Question about Facebook Social Network
Why can't I get into my acc - Facebook Social Network
    New Friend:
Please open my pace book
Posted on Jul 16, 2013
Need a wiring diagram on suzuki raiderj 110. Please. Tnx.
Maybe you can use these codes taken from:
http://www.motorcyclephilippines.com/forums/showthread.php?120554-Motorcycle-Electrical-Wiring-Diagram-Thread
This is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
ORANGE - from Ignition +ACC
BLACK/swhite - Ground
WHITE/sblue - to Ignition Coil
BLUE/syellow - to ENGINE Stator side
ENGINE - Stator Single Phase
WHITE/sred - To RECTIFIER
YELLOW/swhite - To RECTIFIER
BLUE/syellow - from CDI sensor
ENGINE - Transmission Gearbox
GREEN/sblue - 1st Gear
YELLOW/sblue - 2nd Gear
WHITE/syellow - 3rd Gear
RED/swhite - 4th Gear
BLUE - Neutral
ENGINE - Rear Side
PINK - Odometer Speed Sensor
ORANGE/sred -
ELECTRIC Start RELAY
YELLOW/sgreen - form Starter Switch
BREAK - Foot pedal
ORANGE - From ignition + ACC
WHITE/sblack - to Break light
BREAK - Hand Lever
ORANGE - from IGNITION + ACC
WHITE/sblack - To BREAK Light
FUEL Sensor
Yellow/sblack - to Console
REAR - Lights
WHITE/sblack - form BREAK foot/hand
GRAY - From Night Switch
BLACK - from Left Turnsignal
LIMEGREEN - from Right TurnSignal
Signal Flasher Relay
ORANGE - from Ignition + ACC
LIGHTBLUE - Signal SW
RECTIFIER
WHITE/sred - From STATOR
YELLOW/swhite - From STATOR
RED/sorange - BATT+/HEAD LIGHT
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
GREEN - from HORN Switch
ORANGE - Ignition + ACC
NIGHT Switch
RED/sorange - From Rectifier
GRAY - To REAR LIGHT/HEADLIGHTThis is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
Dec 27, 2015 | 2006 Suzuki Stratosphere
How do i delete my fb acc. on my samsung S5 in which acc do go in and if fb acc how do i get in
You can download Fb application in application store. Then sign in Fb on your mobile
Aug 28, 2014 | Samsung S5620 Cell Phone
Problem with ACC on Audi A8 2004 3.0 TDI
who changed the ECU, you, or shop, was the ECU programed for your car or was plugged in and start.
most likely it need to be programed and apdated.
Apr 14, 2014 | 2004 Audi A8
Automatic door lock 1999 toyota prerunner
hi jerome
I have the procedure for Toyota auto lock, is worth to try it
AUTOMATIC LOCK SETTING
1) Step in the vehicle and make sure that all doors are closed completely
2) Insert the key into the ignition key cylinder.
3) Wait for more than 5 seconds.
4) After turning the key to the ACC position, turn the key from the ACC to the
ON position 5 times within 10 seconds (Last position : ON).
? Status Monitor LED will illuminate for 30 seconds.
Note : In case you implement 6 times or more by mistake,
action steps 6)-8) you made will be canceled.
Please retry from step 2).
5) While the LED is illuminated :
• Open and close the driver's door 2 times.
• Turn the key to the ACC position.
? LED will continue illuminating.
? Indicator lights will flash 2 times.
Ignition controlled door lock ON :
6) While the LED is illuminated:
• Open and close the driver's door 1 time.
• Turn the key ACC-ON-ACC 1 time (Last position : ACC).
? Indicator lights will flash 1 time.
? LED will extinguish.
Ignition controlled door lock OFF :
6) While the LED is illuminated :
Jan 28, 2014 | Toyota Camry Cars & Trucks
Delete my account
GO TO CONTROL PANEL - ADD REMOVE USER ACC.- SELECT THE ACC. YOU WISH TO DELETE. KEEP IN MIND IF YOUR ACC. IS A ADMINISTRATOR YOU WILL NOT BE ABLE TO DELETE IT. IN THAT CASE MAKE A NEW ADMIN. ACC. AND DELETE THE OLD UNWANTED ACCOUNT.
REGARDS.
PLZ. RATE THIS
Jul 03, 2011 | Computers & Internet
How do I get the check engine codes? 2003 Durango
There's two ways to retrieve the code. 1. Put the key in the ignition and turn the key to the "ACC" position, then back to "Off", then ACC, and Off, then ACC. (Off, ACC, Off, ACC, Off, ACC) You don't have to do it fast, just hold each position for about 1 second. On the final "ACC" position, the trouble code should flash in the digital odometer. (P#####) When you have the code, you can Google it and you'll see what the code means. 2. Use your scan tool (Or use Autozone's) and plug into the OBDII port under the dashboard and pull the code. They should have a book that tells you what the code means.
Oct 23, 2010 | 2003 Dodge Durango
I had an yahoo email acc but loss my computer and did not use my acc for a year got a new computer but could not retrivie my acc so i set upo a new acc with gmail it work fine until today now i cant get...
1.go here to this site and follow the instruction set:
copy/ paste into the browser address locator.
http://www.facebook.com/help/#!/help/?page=174
2. you need to change the acct settings " My Account " your profile to reflect the new email address ( this is in the face book acct
Aug 19, 2010 | Computers & Internet
After i installed my alpine cd Player in my 2002 ford mustang I pressed the power/source button on the receiver and the engine started. What could cause this to happen?
when you push that power button it draws power from a 12volt constant and sends it to the acc on the deck witch tells it to turn on and off! this acc may be shared with the ing acc. now the only way that it could start your engine is if this acc is grounding out to stater,ing,acc wires etc,remote car starter involed?
Jul 24, 2010 | Alpine CDE-9852 CD Player
Wiring hookup for 6 disc cd changer
battery would go to battery and acc. should go to the same wire that is marked acc. on the back of the radio. this is the accessories wire.
Jun 12, 2009 | Pioneer CDX-FM687 6-Disc CD Changer
Facebook Social Network Logo
14 people viewed this question
Top Facebook Computers & Internet Experts
David Payne
David Payne
Are you a Facebook Computer and Internet Expert? Answer questions, earn points and help others
