Question about Saws
Chicago 10 wet tile saw model tc250b
My tc250b made-in-china tile saw doesn't cut straight. blade has an angle. how do I adjust the blade?
rowdy45176
  • 2176 Answers
SOURCE: wet saw does not cut at right angle to carriage on dewalt 2400
Go to Dewaltservicenet.com and in the middle of the page at the bottom type in your tool number. On the next page click on the right side under manual. The manual is 42 pages long but it does have the information you need to readjust this saw. Let me know if you need any more help
Posted on Jan 25, 2009
  • 10865 Answers
SOURCE: crooked cuts
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Posted on Jan 28, 2009
  • 29 Answers
SOURCE: Tile Saw
i know blades on tile saws don't have to be super tight, i'm not familar with that kind of saw, i put a wrench on the nut and hold on to the blade with my hand and hit the wrench with a rubber mallet, and of course have the unit unplugged
Posted on Mar 26, 2009
  • 29 Answers
SOURCE: Tile Saw Troubleshooting
if your blade is newer or even well used,one way to make it cut better is find a used brick or a piece of a concrete block and cut through them,what really works best is a carborundum stone that setters use to hone cut edges of tile,you can get 1 at any tile store or home depot for 5 bucks. another trick is to lightly pull up on the table towards end of cut, if they keep breaking at end of cut, and you have the gauge set simply flip tile up side down and start your cut then back it off flip it over and cut through. all saw cuts leave minor chips on cut edge, we always stone cuts. cutting a brick cleans debris off blade. MAKE SURE WATER IS PRESENT WHEN CUTTING
Posted on Mar 31, 2009
  • 32 Answers
SOURCE: how do you square the rigid tile saw to cut
take a framing square and set it aginst the back stop.
then loosen the screws that hole the saws arm to the base.
now set the square aginst the blade and adjust untill it is even,in the front and the back.once you have acheved this tighted the screws on the arm to hold .
Posted on Nov 06, 2009
Easier way to cut glass wall tile
Easier than what? I use a diamond tile saw, and find that pretty easy.
Sep 11, 2014 | Saws
Saw is not cutting straight
Make sure the miter is lined up at 90 degrees to the blade. The fence has to be parallel to the blade and the blade tight. Cuts should be straight if the piece is held firmly and you move at the proper speed. Good luck!
Mar 05, 2011 | Dewalt D24000S Wet Saw With Stand
I have a 10" ridgid
With bigger tiles I have to cut more than half way, and then turn tile around and cut last bit from other direction.
You might be able to cut half way down tile, and then move tile forward on tray.
My wheels come to a stopper and don't run off the track, so my saw is different than yours.
Jan 24, 2011 | Ridgid 10"Wet Tile Saw with Laser and...
Cannot keep water on the blade of my 10" Rigid wet
if waters not getting to the blade you will see the powder of what ever your cutting coming off the back of machine,i like to put my pump in a bucket of water under the drain plug instead of puting the pump in the water tray,you can run bigger tubing up to the blade and reduce it down and it will give you better presure,good luck
Dec 31, 2010 | Ridgid 10"Wet Tile Saw with Laser and...
I purchased the new Ridgid tile saw named " The Beast". Initially it looked like a great saw buy after cutting a few ceramic tiles I began to notice that it cuts with a slight curve. I could not find any...
Its either the speed of the blade ( mine came with its speed at half rate), or its the crappy blade they give you with the saw. If a cut is bowing your blade is having a tough time with material. This often happens with tough porcelain tiles and not using a porcelain blade.
Oct 01, 2010 | Ridgid 10"Wet Tile Saw with Laser and...
Will not cut straight anymore, blade wobbles blade is not old
There are a couple reasons why the blade is wobbling. Either the diamonds are glazed over because the material you are cutting is way to hard or the blade is very thin and when metal gets hot it expands and when you make a longer rip cut it will tend to wobble. I sell blades for a living and i can almost gurantee this is the reason
Dec 15, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
My Husky tile saw starts to cut straight and ends up crooked, have tried to adjust tray and still ends up crooked??????
Make sure both sides of blade are wet. Make sure blade is not worn out. Do not feed the tile excessively fast.
Next, and very important is that the blade arbor is at true to the table. If the saw is slanted in the least, the saw will track off course. I am talking VERTICAL slant.
Verify that the arbor bearings are tight and there is no "end shake"
Sep 22, 2009 | Wet International Husky 7" Wet Tile Saw...
Tile saw not cutting straight
Sometimes a blade that is set deep enough will walk in this manner, especially if it is a thin kerf blade like the MK Hotdog blade.
Also, a blade which has worn unevenly will do this too.
Jul 11, 2009 | Mk Diamond MK - 101 Pro 24, 2hp Tile
Crooked cuts
Jan 04, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
