Lansing 5.1 (ADA995) surround sound amplifier for my computer. There is a design flaw where the board gets corroded due to the fact they caulked or glued it togther and left some of the circuit board hanging out. Just thought I would point out my findings in case some of you had the same system. It's a relatively easy fix. I got all the parts from Newark for about $30.00, and it took roughly 2 hours. Original Amplifier Chips below:
Positive Voltage Regulator is blown out:
Notice the traces where corrosion caused a short:
Another view of the burnt traces:
The glue or caulk ran straight across here:
This resistor was blown out.
I pulled it out before I took the picture I went ahead and replaced all of the 4.7 ohm 1/4 watt resistors:8_18_2012_3_31_59_am.jpg
Blown out 4.7ohm 1/4 watt resistor:8_18_2012_3_32_37_am.jpg
Just before surgery on the amp chips:
Re-jumpered the traces:8_18_2012_3_35_55_am.jpg
Re-jumpered the traces:8_18_2012_3_36_44_am.jpg
New amp chips are in! Boy that "Heat Sink Transfer Paste" is really messy!!!:8_18_2012_3_37_26_am.jpg
A peek at the underside:8_18_2012_3_38_11_am.jpg
New L7815CV Positive Voltage Regulator (Shown here):
New L7915CV Negative Voltage Regulator is on the back side:8_18_2012_3_39_35_am.jpg
New amp chips are all nestled down in their new home!:
Boy that's a big heat-sink:
Time to try it out. And it works. Boy, going a week with out 5.1 audio on your computer is terrible! Nobody should have to live that way or be subjected to that kind of torture. I guess this would be considered a "first world problem"!
-Jason-
Posted on Aug 18, 2012
Altec lansing 9 pin din schematic diagrama
try phone app called electrodroid its at google store free app showing pin diagrams ,that might help
Mar 25, 2016 | Altec Lansing Audio Players & Recorders
I need a circuit schematic for Altec Lansing amplified speaker system 121
You can always try the manufacturer but I would not hold my breath. Try to google it - that is a better choice since perhaps others have also had hassles and ................
Aug 09, 2015 | Altec Lansing Audio Players & Recorders
Altec lansing mx5021 pls. give the 9pin wiring diagramthe the color code 9pin going to mainboard.
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Jun 11, 2015 | Altec Lansing MX5021 System
Wiring diagram for altec lansing acs340 sub woofer
This is not something that you will get access to from here. Try asking a repair shop if they can get the schematics for this speaker. You could also contact A-L directly.
Not likely to happen.
Altec Lansing ACS340 Specs CNET
Furthermore these are inexpesive 2.1 speakers that can be replaced for 30-40 dollars. Not worth the effort.
Mar 09, 2015 | Altec Lansing Audio Players & Recorders
Altec mx 5021 schematic diagram
We may not be able to find yet your free schematic diagram,
But if you insist on repairing your computer speaker,
• Open it up , and look for possible causes of
symptoms .
• Check on line for the datasheet of the amplifier,
• Use a multimeter to check for open and short
circuits.
Here is guide when repairing similar Computer Speakers
http://www.fixya.com/support/r4008719-diagnose_not_having_audio_right_channel
Jul 26, 2012 | Altec Lansing Audio Players & Recorders
VS-2121 altec Lansing - ORANGE BIG FAT CABLE MISSING TWO MIDDLE PINS
well u could try a shop that sells music equipment they should be very common... but u need to know how to solder :D or at www.aswo.com i think they have cables....
Jan 19, 2008 | Altec Lansing VS2121 Computer Speakers
Altec Lansing MX5021 System Logo
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
