Canon ir 3035/3045 e000020 000
My printer showing error like this E00020-000 why? what is the problem?
  • 118 Answers
SOURCE: canon iR C3200 E00020 02d0
check or change the magenta drum unit
Posted on Jul 30, 2009
SOURCE: canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
Posted on Jul 20, 2010
dj_relly999
  • 4070 Answers
SOURCE: have an error code on
Hi! It is related to the density sensor and the drum. This will surely need replacement to correct the problem. HOpe this helps and thank you for using FixYa!
Posted on Sep 22, 2010
Joshi_Z
  • 567 Answers
SOURCE: canon 5180 error code E00020-124
e00020 - Indicates a fault with the drum developer.
subcode 01xx - yellow drum
subcode xx24 - salt sensor
Return the machine to door spec, replace the transfer belt, belt cleaning assembly, salt sensor and inspect patch on belt.
Following this will resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
Posted on Oct 15, 2010
SOURCE: Error E007
you need to change the fuser film in the fuser assembly the white patch on the fuser film is warn out
Posted on Jul 26, 2012
Error E00020-0010 IS SHOWING WHT DOES IT MEAN?
do you check the fusing unit?
clean the termostors
check lamps
Jun 07, 2016 | Canon Imagepass S2 Fiery For Ir...
IR 7095. Como puedo reparar marca el error E00020?
Lo que indica es que a pesar que tiene toner la tolva sigue indicando que no hay toner. Posible obstrucci?n en el paso del toner o sensor de toner de la tolva defectuoso
Jun 19, 2015 | Canon Office Equipment & Supplies
Canon ir 3035 error code e00020-000
REPLACE THE DEVELOPER ASSEMBLY TONER SENSOR.REPLACE THE SUB HOOPER TONER SENSOR,OR DC CONTROLLER
Apr 10, 2015 | Canon Office Equipment & Supplies
Error code e000020 0000
remove waste tonner from the machine
Nov 23, 2013 | Canon IR 2230 COPIER FOR 220 VOLTS ONLY
Canon IR C 2880 Error code E00020-0101
This error code refers to the fuser unit not reaching temperature. A new fuser is required.
Feb 26, 2013 | Office Equipment & Supplies
Canon image runner ir 5070 error E00020
E0020. problem with developing unit. sometimes or often toner doesn't full of motor developer, it is may be the toner become froze or no toner.
Dec 26, 2012 | Canon Image Runner 1630 Copier Copier
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
E000020-0010
you have a problem with your developer or toner add assemblys toneris not going into your dev unit
Aug 15, 2009 | Canon imageRUNNER 7200 Copier
Canon iR C3200 E00020 02d0
Jul 29, 2009 | Canon imageRUNNER C3200 Copier
Canon IR 2020 showing system Error E007 printer
Jun 16, 2009 | Canon iR 2022 Printer
35 people viewed this question
jasbo
jasbo
