Question about Altec Lansing - Pc Multimedia Speakers- Gcs100
HOW TO REPAIR GCS100 SPEAKERS - Altec Lansing - Pc Multimedia Speakers- Gcs100
I have the speakers S125i of logitech, but there is a piece that is loose inside of the speakers, at the begining the speakers sounds well, but then the left speaker stoped working. I think I'm able...
The Logitech is a little tricky. You need to carefully pry off the white bezel around the speakers and then pry away the grills. Under the grill you will find four screws holding the two speakers, and four screws set deep in holes.
Undo these eight screws and the front will come off.
Jul 20, 2011 | Logitech S125i
My creative speakers woofer is damege plz repair woofer.
sir I am using 2.1 creative inspire speakers system, at present no sound is coming in the speakers or woofer, what is the problem.
power is on and after connecting the speakers to woofer from pc no sound is coming. what is the problem. please help me. thanks rajanna
Jun 01, 2010 | Creative Labs Inspire 6600 Computer...
Speakers worked fine for a year and now no sound at all
your speakers transformer is getting problem
so change the part of your speaker
from repair shop
then try
ok bye..............
Nov 11, 2009 | Bose Companion 3 Computer Speakers
I have a set of tamon studio monitor speakers with 24 inch subbies the rubbers around the subbies have pearished can i fix them. The speakers are 23 years old.
I have repaired speaker surrounds using repair kits from an internet company- 'Simply Speakers .com" The repair worked 100%.
I do not know if they have a repair kit for those 24" subs, but ask. ( wow -24" subs!).
If this info helps- please rate. Thanks...
Jun 25, 2009 | Audio Players & Recorders
Jl audio w6 surround repair
If you're willing to do the repair yourself, there is an Internet site - Simply Speakers -that sells repair kits for speakers ,including speaker surrounds.
I did two 10" drivers and it worked 100%. ..
Jun 05, 2009 | Jl Audio 12W3 Car Subwoofer
Radio is on, but no sound. 2003 Olds Silhouette.
I had avery similar problem with my radio. At first I would lose audio but it would eventually come back. Then I lost it for good. I replace the radio and that work for a bit and then replaced the speakers and they worked for a bit. Eventually no audio. I took the radio and speakers back to the tech who installed them and he found a short in the speaker wiring to the passenger speakers. He installed a jumper around the short and the new radio and speakers worked fine. Then I had him put in the original raidio and speakers and have had audio ever since.
Doug Crail
dscrail@yahoo.com
May 18, 2009 | 2003 Oldsmobile Silhouette
Bose 901 Series IV BLOWN?
Yes, if you hear any sort of crackling sound, that means it has blown. Given the cost of these units, I would suggest repair. I would also suggest contacting Bose, as many of their products have a lifetime warranty, so you might be in luck. Although, blowing your speakers because you made your speakers go louder than they were supposed to, is no covered in the warranty.
You can approach the repair in 2 ways..
1) Send in to Bose for repair - suggested
2) Take it to a service center, and see if they will be able to recone the speakers or replace. Most service centers are familiar with the 901 series, so you should be ok. If they have no idea what your talking about, stay away.
But yes, they are worth fixing.
- OPTiC
DJ & Pro Audio Repair
Jan 17, 2009 | Bose 901 VI Main / Stereo Speaker
Amplifier has blown supplied speakers and I need to find someone to repair the amp and repair/supply replacement speakers
It would help to know where you are located and what the receiveer and speakers are.
Thanks,
Dan
May 21, 2008 | Audio Players & Recorders
Altec Lansing - Pc Multimedia Speakers- Gcs100 Logo
70 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
