Question about Sharp LC-32D4U 32 in. HD-Ready LCD Television
Power up my sharp lc30hv2u does not turn on, but the the standby light stays on, I was wondering if the power supply should be replaced?
  • sasevenfive Nov 28, 2007
    my Sharp LC-30HV2U keep blinking up and red light stay on.I have to press too many time on remote button power until green light come up. It's Power supply on receiver box problem?
  • 53 Answers
Nothing wrong with the power supply more likely you need to replace the back light. One way to diagnose the problem might be trough the light down on front of the TV count the blinking intervals and/or the color of the same and check your user manual for this part then you will have a better idea of what it is.
Posted on Aug 28, 2007
Sharp LC-50LE442U does not turn on. RED standby LED is lit, when I try to turn it on, the LED turns green but screen stays black. LED then stays green, won't go back to red when turning off.
You cannot tell if capacitors are bad just by looking at them. they need to have a meter called an ESR meter to test them, I can tell you with almost certainty that it is a capacitor in the power supply that has failed. The whole board is Sharp 9JY0950CTN02000 Power Supply Board (09-50CTN020-00) LC-50LE440U LC-50LE442U
May 27, 2016 | Sharp AQUOS LC-50LE442U 50" LED TV...
When in standby the led standby light will flash for about 10 mins, normaly late at night
The problem is that there is a bad capacitor on the power supply board of the television.Therefore it is going to keep acting that way until the bad capacitor is replaced.
Run a check on the power supply board, you will definitely see the bad capacitor, have it replaced and the television will turn on after reassembling the television back together.
Thank you for using fixya
Sep 12, 2011 | Sharp Televison & Video
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position...
tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light
Aug 30, 2011 | Sharp 21" Multi System Stereo TV
Is the red light suppose to stay on when you turn off the tv with the remote?
Yes it is supposed to stay on. This is the standby light. The television still draws power as do many electronic devices when not turned on and when in standby. If you do not want the red light to stay on you will have to unplug the television.
May 09, 2011 | Samsung LN32A330 32 in. LCD TV
KV-36XBR400 won't turn on, "standby/stero" light
You are correct. You are right about the power supply and replacing with led hdtv. You will be happy with a Samsung led. Time to upgrade.
Mar 04, 2011 | Sony KV-36XBR400 36" TV
My sharp aquos 30 inch tv will not come on. what could be the problem
Hello; I have an similar LC30HV2U for sale in my TV repair shop for $350. This is a 2 piece unit. The AV box and the monitor. I am also a Sharp authorized servicer. In the monitor there are 2 inverter boards on the right side that have an 80 % chance of causing this problem. This set counts "lamp errors" due to one or more inverters not working on startup. Once the set accumulates 5 lamp errors, It will not allow the set to come on. The first thing Sharp tells us is to replace both inverter boards. About $90 each. If those don't fix it the cost will go much higher due to a bad power supply board or bad LCD Panel. Hope this helps, John
Jan 02, 2011 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Tv popped and turned off, now won't come back on. left it unplugged for about ten minutes, and the standby light came on but went off when the power button was pressed
Power supply board is dead.Replaced the power board will get the power back.Buy a refurbish power supply board at, for the power supply board.
Feb 10, 2010 | Sharp LC42SB45U 42 in. LCD TV
My sharp lc46sb54u 46 in.hdtv power light keeps blinking
Any indicator light on at all, if you see the light, then only the 5v standby power supply is working but not the main section of the power supply, it can also be the main control board hat is not sending signal to turn on the main power supply section.
Sep 01, 2009 | Sharp LC46SB54U 46 in. LCD TV
Power supply bad on Sharp Aquos LC - bad board - schematic to ID?
Buy the green light going on means Standby is ok. Next, would be to locate the plug coming from the main board to the power supply and find the post that says PO which means power on. With your meter on that post, press the power button as see if the reading goes High, if it does then the main board is able to turn on the power supply. Next, find the plug on the power supply that goes to the inverter( the long board on the side) remove it and see if you have 24 volts coming out of the power supply when you press the power. If you do, then the inverter board is bad, if you don't have 24 v, then the power supply is bad. There are NO diagrams available for these set other than a flow chart if you can find one. A regular svc tech does'nt need a manual for these anyway.
Let me know how you do Kathy ?
May 17, 2009 | Sharp Televison & Video
Have a 30" SHARP Aquos LC30HV2U that has a bad power supply. Nothing happens when I turn on the LCD - though it is getting power confirmed by green light going on but nothing on LCD. Visual inspection
You did try the CLEAR button on front of the box?
One possible idea is the cables going the box to the TV. ( might be bad )
If your sure about the problem, you can get your Service Manual here:
This with have all the schematic, diagrams, part number, and test points you need.
Sharp LC-32D4U 32 in. HD-Ready LCD Television Logo
152 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
