Kenmore dryer does not turn on, no power.
We bought a used kenmore front load washer and dryer, model #402.89032010. my brother inlaw was here to help unload. we discover we don't have an outlet to plug the dryer cord in but rather the wire was just direct. He said he could make that work so we let him try. Stupid idea!!!! He didn't hook up the wires correctly,, he turned the power button on, the dryer turned on but then shut off he turned it on again it made a loud noise and got really hot, bad smelling and died. We haven't been able to turn the dryer on since. How do we determine if we fried the motor or not? Is it worth replacing? Please help!!
Buffalo12980
  • 625 Answers
SOURCE: used kenmore stackable washer and dryer P/N 145781-000A
was the machine working when you bought it? if there's 240 available, then a problem is in the machine NOT your wiring. both motors, the dryer and wash motor may be 240 volts OR 120 volts - a hot leg to ground. the feeder should be a four wire because the white is the neutral and the ground an equipment ground. at the panelbox both the equip gnd and white terminate at the neutral bus.
Posted on Sep 12, 2007
SOURCE: kenmore Front load washer model
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Posted on Aug 30, 2008
SOURCE: Kenmore front load washer
I had the same problem and it went on few months. Then the final spin didn't work and I could smell something buring. Called AHS and they sent a tech, who said it was the bearing. Cost about $350. to fix. Will be replacing the washer soon, I don't think we paid too much more than this at the scratch and dent place.
Posted on Sep 06, 2008
SOURCE: Kenmore Commercial washer 110.20172001
Sounds like motor is bad. See if you can find the 2 main wire leads on the motor and hook up directly to see if you can get it to work.
Posted on Mar 05, 2009
Karthik316
  • 187 Answers
SOURCE: loud noise kenmore washer
  • Hi,
  • try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
Posted on May 22, 2009
Kenmore 417 44042400 Front Load machine Sears says does not exist
YOU ARE ABSOLUTELY RIGHT. THE COMPANY SHOULD HAVE KNOWN ABOUT THIS. HERE IS MY SOLUTION: GO TO LOWE'S HARDWARE AND BUY A WASHER AND DRYER THERE. BUY THE GE BRAND. 3 YEARS AGO, WHEN OUR MAYTAG WASHER DIED, WE BOUGHT A NEW GE WASHER BEFORE MY FATHER DIED IN 2006. BUT CHECK INTO THAT. MY E MAIL ADRESS IS CoolRod41@yahoo.com IF YOU FIND THIS IMFO HELPFUL. GOOD LUCK.
RODNEY
May 17, 2009 | Kenmore 43042 Front Load Washer
Model 417.43042200 Kenmore Washer
I HAVE A KENMORE FRONT LOADER WASHER. MODEL 41743042200 AND IT MAKES A NOISE WHEN IN THE SPIN CYCLE, THIS ONLY HAPPENS WHEN SPINNING. CAN SOMEONE HELP
Apr 23, 2009 | Kenmore 45081 Front Load Washer / Dryer
I need a manual for a Kenmore washer, model # 1102708604.
I have now got the manual for the Kenmore Elite washer and dryer coming in by mail. I had gone to the local Sears store and then to the service center close to home. The service center was able to find the manuals and order them for me.
Thanks for your help.
Cecil
Apr 10, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Where is the model #on my Kenmore stacked unit?
possible locations
Top- or front-loading washer-dryer combination unit
  • Inside the dryer door, on the door frame
  • On the top of the dryer
  • On the side of the washer, near the bottom, front
  • Under the washer lid
  • Feb 13, 2009 | Kenmore Washing Machines
    Kenmore 3.5 HE front load washer went haywire, doesn't work now..
    Yes - the ECU is to blame, and is a common failure with this unit.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Jan 14, 2009 | Kenmore 43042 Front Load Washer
    Screeching Kenmore front loading dryer
    There is a hub and bearing that needs to be replaced you will need to have this serviced by a qualified tech. The whole front of the dryer has to come off and the basket needs to be removed.
    Jan 05, 2009 | Kenmore 94872 Front Load Stacked Washer /...
    Kenmore elite front loading wash & dryer-5 yrs old: should i buy?
    all kenmore named washer will have 110 as first 3 digits of model #..the he washers are usually good washers..like all front loads they have their quirks ..if you read reviews from other consumers they indicate problems ..most of which are easily remedied by reading owners manuals..mold /mildew usually a bleach clean every few months ..vibration need real solid floor..oversuds use HE detergents only..just a matter of changing mind set from top loads with 25 gals of water each fill to a front load with 5-6 gals each fill..top load with 750-850 rpm spin speed to front load 1000-1200 rpm ..if willing to learn proper use and what to expect they can best investment..just don't let opinions of those unwilling to adapt affect your decision
    Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
    Front load dryer
    Read the instruction manual carefully. If you are certain it isn't working as it should then don't hesitate and tell the supplier it is faulty and to send a replacement or give a refund.
    Sep 24, 2017 | Kenmore 94802 Front Load Stacked Washer /...
    Washing Machines Logo
    27 people viewed this question
    Top Washing Machines Experts
