Question about Xerox WorkCentre Pro 635 Laser Printer
Xerox workcentre pro 635
I bought this machine a while ago second hand and can't seem to lift and replace the codes. I need a free download of the users manual. The one I was given is for another model completely. Thank You
  • 239 Answers
The board on this one may need to be re initialized.
Try, holding menu, + * + #, with other hand, turn on copier.
Holding those buttons the machine should go through a cycle, then come to a ready on the console.
If that doesn't work, a main board might need to be replaced.
Try to unplug the machine, and slide out the main board,
then re installing it. See if that works.
Good luck.
Posted on Sep 15, 2011
  • 39 Answers
Http://download.support.xerox.com/pub/docs/WorkCentre_Pro_635/userdocs/any-os/en/WCP635-645-657_UG.zip
Posted on Aug 28, 2007
SOURCE:
Xerox 657 drum reset instructions
need to replace 1/16 A pick-tale(brown color with strips on it) fuse on blank lamp assembly in drum unit
May 06, 2010 | Xerox WorkCentre Pro 635 Laser Printer
Work centre pro 657 memory error
at right side you can remove cover for the memory, remove it and clean contact, or else you need to replace it.
Apr 12, 2010 | Xerox WorkCentre Pro 635 Laser Printer
I have this machine second hand and I don't know how to scan. The user manual seems to have instructions re scanning missing.
Read the manual
http://www.office.xerox.com/userdoc/PE16I/PE16_Web/pdfs/UserGuide_en.pdf
and download the drivers from official site
http://www.support.xerox.com/go/results.asp?Xlang=en_US&XCntry=USA&prodID=PE16&ripId=&Xtype=download
Jul 12, 2009 | Xerox WorkCentre PE16 All-In-One Laser...
Xerox workcentre pro 412 printer do not work
i changed the usb cable to anthor one Parallel Port
Cable so i think the adapter of usb cable is damaged so now it work.
Jul 06, 2009 | Xerox WorkCentre Pro 412 All-In-One Laser...
My workcentre pro 635 will not print
maybe you should go google and put in the name and then go to where the right printers that it shows or just goto the webseti and download the update and if that dosent worck delete evrithing from your computer an reinstall
Apr 10, 2009 | Xerox WorkCentre Pro 635 Laser Printer
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Vista printer driver for a Xerox Workcentre Pro 635
try this....
http://www.xpvistasite.com/workcentre_pro_635_12490.htm
Jan 04, 2009 | Xerox WorkCentre Pro 635 Laser Printer
Xerox WC Pro 35 - Error 14-563
this code means your scanner has failed to setup correctly. this could be a problem that you would need a qualified tech to service the copier. there is nothing that you can do after you power off and power on (popo) the copier. it could be voltage, pwb board, or a binding scanner assembly.
Sep 21, 2008 | Xerox WorkCentre M118 Black and White...
Xerox WorkCentre Pro 635 Laser Printer Logo
159 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
