Sylvania sytaba848c won't power on - Televison & Video
My sylvania 7" mini tablet won't start up. It only
It may need to be connected to a power source if this is the first tym u have turned it on.
Feb 24, 2013 | Computers & Internet
Sylvania 780 with windows 7 powers on but won't display
My sylvania cl772B turns on and shuts right off. what can I do?
Nov 10, 2012 | Sylvania CL772B 17" Flat Panel LCD Monitor
Sylvania HDTV Model LC370SS8 won't turn on.
u should check std-by volt .when u press power on , the power on volt must not b drop
Oct 09, 2012 | Sylvania LC320SS8 32 in. LCD Television
Have a sylvania lc26oss1 tv it won't turn on what is the problem
Check its main power regulator board. Check fuse. Check and repalce damaged component/s.
Oct 01, 2012 | Sylvania Televison & Video
Have a Sylvania 6727DF TV and it won't turn on tried different outlet different remote checked the transistors I can't find what's wrong even the ohm's r weak on the cord
Contact any experienced service technician. Its main power regulator section has the fault. The work is a skilled one, and not a user repairable fault.
Aug 26, 2012 | Sylvania 6727DF TV
My Sylvania 32" Tv Model #SRT2232S won't turn
Hello
There is a fuse inside the power supply bard of your sylvania TV. Check whether it has blown out. If bllown out, replace it with same type bothe in size and amperage. If the newly inserted fuse also blow up as soon as you switch on the set, make sure that the power supply section has some short circuit in it, and should be cheked well. OK.
Sep 28, 2011 | Sylvania SRT2232S 32" TV
I have a 32" CRT Sylvania Tv that won't turn
Hello
If the TV doesn't turn ON ata all, it is surely due to some fault with its power supply regulator section. You haven't given any otehr details of your tV, than it is only a 32 inch CRT Sylvanial Tv. No model number; so I only can provide you a solution in general.
Check the ON-OFF switch for its contact. Normally, TVs uses DPST type switches [Double Pole Single Throw]. If any one contact amoung them have any problem with its internal contacts, the set won't switch ON. If the switch is OK, come towards the power regulator section circuit board, and check whether the fuse has blown out or not. If it has blown out, replace it with same type and ampere rating. Never use higher ampere rating than specified. The ampere rating will be maiked either on the rims of the fuse, or at the printed circuit board, just under the fuse. After repalcing the fuse, switch ON the TV and see whether it works well or the replaced fuse blows up as soon as you switch ON the set. If the repalced switch burns out as soon as you switch ON the set, the power supply section has damaged [shorted components in it]; and should be replaced.
Normally for LCD TVs it will be good to replace the power supply as card basis. This power regulator card can be bought from most of the electronic spare part shops at your town, orby the authorised service center for Sylvania at your town. If you may have given its model number, I could send you the picture of the power card of your TV. OK.
Sep 28, 2011 | Sylvania 32 in. Diagonal LCD HDTV
My 32" won't turn on
Hello
Without its remote control, you can't unlock this TV. Get into this link from where you can buy it.
www.emtcompany.com/sylvania-srt2232s-remote/rc64.html
The price quoted is $19.95 [Shipping free]
OK.
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
Electro Med Services...
