Dayton electrical 3N661 wiring diagram
I have a 10 hp tri volt motor. I need to connect it to a 3 phase 120,120,120 service 208v across any 2 lines. Please help
  • 118 Answers
SOURCE: Where do i connect load wires to 240 volt baseboard heater
240 load goes to 240 supply if on all the time
or 240 load goes to one leg of switch other leg goes to supply
Posted on Oct 27, 2009
  • 33 Answers
this is tricky to some you must connect heater to the load side of thermostat must will have a black set and a red set wires look at the directions to find the line side which you hook wires from panel to them I will tell you some switches are different so with out seeing the schmatics its hard to tell you email me a picof thomastat and i can tell you hope this helps
Posted on Oct 28, 2009
  • 89 Answers
Do you have the installation instructions, they will tell you exactly where to attach your high voltage.
Posted on Nov 01, 2009
SOURCE: is posible run a single phase electric motor from
It is indeed possible to use ONE Phase to run a motor, You simply use One Phase and Neutral. BUT ONLY if the 3 phase is Double, more or less, the required usage Voltage, EG: 440 3 phase, will be OK, for 220 single phase, . But 220 3 Phase,will not run a 240. single Phase. So in your case is suspect not, it really will do no harm to try though. it just wouldn't work, if not enough "juice", be careful.
http://en.wikipedia.org/wiki/Three-phase_electric_power
Posted on Feb 24, 2010
SOURCE: How do you wire a dayton electric unit heater?
tengo un motor dayton y nesesito darle un mantenimiento me podrian fasilitar un manual de ma
Posted on Jun 18, 2012
Could sure use a wiring diagram for a Dayton 5k961c motor.
Electric Motors: dayton motor, Electric motor repair Kansas ...
en.allexperts.com > Industry > Machine Tools > Electric Motors
Aug 24, 2010 - Electric motor repair Kansas City MEAR Service 816-650-4030: Tyler, it is ... i have a dayton motor with no wiring diagram. i need a wiring diagram for a dayton motor with a model # 5k961c and a reference # r67745ck733 ... 1992 Dodge Dynasty Blower Motor Wiring Diagram · 1998 Ford Escort Blower ...
wiring diagram (ideally color) for Dayton belt drive motor Model ...
www.electro-tech-online.com > ... > General Electronics Chat
Apr 29, 2012 - 9 posts - ‎3 authors
There is a sticker on motor indicating wiring, but seems only an. ... This is a motor for vented - big blade ceiling fan -- a belt driven Dayton Motor ...
DAYTON 1/4 HP Condenser Fan Motor,Permanent Split ...
https://www.grainger.com/.../DAYTON-1-4-HP-Condens...
W. W. Grainger
Rating: 3.8 - ‎6 reviews
Shop DAYTON 1/4 HP Condenser Fan Motor,Permanent Split Capacitor,1075 Nameplate RPM,208-230 ... Typical HVAC Condenser Fan Motor Wiring Diagram ...
DAYTON 1/3 HP Direct Drive Blower Motor, Permanent Split ...
https://www.grainger.com/.../DAYTON-1-3-HP-Direct-D...
W. W. Grainger
Jan 23, 2016 | Dayton Dryers
I purchased a generac 22 kw 3 phase 120/240 volt generator. I was surprised to find that it had a wild leg. Can i change the leads on the stator output to eliminate the high leg and get straight 120/208...
This unit is wired 120-240V 3 phase Delta. if you are using on it 120/208V 3 phase application it will need to be re-tapped. If you are using it in a home 120-240V single phase it will need re-tapping, Do NOT just use 2 legs, as this will cause rotor imbalance and wear out the rotor bearings, and odd ball currents to flow. If there are 12 leads coming off the stator it can be reconnected. If not you are stuck with it, except by using a transformer
Dec 15, 2013 | Generac Generator QT02224JNAX QuietSource...
