Question about Husqvarna Garden
Does husqvarna mower model 960430034 have a dip stick for the transmission
Backs up slow
3 Suggested Answers
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 10865 Answers
SOURCE: Just bought a used Husqvarna ltg 2654 mower. Could
Hello aka.... begin by checking the transmission fluid level. Fill it to just slightly above full when the tractor is sitting on the level. This will maximize your power. IF this alone does not solve your problem I recommend changing the fuel filter and the air filter and also adding a fuel additive called seafoam which will clean the internal engine parts. Joe
Posted on May 02, 2011
My husqvarna riding mower moves very slow in forward what's wrong
Lisa. the brakes may be sticking. see if it pushes easy. if it does it may have a worn out drive belt.
Nov 13, 2016 | Husqvarna Garden
Tip
Ignition Won't start ?
We have a 48" cut Husqvarna riding tractor ....<br />1. Check oil. If its low , add oil to fill mark on dip stick.<br />2. Check ignition fuse. Our's took a 20 amp fuse. <br />It started right up. <br />We have a lot of pot-holes in our town. The fuse wire must have jiggled and touched against the frame. It blew the fuse.
on May 24, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Checking transmission fluid cub cadet 1500 siries
pull the dip stick out pour oil to level mark on the dip stick and your done
Aug 14, 2014 | Cub Cadet Garden
Mower runs slow
Replace the belt or adjust tensioner. If the belt looks cracked replace.
May 14, 2013 | Husqvarna Garden
I have a lgt 2654 husqzarna changed oil for first time and took 2hrs to drain and only about a quart came out it only has 7 hrs on it is that normal , maybe lowes only put a quart in it?
the temp of the oil while draining being cold will slow it down also have no vent will as well run the engine get it hot open the dip stick port then drain it
Apr 13, 2012 | Husqvarna Garden
Husqvarna riding mower modle yth20k46 that move very slow
The link rod from the petal to the transmission straightened out at the rear bend. Take it off and bend it slightly further to make it go forward faster. The 1/2" nut above where the rod connects to the transmission is adjustable to set it where it doesn't move when your foot is off the petal. Loosen it a bit and you can move the petal slightly forward or backward to adjust it. Depending on how much you bent the rod it won't take much adjustment. Re-tighten and try it out. It may take a few tries. Good luck!
Mar 17, 2012 | Husqvarna Garden
I have a model yth2348 mower. How do you adjust the speed of the mower. I have changed the drive belt but it still runs slow.
hydrostatic transmission there is only one throttle setting and that is WFO. if it is running slower than it used to, and the drive belt is snug, then you are looking at a failing transmission.
Sep 19, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Weed eater 961380017 where is oil drain plug located?
On the Weed Eater 961380017 it uses a Rato engine and the mower is made by Husqvarna, it is the same as their U.S. model 5521P. To drain the oil you have to first remove the dip stick and then tilt the mower over to drain the oil out into a pan.
Aug 04, 2011 | Garden
Were is the dipstick at
WHICH DIP STICK OIL DIP STICK FRONT OF ENGINE BELOW FRONT VALVE COVER.THE TRANSMISSION DONT HAVE A DIP STICK IT HAS A VENT FILLER CAP.THE GARAGE HAS TO PUT CAR ON A LIFT TO CHECK TRANSMISSION FLUID BY REMOVING A CHECK PLUG.IF TOO FLUID COMES OUT PLUG HOLE TOO MUCH FLUID IN TRANSMISSION IF NO FLUID COMES OUT NEED TO ADD SOME.IF A SMALL SLOW DRIP COME OUT TRANSMISSION FLUID LEVEL IS OKAY.SEE THE GARAGE HAS TO RAISE VECHICLE UP WHILE RUNNING IT HAS TO BE LEVEL THEY REMOVE THE CHECK PLUG TO SEE HOW MUCH FLUID IN TRANSMISSION.ITS DANGEROUS TO DO IT YOUR SELF.
Jun 08, 2010 | 2003 Chevrolet Impala
How do i refill the transmission oil in my 1997 Micra auto (1 ltr). Can't find the cap.
Hi: To Refill your Auto Transmission with Tranny Fluid, There is NO CAP, Look For a Dip Stick Similar to your Oil Dip Stick.You Refill your Transmission where the Transmission Dip Stick comes out of a Tube. You'll Need a Funnel that Fits inside the Transmission Dip Stick Tube. This Should Resolve your Question. Please Vote and That actually sends me How Well I have Helped You. OH Look Towards the middle to the Back of Your Engine to Locate Your Tranmission Dip Stick: From the WYOCWBOY
May 30, 2010 | 1996 Nissan Sentra
Garden Logo
23 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
