Question about Event Planning & Celebration
Kick buttowski theme psp - Event Planning & Celebration
How to download themes to psp?
This website will show you how:
http://boardsus.playstation.com/t5/PSP-Media/ptf-Psp-themes-EASY-TO-DOWNLOAD/td-p/31742821
Oct 23, 2010 | Sony PSP-3000 Black Console
Hot to get themes from pc to psp
If you got themes already, fantastic! If not what you need to do s first search online for themes you want. when you have all the themes you desire connect your PSP to you computer and go to the folder PSP in it you want to create a new folder and name it THEME like this with all caps, so then it will look something like this:
X drive: PSP : THEME
your THEME folder will be in your PSP folder, then you drag and drop all the themes you want
To access your themes go to theme settings in system on you PSP and ENJOY!
May 03, 2010 | Sony PlayStation Portable (PSP) Console
How to download theme psp???
try this site its where i get all of my psp stuff from here pspiso.com. hope this helps
Mar 27, 2010 | Sony PlayStation Portable (PSP) Console
THEMES OF PSP
Themes are kind of tricky. If your themes were created for 5.00 or just about any other firmware version then they won't work on 5.50. Same for just about all the other updates, themes are made specifically for it's particular firmware. If it was made for 5.50 then it should work but I know from downloading about 10 themes personally, only 2 worked.
May 30, 2009 | Sony PlayStation Portable (PSP) Console
How to install the theme in psp
go to a website that caters psp themes, you can google it if you want, then download the themes, save it on your mem stick, make sure that you copied it on the correct folder, you will see a theme folder. disconnect you psp, then go to settings on your psp then theme settings, there you will see your installed theme.
May 23, 2009 | Sony PlayStation Portable (PSP) Slim...
How do i download psp themes to psp slim
connect your psp to your computer using a USB cable and activate the usb connection on the psp system under settings menu. go to my computer on your desktop or laptop, find the psp drive and double click on it. click on the PSP folder, you will see a folder name called THEME. this is where you download and save psp themes to.
Use this site: http://download.qj.net/PSP-Themes-PSP-/catid/538 to download psp themes. please save the file to ptf file to your themes folder on your psp as I have described above. disconnect the usb cable and check on the themes.
Feb 08, 2009 | Sony PlayStation Portable (PSP) Console
I am not able to download themes in my psp
You don't have to create a themes folder on the on the memory stick duo, it is already created on the memory stick duo, all you have to do is to just connect your psp to your computer and activate the USB connection under settings on your psp, if you have firmware update 5.00 or higher, there is a feature called USB auto connect under system setiings which automatically switches to USB mode when you plug in a USB cable to your psp and your computer.
STEPS TO DOWNLOAD THEMES TO YOUR PSP.
1. connect your PSP to your computer, go to MY COMPUTER on your desktop and click on the drive that represents your PSP.
2. double click your PSP drive and navigate to PSP folder and select THEME under the folder.
3. Now copy and paste this link to your browser to download many themes for your PSP: http://dl.qj.net/index.php?&catid=538&name=PSP-Themes-PSP-&p10=5
4. select the file you want, click on download, depending on your browser, click SAVE when you are prompted to RUN or SAVE the downloaded file. Please select the PSP drive under MY COMPUTER and select PSP, navigate to the THEME folder and save the file to this folder.
Now disconnect the PSP from your computer and select THEME SETTINGS on your PSP, select THEME, navigate to the available themes and you will see a preview of the theme, select apply to use the new theme.
PLEASE RATE ME.
Dec 14, 2008 | Sony PlayStation Portable (PSP) Console
How to download psp themes??
There are actually a lot of themes running around the internet now...just type in your search bar PSP themes. How, for the location of the themes, just put it in your themes folder on the memory card of your PSP>>ms0:\PSP\THEME (ms0: meaning the root directory of your memory card)
Aug 03, 2008 | Sony PlayStation Portable (PSP) Console
Themes
Hi, first of all you DO NOT need custom firmware to install themes onto your psp, you need a firmware 3.71 or later to do it. First of all go to a theme site E.G http://www.psp-themes.net/ select a theme you want and download it to your computer. then connect your psp to your pc. open the psp files, go PSP, then there should be a folder called THEME. copy the theme you downloaded and viola. this is the folders in psp memory stick: bf57d12.jpg
the theme file must be .ptf Hope this helps.
May 06, 2008 | Sony PlayStation Portable (PSP) Console
Where can i get some free themes
you can try some in here http://www.psp-themes.net/psp-official-themes/
Apr 15, 2008 | Sony PlayStation Portable (PSP) Console
Event Planning & Celebration Logo
286 people viewed this question
Top Event Planning & Celebration Experts
DAVE PARTA
Level 1 Expert
samiya_jahan
Level 1 Expert
Are you an Event Planning and Celebration Expert? Answer questions, earn points and help others
