Home | Bosch | 24 in. SHU66C05 Stainless Steel Built-in Dis... | Bosch dishwasher = mac...
Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher
Problem for Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher
Bosch dishwasher = machine on but no water, so the
By paulernest12 on Mar 29, 2009
bosch dishwasher = machine on but no water, so the lower basin has water in it and because of it the FLOOD CONTROL SWITCH IS ON, so how do I drain the rest of the water so the FLOOD CONTROL SWITCH goes off? A plastic cover with a seal is stopping me from drain the water below?
Solution #1
posted on Mar 29, 2009
Not Rated)
mark_37388
Rank: Guru
Rating: 92%, 74 votes
If you can see the water use a shop vac if not you will have to pull the unit out and remove the left side panel after removeing the water you will need to find the leak that caused the bottom to fill with water
Was this helpful?
Yes
No
Popular Solutions for Bosch 24 in. SHU66C05
Questions and Unsolved Problems for Bosch 24 in. SHU66C05
Do you recommend Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher?
Answer
Answer
I found that by initially disconnecting the pipes and cleaning them out (without the usual... (More)
Answer
our bosch dishwasher had some water on the floor . I think it's coming from the bottom seal of the... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch 24 in. SHU66C05...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
