Question about Vornado Silver Swan Table Fan
Vornado FAI 0013 bearings
I think the bearings are shot. We took it apart and oiled it. Problem still not resolved. Fan blades when manually turned are seized. Turning motor on results in very imperceptible movement of fan blades gradually picking up speed. Are the bearings available for installation (to buy)? Hate to throw this fan out.
2 Suggested Answers
SOURCE: Vornado fan Model CR1-0023 ,
I have had the same model for almost ten years, and have had to lubricate it twice - both times when the fan stopped rotating. It's obvious that Vornado never intended the bearings to be serviced, but if you're patient, it can be done. You must remove the front louver section (press the three clips inward gently). Then firmly pull the fan toward the front, off the shaft. Then remove the four nuts on the front of the motor housing - you'll note that the bolts appear to be free-floating, but that allows re-assembly after the bearings are lubricated. When the nuts are removed, firmly pull the front of the motor housing toward you. This may require a firm pull or GENTLE prying, as the rear bearing sometimes doesn't want to let go. When you have the front portion of the housing and shaft out, hold the housing and pull the shaft out of the front bearing. Again, this may require a steady firm pull straight back. When the rotor & shaft are free, you'll need some very fine emery paper to remove the varnish that's built up on the shaft (it's unmistakable where to clean the shaft.) And I never attempt to do anything with the front and rear bearing themselves - too much work, and cleaning the shaft does the job for me. Then clean everything up carefully and lubricate the shaft where it enters the bearings (and maybe a drop in the rear bearing itself.) I use a very fine machine oil that I bought at Sears, but I think any good oil would work. Then, it's re-assembly time - shaft into front bearing, shaft into rear bearing as the motor housing is put back together (lining up the bolts), four nuts on the bolts & tighten (firmly, no gorilla), press fan back on shaft (don't force it too far on - it'll stop when it's in the right place), plug in and check, re-attach front louver (just press - the clips will snap easily into place.)
Posted on Jun 22, 2013
Fan sweaks, is it a bearing?
Vornado makes several fan models. Whether yours has ball bearings, sleeve bearings or another type is unknown. Most manufacturers of consumer grade fans use "permanently lubricated bearings" and require no additional lubrication by the owner "for the life of the fan".
If yours does accept lubrication, you should find a "filler neck" at the front and rear of the motor housing - directly over the motor's shaft (that the fan blade is attached to). A few drops of a light bodied machine oil in each should quiet the squeaking sounds (if coming from the bearing). If there is no such filler neck on the fan, you could unplug the fan and rest it on its back - fan aimed straight up. Squirt a couple drops of oil on the shaft - close to the motor. Because the fan is pointed straight up, gravity will draw the oil down the shaft into the bearing. You may not be able to access the shaft at the rear of the motor without some dis-assembly however. You should not attempt dis-assembly if you're not sure how to go about it. After the oil has run into the bearing, you should spread out newspaper or rags under the fan(or better yet - brought outside - before powering it on, as some oil may be cast off the shaft if it spins fast enough or if there was an excessive amount of oil applied to the shaft.
I hope this helps & good luck!
Jul 28, 2012 | Vornado Circulating Fan
Vornado fan Model CR1-0023 , Type 750 I bought this fan used 3 days ago. Seemed to work fine but not as powerfully as another new Vornado shop fan I have. Today the fan blades stopped turning. I can...
Jul 27, 2011 | Vornado CR10023-06 Air Circulator Fan
My Vornado VH2 heater stops heating several moments after switching on. The fan runs but no heat. The heating elements never get hot but all the wiring appears to be firmly in place. The tilt shutoff...
A big problem with these heaters ans well as others is the motor driving the fan. The bearings get stiff from dirt and do not spin fast enough activating the over temp device of the heating element. Check the motor out by placing the unit in fan mode them pull the plug or turn off looking at the fan to see how many revolutions is makes with no power applied. It should rotate like five times or more indicating freeness. If it hals to a stop immediately after power is removed the motor bearings are tight.
If your handy you take apart and oil the shafts using 3inone motor lube. Clean the motor of dust and dirt drop a few drops on the shafts near the bearings then work it in by hand rotating the blades. Do this a few times reassemble then ler ripp!!!
Feb 15, 2011 | Vornado VH2 Compact Heater
Fan is making squeeling noise when running.
After reading dozens of similar problems on here about the Vornado fans squealing (and rattling) it seems they are in need of some 3-in-1 oil for the bearings and any moving parts in and around the motor area.
Also good to keep the fan clean by wiping down and removing front grill and the fan blade...A high pressure duster or spray air canister for the motor body etc. should get out any dust inside the unit.
good luck!
Oct 19, 2010 | Vornado 785 Stand (Pedestal) Fan
The fan has quit on my Vornado VH2 portable heater.
take apart the heater clean the bearings, and oil the shaft around the berings lightly with all purpass oil
Jan 19, 2009 | Vornado VH2 Compact Heater
I have a Vornado VH2 portable heater. The fan has quit working.
generaly a problem like this ocures because of gummed up bearings
1.take apart heater
2.remove fan
3.wipe of bearings
4.lightly oil bearings and shaft around bearings ## TO MUCH OIL COULD POSE A FIRE HAZARD :0
5.asemble
6.test
Motor stopped
hi,
you can try and oil it, unplug it and begin taking it apart, your destination is the fan motor, dust around the motor and I would recommend using regular automotive 10w30 motor oil on that motor, put some in a small bowl and use a small baster or equivalent and oil around both ends of the motor shaft(where it protrudes from the motor) behind the fan blades and behind it, look closely with a flashlight where the motor attatches to the back guard. try get some oil in there and within the motor housing to the inner bearing areas if possible. My guess is that its sealed from the factory, but you can try, those fans are the best on the market and have a long warranty, heres a link to the manual
http://www.vornado.com/manuals/allcirc.pdf
J
Aug 05, 2008 | Vornado Circulating Fan
Motor problem
hi,
I wrote to a person earlier about oiling one, now Im thinking she may be having the same problem you have, I will paste that info at the bottom, but sounds like your fan blade assembly has come loose and/or worked its way back down to the motor, study the fan blade assembly and look for an allen bolt or ring holding the assembly to the shaft, remove the ring or loosen the allen bolt , adjust the fan blade assembly so it doesent bind, oil the motor with regular 10w40 motor oil and dust the fan, these are good little fans and that company has been making those since the40's, also sending user guide link.
J
Aug 04, 2008 | Vornado Circulating Fan
Vornado Silver Swan Table Fan Logo
70 people viewed this question
Top Vornado Dryers Experts
Steve
Ian Summerfield
Ian Summerfield
Mack Baxter
Are you a Vornado Dryer Expert? Answer questions, earn points and help others
