Question about Brother MFC-8460N All-In-One Printer
Mfc 8450n please wait flashes continuously
After sending a fax it started flashing please wait. Turned it off, unplugged it , will not clear the error message.
Mix-it-up
  • 832 Answers
SOURCE: Brother MFC-210C stuck in "please wait maintenance"
Press menu then start mono (b/w) then 4x arrow-up-button. Machine will be in maintenance-mode: What error code does the display show off?
Posted on Sep 24, 2007
ctf1800
  • 4402 Answers
SOURCE: fax memory
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/000100/000095/faq000195_006.html?reg=us&c=mx&lang=es&prod=mfc420cn_us&Cat=11&ot=us_ot
Posted on Dec 18, 2007
SOURCE: Document Jam Error Message on Brother MFC-8660DN
I had the same problem with a Brother MFC-8460 and called Brother's support line. The solution that worked for me was to lift the top cover where the sheets of paper go through when you fax. On the right of the black rectangluar piece with grey roller there is a slot in the tray with a black lever inside. The black piece was stuck down inside the slot and had to be popped back out. Once it was out I hit the stop button and it was fixed!!
Posted on Apr 24, 2008
SOURCE: Error message 50
Confirm Success on a 440CN
1) Remove Plastic wire covers from inside printers, and release plastic stay on lower edge, tilt cover to 90 Degrees
2) make a note of where each connector goes
3) release the Ribbon and 3 Multicore cables, removing grounding screw, then remove scanner module by sliding it off the hinges at 90 degrees.
4) Remove Three Front Panel Screws, carefully leaver front panel upwards releasing front side clips.
5) Remove front panel by disconnecting ribbon and wireing on both sides.
6) Remove 6 Screws (2 on back, three at front and one middle right
7) Carefully remove speaker cable (Red Connector) and lift up plastic casing, leaving printer uncovered.
8) Re-Seat Encoder Strip into guide. (The Transparent strip)
9) Re-assemble in reverse and Hey Presto.
All Cured. Hopefully!
Posted on Aug 04, 2008
Healeyman
  • 1198 Answers
SOURCE: have voip and brother mfc 7420. error code 2001 and 2006
Get a new phone wire. Put a phone on the line and listen for static. Too many phones on one line will cause problems. If the phone line is going thru a surge protector, check the quality of the sound with it and without it, it may be damaged. Keep power wires away from phone wires, they cause static.
Posted on Apr 26, 2009
OUT OF MEMORY TRYING TO FAX
<Fax sending or copy operation in
progress>
Do one of the following:
- Press [Start] key to send or copy the
scanned pages.
- Press [Stop/Exit] key and wait until
the other operations in progress finish
and then try again.
- Clear the data from the memory.
<Printing operation in process>
- Reduce print resolution.
- Clear the faxes from the memory.
Apr 02, 2014 | Brother MFC 8950DW
Clearing fax numbers from my brother mfc 8220 printer
press menu*2864, display will flash, then enter 01 on the keypad,wait 30 seconds and then press 99 on keypad, machine is now returned to factory settings
Nov 20, 2011 | Brother MFC-8220 Fax
"Please Wait" flashes continuously. Cannot
I was wondering if you found a solution for the "please wait" flashing. Mine started doing this today, last night it played a blue-ray fine then I turned it on this morning and all it does it starts to turn on and then just flashes "please wait". Mine is also about a year and half old.
Aug 27, 2011 | LG BD390 Blu-Ray Player
Fax automaticaly daling #365 etc like tha number how can reset my MFC 7450 printer
Found this here...
(For MFC-7420)
When you turn off the MFC's power switch its memory will be cleared. To check
whether the MFC has faxes in its memory see Checking if the MFC has faxes in
its memory on page 11-5. If there are faxes you need to save them before following
the suggestions below (See Transferring faxes to your PC on page 11-5 or
Forwarding faxes to another fax machine on page 11-5).
Turn off the MFC's power switch and then turn it on again. If the error message
continues, leave the MFC for several minutes and try it again.