Wiring a dimmer switch with 208vac, single pole
208 Volt 2-wire is generally achieved by pulling two hot wires off 3-phase 120/208 Wye or 208 Delta, or Highleg to center tap off high leg delta.
http://waterheatertimer.org/How-to-wire-3-phase-electric.html
http://waterheatertimer.org/images/3-phase-timer-diagram3-T104-208-240.jpg
Since each of these three phase systems also offers 120volt for lights, and a dimmer can be used for lights, then I wonder what you are using dimmer for?
208 volts.can be controlled by turning off one hot of the two hot wires.
Install dimmer on one of the hot wires, and see what happens.
Is the dimmer rated for 208 volts?
Add a comment and say what you discover.
Jan 03, 2013 | Generac HTSN400G 400Amp HTS 3ph 120/208V...
I got a dayton 2hp. electric motor model#2N982M it appears you can wire it for 110volts,220volts, or 440volts - need a wiring diagram mine partially worn off.
That motor is a three phase motor and will not run on 110 volts. It is also a high RPM motor with a lot of torque and MUST be mounted to a solid surface before it is powered up or it could rip your arm off as it flies across the room. If you have access to three phase power then you could power that motor but not with standard household electrical service.
Heres a link to some info for it
Jun 17, 2011 | Dayton Heating & Cooling
I need a wiring diagram for a dayton 120/230 v capacity start motor model 6k157 or equivalent
I have dayton motor 3/4 hp 120-240v it has 3 contacts 1-2& 4 it has 5 wires 2 white 2 red 1 blue. I want forward rotation! what do I do?
Jan 14, 2011 | Dayton Permanent Split Capacitor Motor Fan
Hello im tryin to wire a dayton model 2yu68 unit heater 208v .30 amp bbreaker with 10 awg 3 wire and simple thermostat and still wont fire up
Are you using this heater for a residential application? 208V is typically only seen in a commercial/residential setting. It would be unusual for a home to be wired in what they call 3 phase which is how a 208 voltage is obtained.
Hope this helps. I would strongly advise that you consult with an electrician as 3 phase voltage is not for the average DIY'r.
Oct 10, 2010 | Dayton D-F79 Electric Space Heater- the...
How to install a 208v outlet for a stove
if its a single phase panel you will only have 120/240 v.a.c. you can wire it for 240 volts and it will heat faster anyway the only way you could have 208 volts would be if you had 3 phase delta or open delta 3 phase or buy a special "dry-type" transformer for 240 volt to 208 volt step-down,otherwise it will be red-& black will be your 2 hot phases of 120 volts each/white-neutral/and green or green-yellow will be the case safety ground
Nov 14, 2009 | General Electric Profile PP945 30 in....
How do you wire a dayton electric unit heater? Model-3e030,watts-15000, phase-3, motor amps-22, motor volts-120, heater volts-480, listed air heater-492b, cycles-60 ac.You have a...
red, white, and black will be your high voltage. Green will probably be for ground and yellow and orange go to the thermostat. I can confirm on Monday when I have access to manuals.
Oct 04, 2009 | Dayton Electric Heater
How to connect the Dayton Capacitor Start Motor to 230 volts ?
In the **********, the screws will be market L1 & L2. There will also be a jumper that needs to be connected between the 2 terminals for 230V.
Aug 28, 2009 | Dayton Permanent Split Capacitor Motor Fan
I have 2-240V (4.2V) basebaord heaters, Need Wiring Diagram
you get 120V from any phase (black OR red) to neutral
you get 240V from phase to phase (between black and red) and in this scenario you don't need the white wire.
So for you, connect the black to 1 pole of the breaker and the red to the other pole, connect the green wire to the ground strip and you are done.
A white wire is NEVER connected to a circuit breaker anyway, it is a grounded wire, it would be like connecting a green wire to a black wire, bad idea.
the National electrical code specifies red and black wire color for 240VAC circuits.
As Ask Hank mentionned, nothing wrong with 10/3 wire.
Mar 22, 2009 | Fahrenheat Electric Hydronic Baseboard...
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
