Question about GE Spacemaker JVM1640SJ Microwave Oven
Jvm1430wd002 I have model # JVM1430WD002. when i close the door the fan and turntable come on before i set a time and start it. it works fine went i start it but the turntable and fan keep running with the door closed. what is wrong with it
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave Will not work
This is usually a bad door swithc or loose or broken door switch mount.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can also find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Nov 18, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave light, turntable, and fan run after the door closes
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally by a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 02, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Advantium 120 fan and tray keep running
Looking at the service manual here, I'd bet that relay number RY6 is shorted on the "sub PC" relay circuit board, or its driver transistor on the main "smart" board is shorted.
Unless your technician does component-level repair, he'll probably want to just sell you a new sub board, or main ("smart") board, or both.
They list for $64.78 and $109.83 respectively here. Hard to tell what they'll mark them up to.
Then add about $150-200 for the labor.
On the other hand, we regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
Or you can tell your technician about our services.
William E. Miller
prototech@usa.net
Posted on Jan 09, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: I have a GE over-the-range
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
So don't let that fool you.
The TCOs you need to be concerned usually with have thick black or white wires only.
If the cavity thermostat needs to be checked or replaced you'll need to pull the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly if you need more FREE help & do-it-yourself advice.
William E. Miller
prototech@usa.net
Posted on Sep 12, 2009
MicrowaveSvc
  • 9085 Answers
SOURCE: model JVM1443 fan runs all the time when unit is
The top door switch (door sensing switch) is defective, or its mount is loose or broken.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If the switch mount is broken, it's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Sep 27, 2009
Fan runs when door is closed and no time set.
Some GE units were starting on their own. I would definitely unplug this oven and call GE to make sure yours wasn't one of the ones being re-called.
Feb 14, 2013 | GE Advantium 120 Convection/Microwave Oven
Magic chef microwave runs backwards with door closed and no time set - works normally when time is set and door is closed - any ideas?
Probably a bad door switch or door switch mount. See help file here.
It's normal for a microwave turntable to run either direction at random. That's common in such AC motors.
Dec 26, 2012 | Magic Chef Microwave Ovens
I have model # JVM1430WD002. Both the under light & ventilation fan are not working. When I press the button, I can hear a click but nothing comes on.
Sounds to me like you main control board is failing. The relays on the board that control the light and fan are closing but the points in the relay are probably burnt and not making contact. You will probably need to replace the main control board. Hope that helps.
Aug 29, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE over-the-range microwave model jvm1430wd002. Nothing works, not even the light nor clock. Fuse not the problem. ????? >ed
William E. Miller
prototech@usa.net
Sep 07, 2009 | General Electric Microwave Oven
Model jvm1430wd002 keypad is locked
This is a built in safety feature called "Child Lock-Out" that allows you to lock or unlock the control panel to keep small children from manipulating the controls.
To lock/unlock, simply press and hold the CLEAR OFF button for 3 seconds.
If you have questions, please let me know. I hope this helps you.
Aug 15, 2009 | Microwave Ovens
WHat part number for this GW Microwave oven thermostat?
It will tell you where each one is located and what it's called, and should have the part numbers.
Three of them should read normally closed and one should read open.
If you still need help, let us know.
Jul 04, 2009 | GE Microwave Ovens
No heat or turntable motion
This is usually caused by either a bad door switch or a loose door switch mount.
There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383 or here.
Jun 01, 2008 | Sharp R-403HW Microwave Oven
Door shut off malfunction
I have the same problem starting yesterday April 19. Have you gotten any answers.
Mar 12, 2008 | Panasonic NN-T993SF Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
22 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
