Question about Refrigerators
Frigidaire Refrigerator FRT21IL4W8 frig not cool/freezer ok
Replaced Icemaker & kit last week. Freezer & icemaker working fine but now the frig temp not as cool as b4 even after adjusting control knob to be cooler.
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
lenwest
  • 150 Answers
SOURCE: Refrigerator part not cooling, freezer
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 27, 2009
ginko
  • 19396 Answers
SOURCE: Icemaker not working, freezer not getting cold enough....
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
SOURCE: Frigidaire Refrigerator FRS26H5ASB5 side-by-side
Hi, yes, your thermostat could be faulty, yes there should vent( damper), check controls on freezer side, controls amount of cold air going to ref. side, yes could be stuck by ice, yes both adjustment are necessary, check manual, some thermostat are very sensitive, you should adjust gradually, wait for about 40 minutes, before adjusting again. yes there's vent flap (damper) yes that could be your problem, normally they get stuck with ice, remove covers to locate it., you 're smart, you will see, damper, good luck.
Posted on Aug 12, 2009
  • 2468 Answers
SOURCE: Refrigerator section does not cool. Light or LED
these refrigerators are notorious for a bad main/mother-board being bad,especially if recently you had light bulbs have burned out in the refrigerator compartment as this creates a surge on this board and burn the printed circuit trace on the board,it is located in the lower rear of the unit and is housed in a plastic case and if you open the case and look at the board and case there will be a burn spot on the plastic case also
Posted on Mar 13, 2010
Testimonial: "One of the two light bulbs is burned out. The burned out bulb is on the same side as the refrigerator control. I will look at he board. Thanks!"
Why is my freezer working but not my frig in frigidaire upright with seperate doors
Check the rear is clean and clear. The condenser should be warm, not hot. If it cools down towards the end of the rungs and the last bit is cold. suspect short of gas.
Further check any fans etc and remove any excess ice, and make sure the door seals ok.
Aug 06, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
Have frigidaire my freezer is working but bottom of refridge is not getting cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 21, 2010 | Frigidaire 18.3 cu. ft. Top Freezer...
Makes ice but is very slow to dispense and makes a load bumping noise
Turn off the water to the icemaker. Locate the plug from the icemaker to the freezer & disconnect it. There is usually 2 screws under the icemaker that mounts it to the freezer, remove them. Some may have a screw or 2 in the top also. these are only short sheetmetal screws. You should then be able to extract the icemaker, a short hose attatched to the icemaker will come out of the back of the freezer. When complete the freezer/frig will work fine. Thaw out the icemaker, drain the water out, inspect the rotating finger grate area for any objects. Shaking it upside down may help. Reinstall & test, if it doesn't work it is bad. You can take it to an appliance repair store to replace.
Nov 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer working: refrigerator not cooling
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Sep 23, 2009 | Frigidaire GLRT83TES Top Freezer...
Refrigerator part not cooling, freezer is fine Amana TXI18JW (top freezer model) I noticed in the last week or so that my refrigerator was slowly starting to warm up, so I started to turn the dial up on...
Len West
Feb 27, 2009 | Amana ARSE66MB Side by Side Refrigerator
Ice maker motherboard
call the manufacture, sounds like an issue with the circuit board
Feb 19, 2008 | Maytag MFD2560HES Bottom Freezer French...
Frigidaire Refigerator
TEMP FIX i found remove hinge cover top of left door and unplug the Icemaker and fridge will run again havent figured out the problem with icemaker yet though
Feb 18, 2008 | Refrigerators
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
