Question about Garden
Ariens 911052 self propel isn't working
  • 7 Answers
SOURCE: yardman push mower self propell not working
check to see if it is belt or gear driven
Posted on May 02, 2009
panilling9
  • 284 Answers
SOURCE: Self-propelled doesn't work
remove plastic cover to access drive mechanism
check belt and remove debris and try again
Posted on May 26, 2009
#1 Taper
  • 1041 Answers
SOURCE: SELF PROPELL NOT WORKING GOOD
Have you checked the belt that drives the wheel? This is more than likely the problem. It may be broken.
Jim
Posted on May 30, 2009
SOURCE: Honda lawn mower, self propelled mechanism not working
check the mechanism first before changing the gearbox its possible that the cable might jump out from the pulley or the cable is worn out or its possible that the gear on the tire is worn out to if not then that would be the time for you to change the gear box it would be hard to change it if you don't have the right tools to work on it if you know how everything work its not that hard to replace it just make sure were everything goes memorize the parts before disassembling cause that would be you guide to reassemble it...goodluck
Posted on Aug 16, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Ariens A173K22 self-propelled. Fill up before
Your engine is flooding because you probably have some debris under the inlet float needle valve causing the carburetor to flood as you described.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
How do I replace the rubber friction ring on a ariens self propelled mower
you should have a dealer do it. because it will need to be adjust to the new friction ring. or you'll wear out the new one prematurely
May 27, 2016 | Ariens Garden
How can I get a airfilter for a Ariens model 911077
Generally you can get away with a different brand that shares the component. Just take in the old one to compare when you purchase. They need to be the same size.
Jul 19, 2014 | Filter Queen Defender Air Purifier
I have an Ariens self propel mower model # 911016.I think it runs hot. It sounds to me like it is racing?
should be a cable connected to the handle, might be reversed or could of been snagged causing it to give you this issue
Apr 14, 2014 | Ariens Garden
Just bought a self propelled toro, model #120000. Used it last weekend and tried to use it again this weekend. The self propelling part isn't working. There's a bit of a grinding sound, but it...
It is possible that the scews and/or latches for the cover will be accesible UNDER the deck where the blade it. Have someone tilt it back while you check and/or hold it for you while you removes the retainers and screws. If the unit IS defective, I suggest you take it back as the Toro should be warranted.
Sep 11, 2011 | Toro Power Lawn Mower
Craftsman 6.75 self-propelled...This is for a friend of mine. She has a broken arm and her mower will not operate as it should. The self-propelled function is not working. She spoke with someone who...
The self propel lever is the bottom one, the top one is the running lever. Have her check the cable coming out of that one. var geo_Partner = '1890d1e7-e721-4f9c-b474-1a19eda23e94'; var geo_isCG = true;
Aug 06, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Wont start, have cleaned the carb, new filter, new spark plug. removed plug and grounded. Very tiny little sparks, not real single snapping spark. Any idea of what could be the problem? Ariens model...
I believe you have a timing problem. Do you remember hitting something hard with your blade? I would say you have sheared your timing key. Order of repair : remove top cover to engine, this may involve gas tank, gas line, oil filler tube. Remove flywheel nut, remove flywheel. Timing key is the small key between flywheel and crankshaft. Timing key may just be dented but it will need to be replaced. Bring it with you, Tecumseh has a few different styles of key depending on engine and year.
GOOD LUCK.
Jun 12, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
Unknown Spring on Ariens Walk Behind Mower (1980's)
there is a hole in the top of the governer it goes in there
Jun 23, 2010 | Ariens 21 In Classic Walk Behind Push Lawn...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
