Question about Refrigerators
St14ckxsq00 what size is this fridge - Refrigerators
Freezer capacity fisher & paykel fridge model E521T
Type Freezer on top Fridge size Large (451-525 L) Total volume (L) 517
Fridge volume - claimed (L) 400
Freezer volume - claimed (L) 117
Height (cm) Width (cm)
https://www.choice.com.au/products/home-and-living/kitchen/fridges/fisher-paykel-e521t
Apr 28, 2018 | Fisher Refrigerators
WHAT THE CUBIC FOOT SIZE FOR THE MEASUREMENTS OF 62"H x 23.5"W x 24"D?
The cubic ft capacity spec on a fridge is measured inside, and varies depending on its design, especially on whether it has an ice maker, although those measurements you give seem to be for a bar fridge or similar.
Your measurements come to 20.3 cu ft on the outside, but remember that is not relevant, you have to measure the dimensions to make sure it fits.
Feb 25, 2016 | Refrigerators
Cubic feet of my fridge and freezer model #ED5CHQXVQ00
The model number usually depicts what size fridge it is. ED 5 ?? That would suggest 5 cubic feet. ?? In Australia, fridges are measured in litre size. IE/ a fridge with say a model of HE550 would suggest 550 litres ( a reasonably big fridge)
Apr 09, 2015 | Refrigerators
What size is the glass shelf in a consul 8 cu ft propane fridge
measure the space with a tape measure or order by model number :-)
Aug 18, 2014 | Refrigerators
Whirlpool 6wmv43ns/02 Fridge Too Cold & Freezing Food
I would first try replacing the control in the fridge. If that doesn't remedy the situation, I would try replacing the thermostat next.
May 14, 2012 | Whirlpool Refrigerators
What is a 1/2 inch or 3/4 inch water tap? For washer n side by side fridge with water dispenser.
As standard size for most fridges as much as we know they take 1/4 inch water lines
As you could buy fridge water line kits from appliance service shops
Jun 07, 2011 | Bosch Washing Machines
My compact fridge does not defrost and ice builds up in freezer section. How can I disconnect the freezer and not use it?
Lynne, the freezer section is what provides the cooling for the fridge, so there is no way to disconnect the freezer and still be able to have the fridge operate.
With the small compact fridges, the only thing you can do is to manually defrost the unit, when the ice buildup gets too much, which can vary, based on how you use your fridge, how often it gets opened and closed, etc.
Some compact fridge models have a small push button in the center of the temperature setting control knob - if your's has one, you can push that to initiate a self defrost cycle. However, you'll need to have some towels handy to collect the water that will result from melting off the freezer section.
There are not many small, compact fridge units that have the no-frost feature of full sized fridges, as it is more costly to build in all the needed components required to have frost-free operation. Not to mention the size of the fridge gets much larger, because of all the space needed to house those features (defrost heaters, electronic controls, ciruculating fans, control vents, sensors, drip/drain pan, etc., etc.)
Hope you find this Very Helpful and best regards!
Aug 25, 2009 | GE Refrigerators
I just bought a RoadPro 2500 and i want to buy like a dorm fridge how many watts or volts size would work??
If you are referring to the RoadPro RPPI-250
  • 2000 Watts Continuous Power
  • 2500 Watts Power Output @ 10 Minutes
  • 5000 Watts Peak Power Output.
  • A small fridge will use about 500 -700 watts, with startup wattage at around 2000watts.
  • So, a dorm fridge will work fine.
  • the RoadPro converts DC to AC voltage, so a regular 120 volt dorm fridge will work.
  • Jul 05, 2009 | RoadPro RPPI-2500W Inverter
    What size star key do I use to take off the fridge doors of model MTX18BAXJRWH?
    The torx T-20 is generally the size needed for fridge hinges. That said, I recommend that you purchase a set of these star [torx] screwdrivers, then you will have what will soon become a most common screw in the industry.
    Jun 14, 2009 | Refrigerators
    Repair lining of fridge
    depending on the size of the hole you can use white rtv silicone or white epoxy
    Feb 09, 2008 | Refrigerators
    Refrigerators Logo
    62 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
