Question about Makita Circular Saw 7 1/4in., 15 Amp, 5800 RPM, Model 5007MG
How do i remove the motor out of a makita model 5007mg
2 Suggested Answers
H2_Brad
  • 425 Answers
SOURCE: how to get motor out of houseing on a makita 5007MG circular saw
The armature and field will need to come out. It's quite a bit of work to swap everything over. Here is a parts diagram which should help.
Makita 5007MG diagram
Posted on Aug 22, 2012
My Makita DSS610 18v cordless circular saw stopped working mid cut. I changed the battery to another, fully charged, one but still nothing. Tried again next day, with both batteries, still nothing.
Hello Derek, it seems that your motor or motor brushes have failed please contact the manufacture about replacing the motor brushes.
Sep 15, 2016 | Makita Saws
Makita 5007mg blade spins wont cut thought
blade bone or sitting upside down on the machine or the drive shaft is worn
Aug 01, 2015 | Makita Saws
How to gear spindle from housing
The unit is retained by two or three screws surrounding a retaining ring on the saw blade side, and I believe there are some screws holding the gear housing on the motor side that need to be removed as well. I just replaced the bearing on mine a week ago, and even though the situation is obvious once you figure it out I was not smart enough to do so, and wasted an hour trying to figure out how to remove that retaining ring over the bearing. Good luck
Apr 05, 2013 | Makita 5007MG Factory Reconditioned 7 14...
While cutting saw jammed for a second or two and stopped . what part do i need to relace ?
Check the brushes and the fuse in the plug otherwise untill it has been opened up and check it is difficult to say.
Dec 12, 2012 | Makita 5007MG Factory Reconditioned 7 14...
How to get motor out of houseing on a makita 5007MG circular saw
Aug 06, 2012 | Makita 5007MG Factory Reconditioned 7 14...
No power
Check fuse in plug if fitted, possibly cores in cable have broken, this is most likely to happen at plug and where cable enters body of saw.
You will probably have to open the handle of the saw and do a continuity test with a continuity meter or multimeter from the pins of the plug to where the cores of the cable enter the trigger switch. If this checks out ok, then check brushes haven't worn, check for any overheating on armature.
Feb 28, 2011 | Makita 5007MG Factory Reconditioned 7 14...
Need to know where to get a replacment guard for my 5007MG circular saw
if you give me your general area I will try and find a local dealer for you, you can also look in the yellow pages under tool repair for an authorized dealer, but it is faster online to find one. Or if you want you can go to Makitausa.com and they have a locator. Let me know if you need more help before voting please and thank you.
Feb 17, 2011 | Makita 5007MG Factory Reconditioned 7 14...
1/2 inch makita drill , model # 6013BR . Problem ;;;; great deal of arcing and smoke from vicinity of brushes. Would like to attempt my own repairs but am unable to remove the motor because I can't figure...
Take digital pictures as you go. Get a parts list if you can as well.
There are some electronics cleaners special for sensitive electronics and motors.
Compressed dry air may help as well.
Most drills housings will require a long round shank tool. These tools are in the forms of philips or torx some even security torx depending on the Mfg.
Jan 16, 2011 | Makita & 1/2 Inch Drill
Makita "7 1/4 inch" circular saw poblem. the saw seems to lose power soon into ripping boards. if you letit sit andcool, it will work again, but will quickly cease upagain. the saw blade seems to go...
Clean the armature and install new brushes, the armature is burned with carbon and loses its ability to conduct electricity properly. Make sure to in between every copper rib on the armature so it doesn't ground itself back out.
Oct 06, 2010 | Makita 5007MG 7 1/4 Inch Magnesium...
Makita Circular Saw 7 1/4in., 15 Amp, 5800 RPM, Model 5007MG Logo
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
