Question about Furuno GP7000F/NT GPS Receiver
Sounder/gps cuts out on engine start
As soon as the key to the 115 yamaha fourstoke is turned the unit shuts down instantly I have checked for voltage drop at bus bar with voltmeter and doubled up positive cables to battery switch. boat is aluminium and i havent grounded unit to it. It has only one battery
2 Suggested Answers
  • 111 Answers
SOURCE: GPS/plotter/sounder will turn on and operate properly. Unit will
Try removing your chart card then powering up your unit. Chances are your chart could be bad and is causing the problem.
Posted on Jan 25, 2010
I have a Kohler 7.3 ECD generator with error code UVunder frequency. Restarted gen and it ran for one hour so I shut it off. What's the problem?
check the operating rpms
the rpms determine the voltage and frequency and can be adjusted at the governor spring setting
adjust it until the voltmeter reads the required voltage
set slightly above to allow for rpms drop under load
for example if 240 volts set around 250 volts and that will drop back to 240 volts under load
if 110 set around 115 and that will drop back under full load
both frequency and volts are dependant on rpms
Sep 20, 2016 | Kohler Electrical Supplies
Have power to starter when key is on
Hi, Anonymous after you disconnect the battery, remove the starter solenoid cap and break away the contact plate from the shoes and clean/dress all electrical arc residue. In order to diagnose the starter circuit, you must start with a fully charged battery, 12.5 volts or better and be able to pass a proper load test if necessary. The battery cables and terminals must be clean and tight. The "NEGATIVE" cable is famous for corroding and or breaking inside the harness, check the connectors at both ends. Check your starter relay with a test light for continuity, it could be faulty due to corrosion and sticking in a closed configuration, another claim to fame. Finally, there is the starter solenoid, low battery voltage or faulty battery connections will cause extremely high amperage at the plate and contact shoes and rob the hold in coils of much-needed voltage. In extreme cases, the solenoid plunger plate will literally weld itself to the contact shoes, keeping the circuit closed and thus permanent engagement. Another scenario is unacceptable voltage drop to the starter solenoid from the ignition switch to the starter relay to the starter button, and finally to the solenoid. Remove the green wire from the starter solenoid and hook up the positive lead of your voltmeter to the green wire connector and ground the negative lead. Turn on the ignition switch and depress starter button, the voltage reading should be no more than .5 volt less than the battery voltage. If it is more than .5 volt you need to backtrack that part of the circuit with your voltmeter until you find the voltage robbing offender. Next, remove the 3 screws that secure the solenoid cover and remove the plunger, dress the plate and the contact shoes of arching residue and make sure the contact shoes are tight and secure. If you have done all of the above, replace the green starter button wire, hook up your voltmeter to the battery and check the voltage drop when you start the engine, anything below 9 volts could indicate a faulty battery and a proper load test should be performed. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Yamaha R6 Forum YZF R6 Forums View Single Post Does your R6 make noise...
Starter staying engaged
2008 2009 Yamaha YZF R6 Service Manual R6 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Mar 09, 2014 | Yamaha YZF-R6 Motorcycles
Unit cuts out on engine start
will not enter navigation.
Jul 16, 2013 | Furuno GPS
My yamaha htr-5640 receiver will turn on for a sec then a small click and then shuts down....no speakers hooked up....what is the deal?
With the power off, try to disconnect every component and then power on the receiver. If it still shuts down, then it is an indication of an internal error and the unit needs to be serviced.
Regards,
Yamaha Support
Nov 28, 2011 | Yamaha HTR-5640 Receiver
On an 1100 V star why would the charging system work perfectly for about 10 min. then quit charging. I charged the battery, checked the voltage had 13.72 volts before start up. apon turning on the key...
first thin is to clean up all contacts neg and pos, coild be one is loosing contact due to heat, nest step is monitor cahrge rate at alternator when drop occurs , if so then it is probably internal
May 15, 2011 | 2001 Yamaha V Star 1100 Classic
Im trying to get my bike ready to ride The charger says that the bike battery is charged but I still cant get it on no lights and the horn does not work. i have no gas in it either please advise
Ensure battery cables are clean and tight,
Check that the main fuse is intact...should be close to battery.