Check the settings in your application software to make sure it is set up to work
with your MFC.
(For MFC-7820N)
continues leave the MFC for several minutes and then try it again. (The MFC can
be turned off for up to 4 days without losing faxes stored in the memory.)
Looking through this manual, this is the only solution that I could find. There are options on the 7820N model in the menus that will allow you to reset the printer itself, and i quick search through the above link for "printer reset" should bring you to the menu selections for that.
Jun 29, 2011 | Brother MFC 7420 All-In-One Laser Printer
My brother mfc-490cw I can't send or recieve faxes.
According to the User's Manual for the Brother MFC-490CW:
  • Poor Line Connection indicates an issue with your telephone line (Page 136). If you are sharing the fax line with any splitters or computers, try connecting the MFC-490CW directly to the phone jack and send a fax. If you are still getting a Poor Line Connection error message, call the telephone company and have a repair technician check your telephone line.
  • Out of Memory error message means the machine's memory is full (Page 138).
    Try pressing Stop/Exit and wait until all current operations finish and try again.
    Try clearing the data in memory. To gain extra memory space. turn off Memory Receive (See Page 48).
    Try printing the faxes that are in memory (See Page 49).
  • System Busy error message wasn't in the manual, but I suspect it means there's a current operation in progress and the machine needs time to finish before moving on to another job. Just wait for the current job to finish, then try again.
May 05, 2010 | Brother MFC 490cw Color Inkjet...
CHECK CARTRIDGE
when trying to copy or receive a fax machine will flash printer error and send out blank page i replaced the ink cartridge and blue air tho it but nothing seems to help
Oct 03, 2008 | Sharp INKJET FAX UX-A1000
Machine error 41
Machine Error 41 indicates a mechanical malfunction with FAX/DCP/MFC.Often, unplugging the unit from the power source and then plugging it back in again can clear this error message.If the message continues to be displayed on the LCD, please contact YOUR PRINTER Customer Service for more options.
Sep 16, 2008 | Office Equipment & Supplies
Panafax UF-7100 showing install developer
Unplug power / plug back in.... NoGo? try this:
Function
7
press monitor key slowly 4 times
6 (RAM INITIALIZE)
scroll down to CLEAR FLASH MEMORY
set (wait for reboot)
If that doesn't work, scroll down to ALL JOB CLEAR and set.
Last resort....
scroll down to SHIPMENT SET
set
2 for no
Did the developer problem go away?
Sep 08, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Problem with my fax Machine MFC 420CN
You can cancel a fax job that is stored and waiting in the memory.
1 For MFC-210C,
press Menu/Set, 2, 5.
For MFC-420CN,
press Menu/Set, 2, 6.
Any jobs that are waiting will appear on the LCD.
2 If you have more than one job waiting, press ▲ or ▼ to select the
job you want to cancel.
Press Menu/Set.
—OR—
If you only have one job waiting, go to Step 3.
3 Press 1 to cancel.
To cancel another job go to Step 2.
—OR—
Press 2 to exit without canceling.
4 Press Stop/Exit.
That should do it for clearing faxes you dont need you can also print off all the faxes in the memory and I believe that clears it.
Enjoy,
Lee
Jun 12, 2008 | Brother MFC 420CN All-In-One InkJet...
Unable to init.
Error message Unable to Change Unable to Clean Unable to Init Unable to Print Unable to Scan Cause The MFC has a mechanical problem. ?OR? A foreign obstacle, such as a clip or ripped paper, is in the MFC. Solution Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in the memory 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. ?OR? If faxes are present, you can transfer them to another fax machine. Go to Step 3. ?OR? You can forward the faxes to your PC. Please see Transfer faxes to your PC. Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1 Transfer faxes to your PC You can move the faxes from your MFC?s memory to your PC. 1. Press Menu/Set, 2, 5, 1. 2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC. 3. To transfer all faxes to your PC, press 1. ?OR? To keep all faxes in the MFC?s memory, press 2. 4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. (For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
Sep 06, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-8460N All-In-One Printer Logo
146 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
