Error code e-95 on toshiba washing machine aw-d980s.. What does it mean?
4 Suggested Answers
SOURCE: my AW-1170S toshiba washing machine
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Posted on Aug 28, 2011
caroldon
  • 17129 Answers
SOURCE: -I have a Daewoo washing machine DW F1251S with OE error code. What doesthis mean?
Possible this is relative of a poor drain time which means a clogged draining pump and system. So it si best to remove and clean the drain pump/filter and reset.
check if the machine drain hose is connected to a outlet which is not clogged when the water is flushed out . Also the washing machine must be slightly tilted to drain to the pump to reduce the drain timing.
Finally check if the machine was overloaded to produce a strain on the motor so as to give an error. If so shut down remove plug remove load , check if the agitator is jammed and reset.
Posted on Nov 21, 2011
  • 915 Answers
SOURCE: My toshiba washing machine AW-D980S shows an error code E L. what does it mean?
Check drainage hose for blockage.
Posted on Feb 07, 2017
Toshiba washing machine model aw-9771ubb error code e7-4
On washing machine error code e7_4 display and stop
Not working
Nov 10, 2016 | Washing Machines
Toshiba washing machine When I push on the error E7-4 shows and then it turns off what is E7-4 error ?
Is your machine either the Toshiba AW-SD120SM or AW-SD120SS?
If it is I checked the manual and the error code you mentioned is not listed in their operators manual. On page 35 of the manual there is a message that says "As for information display beyond the above-mentioned details, or the above-mentioned solutions do not work, please disconnect the power plug and contact technicians for repair."
The only codes mentioned are: E1 E21 E23 E31 E32 E5 A ans F
Jul 31, 2016 | Washing Machines
My washing machine toshiba aw-9760s Kept showing this "E2 -3" problem. Whenever i close the lid to start washing my cloths. Anyone here can help me? In need of answers A.S.A.P
I also have a Toshiba AW-9790S, and encountered similar problem. The E2-3 would occur sporadically and halt the washing programme. E2-3 error occurs when the washing machine detects that the lid is not properly seated and locked during the rinse or spin cycles. I took mine apart and resolved my problem by cleaning the contacts for the switches. There are 2 contact switches at the lower right side; 1 for sensing the lid is closed and 1 for sensing that the lid lock is engaged. Both the switches were slightly oxidized which prevented current flow and the sensors from working properly.
Nov 02, 2013 | Washing Machines
Toshiba washing machine AW-1160SM error E7-1
my washing maction have a priblem E7 err
Jan 11, 2012 | Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
Nov 13, 2010 | Washing Machines
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