Hook up a voltmeter to battery and monitor voltage when you turn on the key and press starter button. If voltage dives down, battery is bad. No change in voltage....incomplete circuit....main fuse, ground cable...etc
Mar 05, 2011 | Yamaha V Star Classic Motorcycles
Yamaha 115 will not shut off with key or kill switch
not enough information on the motor. what year and model? but all yamaha outboards are shut down by the C.D.I. being grounded by the key switch or the emergency kill switch. the cheapest thing to test or replace is the key switch and the emergency kill. with more info on engine I can help you further.
Sep 23, 2009 | Light Outboard Motor Boat Bass Fishing...
Will not turn on.
It has an internal problem. Just received an RX-V2600 back from service for the same issue. It took a voltage drop then a spike. It takes out 5 caps and a few other parts. The repair will run roughly 250-275 depending on who does the service. Hope this helps
Aug 14, 2009 | Yamaha R-V905 Receiver
Replace AC fan motor now car doesnt turn over right away.
You can try this to verify that the starter is good or bad.
Starter Testing Starting System Voltage Drop Tests NOTE: The battery must be in good condition and fully charged prior to performing this test.
There are three area of the starter motor circuits that voltage drop test can be performed on. These include:
  • The starter feed circuit
  • The starter ground circuit
  • The starter solenoid.
Starter Feed Circuit
  1. Disable the fuel system by removing the fuel pump fuse or the fuel pump relay.
  2. Verify that the vehicle will not start.
  3. Connect the positive lead of a voltmeter to the positive terminal of the battery.
  4. Connect the negative lead of a voltmeter to the starter B+ terminal.
  5. Turn the ignition key to the START position and note the voltage displayed on the voltmeter.
    • Ideally, there should be no more than 0.1 volt drop for each connection displayed on the voltmeter. No voltage should be consumed by the vehicle wiring
      1. If the battery cable connects directly to the starter motor there should be no more than a 0.2 volt drop measured
      2. If the vehicle uses a starter solenoid between the battery and the starter motor terminal there should be no more than 0.4 volt displayed on the voltmeter
Starter Ground Circuit
  3. Connect the positive lead of the voltmeter to the case of the starter motor.
  4. Connect the negative lead of the voltmeter to the negative terminal of the battery.
      1. If the battery cable connects directly to the starter motor there should be no more than a 0.2 volt drop measured.
Starter Solenoid
  3. Connect the positive lead of the voltmeter to the case starter B+ terminal.
  4. Connect the negative lead of the voltmeter to the lug (the starter M terminal) that connects the starter solenoid to the starter motor.
    • Ideally, there should be no more than 0.2 volt drop across the starter solenoid displayed on the voltmeter.
In general, there should be no more than a 1.0 volt drop throughout the entire starter motor feed and ground circuit. Any voltage drops measured in either the feed or ground circuits after connections have been cleaned will require replacement of the affected battery cable. Typically, any voltage drops measured in the solenoid are repaired by replacing the starter motor.
I looked at all the steps for replacing the blower motor...they should not have messed with anything that would have affected the operation of the starter.
Apr 02, 2009 | 1999 Toyota Corolla
My 98 S10, stop and don't start anymore. the compression test is ok,but no spark....and the fuel pump have no power...that means 12 volts is interrupted in some place....but where????
first check the condition of all circuit wiring for damage. Inspect all connection to the starter motor, solenoid, ignition switch, and battery, including all ground connections. Clean and tighten all connections as required
next
Check the voltage drop between the negative battery terminal and the vehicle frame by placing one lead of a voltmeter on the grounded battery post (not the cable clamp) and the other lead on the frame. Turn the ignition key to the START position and note the voltage drop.
Check the voltage drop between the positive battery terminal (not the cable clamp) and the starter terminal stud. Turn the ignition key to the START position and note the voltage drop.
Check the voltage drop between the starter housing and the frame. Turn the ignition key to the START position and note the voltage drop.
If the voltage drop in any of the above is more than 1 volt, there is excessive resistance in the circuit. Clean and retest all cables not within specification. Replace as necessary.
let me know what happens
Mar 06, 2009 | 1984 Chevrolet S-10
Furuno GP7000F/NT GPS Receiver Logo
20 people viewed this question
Top Furuno GPS Experts
Steve
Steve
Are you a Furuno GPS Expert? Answer questions, earn points and help others
