Frigidaire AC Control Knob 3093070 - Heating & Cooling
3 Suggested Answers
ngfam1
  • 639 Answers
SOURCE: Frigidaire PS417831 Timer Knob Assembly
Dear etgt3,
ngfam1 here for you!
I am happy to be of assistance!
I believe you should use service for this particular situation!
It sounds like you will may cause it to cost you twice!
once trying and once to pay service!
Here is a good service that I recommend to my customers,
in our 65 year old appliance business!
A&E Factory Service
1-800-905-9505
They are open to make appointments 7days/24hours
A&E is factory authorized service for most brands!
Including warranty work!!!
They will help you, and all will be well!
You will be fine now!
Thank You
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
machinetech7
  • 1344 Answers
SOURCE: frigidaire find temperature control knob
I believe the cold control is located inside near the bottom more so in the middle right area. You made need to take some shelves out to get to it.
Posted on Apr 29, 2012
Testimonial: "Yes. thank you, Had to bend down to actually see it since the shelf was obstructing its view."
Temp control knob loose on old Frigidaire oven
my best guess its A Frigidaire wall oven, circa 1966-1970,
unsafe to use at any time if the temp controller trips the circuit breaker
could be the oven thermostat causing the trip as well
if Frigidaire are still in business
You will need to ask an electrician to fit a /tested used controller or new superseded part temp controller and knob
Oct 11, 2016 | Frigidaire Ovens
Where is the control knob for Frigidaire upright freezer Model No FFU20FC4AW2
It is on the back wall, about 2/3 of the way to the floor on the right hand side... Knob will look like this: Frigidaire Freezer Control Knob 216707200
You probably have food in front of it!
Jul 31, 2016 | Frigidaire Freezers
How to replace the knob and stem on a frigidaire range?
Stem is part of control switch need to replace control .....
Knob is probably fine, just pull out shaft from knob use old knob on new switch as long as plastic knob is not broken
Aug 12, 2014 | Frigidaire Kitchen Ranges
How to replace frigidaire gallery washer knob?
Good afternoon friend, that's a great question!
I understand that you are trying to replace the selector knob on your Frigidaire washer, GLTF2940E. Normally this is not a DIY job and we would recommend having a technician come out to the home in order to properly disassemble your front panel and replace the selector knob as needed. Hope this is helpful. -Matt
Jul 29, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire find temperature control knob
Apr 28, 2012 | Frigidaire 12.1 Cu. Ft. Upright Freezer -...
2002 Toyota Highlander AC main control
Before tearing out the AC control, does the temp knob feel loose or wobble alot more then the fan knob? If so pull the temp knob straight off. Look at the small nut around the shaft the knob came off of. Its common for them to come loose. Just tighten it up some and reinstall the knob. Your temp will work normally now.
This fix is for the manual system not the auto ac system.
Mar 28, 2009 | 2002 Toyota Highlander
Dash Control Unit Replacement
You can save a LOT of money by fixing it yourself.
All that is wrong with the knob are broken wires from the knob's PC board to the main PC board on the AC control.
All you have to do is remove the AC main control, take it apart, and resolder the broken wires from the PC board with the knob on it, to the main AC pc board. There are 3 wires, any number could be broken.
If you take it apart and solder the broken wires, this WILL fix your issue. Just make sure you put the wires back exactly where they go.
A FIXYA rating (4 blue diamonds) would be most appreciated for my assistance.
Mar 21, 2009 | 2002 Toyota Highlander
My 1992 Frigidaire Elite stove has locked itself, how do unlock it?
1-turn oven control to lock
2-push in and turn the stop dial knob to set a cleaning time of aprox. 1 hour
3-push the start dial knob in . this will make the locking mechanism to operate (wait 15 seconds)
4- turn the stop knob back to the"0" setting on the cleaning dial. the knob will pop out waight 15 seconds to allow the mechanism to unlatch the door
5-open the door
6 push the stop dial in to return it to the manual position
7- turn the oven control knob to off
8- close door.
basically your just repeating a cleaning cycle to reset the lock mechanism
Sep 01, 2008 | Frigidaire Kitchen Ranges
Thermostat set to low.
If your A/C has a digital control panel no screw driver is necessary to reset the temperature.
http://www.frigidaire.com/products/
resultspage.asp?strmodel=FAA065P7
The above URL will take you to the site to download the owners manual for your model number stated.
May 11, 2008 | Frigidaire Compact Air Conditioner
Heating & Cooling Logo
267 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
