Question about Microwave Ovens
Baumatic bamw2531 p
Door button not working
Push button on microwave has stopped working
It is easy and cheap to fix this, but you need to know about electricity and electronics. Look for a local appliance repair person if you feel it is worth it, but many ovens are so cheap it may not be worth the repair costs.
Oct 09, 2014 | Baumatic BTM23 900 Watts Microwave Oven
Switch on machine comes up as 5?
please follow this steps and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Nov 19, 2013 | Baumatic Microwave Ovens
What microwave replaces the btm25ss baumatic builtin microwave. i need one the same size.help?
Contact Baumatic and ask if they have a "drop-in replacement".
Their contact information will be on your owner's manual or the dealer where you bought it should know.
Apr 08, 2013 | Baumatic BTM25SS Convection Microwave Oven
I"m looking for a wiring
The closet model number I could find was the BT83Al which is a discontinued model. At teh follwoing site you can download a User Manual and Technical Drawing.
http://www.baumatic.co.uk/bt83al_21_106_550.html
If this is not your model other discontinued models can be found here:
http://www.baumatic.co.uk/cooker_hoods_21_106.html
Current Models:
http://www.baumatic.co.uk/cookerhoods.html
Feb 11, 2011 | Baumatic Microwave Ovens
We have a BAM2801 Microwave oven that has started to randomly beep and 8's keep coming up on the screen. No other buttons appear to work and we can't stop it beeping. Are you able to provide any...
Ours did exactly the same thing. Fortunately we are still in the warranty period and it is to be replaced, but the 2801 is apparently out of production and we are now in discussions over its replacement. They brought a BAM253TK today, but it is smaller, has fewer features, fewer heat options and has a rotary dial, not push pad and the one they brought had a faulty door opener. I'll see what eventuates!
Dec 12, 2010 | Baumatic BTM24 Microwave Oven
How do we replace the light bulb in our Baumatic BTM25SS microwave oven? It seems to be inaccessible....
From Baumatic:
"Unfortunately, the bulb is positioned next to the main working component of
the microwave. This means only a qualified domestic appliance engineer,
trained to work with microwaves can carry out such a repair. If you wish to
have a Baumatic engineer attend, please contact the Baumatic Customer Care
team direct on 0118 933 6911. If, however, you wish to purchase the correct
bulb and have a local engineer carry out the repair, please call the
baumatic Spares team direct on 01235 437 244 for price and delivery
information."
Nov 20, 2010 | Baumatic BTM25SS Convection Microwave Oven
Mod: BMK 2 SS. Manual has gone missing!
http://www.baumatic.co.uk/products/catalogue/microwaveovens/BTM23.1SS
I beleive this is the same item, not sure why it has a different model number on the website, but you can download the PDF of the manual from the above link.
Oct 07, 2009 | Baumatic BTM231SS Microwave Oven
How to replace bulb in baumatic btm25ss microwave oven?
Had the same problem. From Baumatic:
baumatic Spares team direct on 01235 437 244 for price and delivery"
information.
Apr 17, 2009 | Baumatic BTM25SS Convection Microwave Oven
Remove built in microwave Baumatic BTM231SS 900 from cabinet
Hi Brunie1,
They are on popers so with a knife being careful not to bend either knife or surround gently prise 2 strips either side of door. this should then reveal the 4 screws
Mar 25, 2008 | Baumatic BTM231SS Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
