Question about Refrigerators
Can you put a mini fridge on carpet - Refrigerators
Mini frig has a very small freezer that is not used , is it possible to not it use it as a freezer and incorporate it into the refrigerator
The freezer IS the source of cooling for the entire fridge. You cannot make the freezer into more space for the fridge. Anything you put in there will freeze.
May 05, 2018 | Refrigerators
Why are mini fridge sides getting very warm?
that's normal for that refrigerator it takes the heat from inside and place it on the metal outside of the refrigerator
Appliance 911 Sea Breeze
Jul 30, 2015 | Refrigerators
I actually need to change the light bulb on the reverse light on my 2002 Mini Cooper but need guidance:-)
open the boot anlook at the light cluster you might have to pull the side carpet out of the way when this i done then you can depress the clips and pull the bulb cluster out do not start car just turn ignition on and put in reverse and look for a black or bulb with a filement broken replace with a new 21 watt bulb
Dec 30, 2013 | 2004 Mini Cooper
Can i plug a mini fridge into a surge protector?
you must check the amper ( current) rating as will as wattage of the mini fridge usually at the back portion. if the current and wattage rating of the surge protector is higher capacity so it can hold this fridge.
Oct 02, 2012 | Emerson White Compact Fridge - 1.8 Cu. Ft
Damp carpet in my 1985 mini mayfair?
that means your heater core is leaking
Jan 17, 2010 | 2000 Mini Cooper
My Magic Chef mini fridge temperature trouble
That can be very difficult to do with a mini refrigerator. There is just not enough separation between the freezer and the refrigerator.
You will likely just have to find a compromise setting and accept the results.
Oct 20, 2009 | Refrigerators
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Koolatron Mini Fridge Overheating
Check the condensor fan behind the fridge which is designed to cool the compressor/gas line by blowing air over the condensor. When this fan motor seizes or stops running, the gas gets very hot and because it is skin cooled too, the outside of the fridge also gets very hot. You can overcome the problem temporarily by putting a standing fan behind the fridge, blowing onto the compressor and under the fridge untill you can have the problem rectified.
Nov 03, 2007 | Koolatron Mini Fridge Compact Refrigerator
Refrigerators Logo
98 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
