Question about Toshiba Satellite A100-ST3211 Notebook
Booting problem i just got a new toshiba satellite 100, but twice the laptop could not start up unless u hit it. both the power and charging light will come on but the screen will be blank.
  • Toshiba Master
  • 12,061 Answers
Sounds like you have a "loose connection" in your lappy, thats NOT acceptable with a new unit. I suggest ya take it back to the shop and quietly "read em the riot act"... and get replacement or repair...... A repacement would be the most desireable outcome, as far as I would be concerned, Claiming under the "Manufacturers Defect" side of things. One should NOT have to "Hit" any device to make it work.. more so when new!
Posted on Aug 28, 2007
SOURCE:
I have a Toshiba satellite C55 laptop that will only show one light on the front when plugged into power source. I have bought, and put in, a new battery, and it would go to the advanced boot up screen,...
Try this:
Disconnect the battery from the laptop; Plug in the AC power cable, try turning on the laptop again.
It SHOULD power up and continue to boot into windows like normal.
If it does, now put the battery into the laptop while the laptop is on.
Make sure in windows you see that the battery is charging.
If it is, then the battery was to depleted on energy to start the laptop; Some laptop batterys have to have a minimum charge in order to start the laptops. Even if the power cable is plugged in.
Oct 04, 2013 | Toshiba Satellite Computers & Internet
Toshiba satellite l305d-s5934 Won't charge battery dont power On
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 25, 2012 | Toshiba Satellite L305D-S5934 Notebook
Toshiba Laptop will not stay on for more than 5 seconds
Sounds like the battery is dead or not able to hold a charge. Plug in your wall adapter and see if your laptop light comes on. If not then the adapter may be bad, thus not charging the battery. Another common problem is the AC jack on the laptops get broken inside and need to be either resoldered or replaced. Thats why you see a ton of them for sale on Ebay.
Sep 14, 2009 | Toshiba Satellite A60 Notebook
My laptop(Toshiba Satellite A105 - S2051) wont turn on with or without battery on a/c adapter. Adapter seems to have a charge but when i plug it in and try hitting the power button nothing happens. I do...
hi, this is tricky, as the machine does seem to freeze even before booting. the fan may have become stuck, use some compressed air with the fan inlet (bicycle pump may do) to clean out some dust.
wait some time and switch on again.
observe if the green lamps for harddrive and cd-drive light up.
if no, the computer does not boot up, it may be then that :
the fan is broke and laptop prevents overheat damage by not booting up(buy a new fan and replace it)
or the machine itself is broke
in either way, if the solution i provided did not help, i would recommend to see a technician!
good luck then
Aug 08, 2009 | Toshiba Satellite A105 Notebook
Toshiba laptop power light on but not working
Try this.Your VGA is problem or your battery is fully charge down.so please fully charge your battery atleast 8 hours and then press your power switch.it will on your loptop system.
plz Call 09944377607 V.RAJA
Jul 25, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Laptop wont work unless plugged in, i recently bought a new battery think that the battery was the problem and still it doesnt work unless its plugged in. please help me!
Go to CONTROL PANEL / POWER OPTIONS / POWER METER. Is the battery charged or charging?
If POWER METER says the battery is charged, you have a motherboard problem. Take it to a tech.
Do you have a voltmeter?
Remove the battery and check for voltage at the laptop's battery contacts, while it is plugged in. No voltage = charging circuit defect. A blown internal fuse or other motherboard problem. Take it to a tech.
Voltage OK or no voltmeter - take it to a tech.
A qualified technician should have a schematic and other technical documentation for your model It can be rather difficult (expensive) and hit-or-miss to locate possible fuses without the factory paperwork.
Good luck.
May 13, 2008 | Toshiba Satellite P105-S9722 Notebook
Battery: Fast Discharge, Slow Charge, Charging Lights Flicker, Runs off battery when plugged in
Problems sounds like a damaged power pin from pulling or jerking on the AC cable. I use a Cable Retention Device like the one in this video to keep from hurting the pin.
Dec 29, 2007 | Toshiba Satellite M35X-S149 Notebook
Power conflict
Thats an infamous retard sowtware fukup tweak your settings back to default LAPTOP power settings if it no workie then its a connections issue in wich case get it seviced by a pro (not geek squad)....unless your a rich guy with money to burn
Oct 27, 2007 | Toshiba Satellite A135-S2386 Notebook
Toshiba satellite A60 no boot
We can only assume that because the cd drive operates then the motherboard is operating in part, although, the southbridge chip may be damaged, as the northbridge works memory etc. Maybe it is that the processor is fried as there is no fan and the system then shuts down. Toshiba are probably half way there with the answer, unless; they investigated further and decided it was not the processor but the motherboard.
Jan 02, 2007 | Toshiba Satellite A60 Notebook
Computers & Internet Logo
44 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
