Question about Sewing Machines
JUKI DU141 Stitch to small
I am a swimwear designer and just got a juki ddl 8300n did I pick a good machine? How can I adjust the machine for a more stretchy stitch?! What number should my stitch dial be on to get a stretch?
Perhaps a manual would be helpful:
File JUKI DDL 8300N Instruction Manual pdf
You should probably contact the manufacturer with questions. Hopefully, you did some thorough research before purchasing this machine. From the info I found, it appears to be a straight stitch only machine. I don't know anything about this machine, but I would be hesitant to purchase a straight stitch machine for sewing swimwear. Usually, swimwear needs a stretch stitch or zig-zag capability. Just my thoughts...
Amazon com Juki DDL 8700 Industrial Straight Stitch Sewing Machine Arts...
Juki DDL 8300N Industrial Single Needle Lockstitch Sewing Machine with...
JUKI DDL 8300N Straight Stitch Industrial Sewing Machine With Table Lamp...
Nov 21, 2016 | Juki Sewing Machines
Juki 8700- stitch length won't go below 2.5. Knob gets stuck. How to make stitch length lower?
SLIGHTLY unscrew the large screw in the center of the stitch length knob, turn the knob to the right several clicks and retighten the screw. DON'T take it completely out, or you will make more work for your self.
Jul 07, 2016 | Juki Sewing Machines
How do I adjust small narrow stitch for light fabric for juki 6700
hello
concern how to adjust small narrow stitch there's two step to fine adjustment please see 2 photo
1-adjust by differential at left side when open left door.
2-adjust by stitch length.
both is important to made fine adjustment.
best regards
ASHRAF ABOZID
aabozid@hotmail.com
CAIRO - EGYPT
Mar 16, 2015 | Juki Sewing Machines
Does This model have a reverse stitch option?
hello there
depended on model , the all JUKI LOCKSTITCH MODEL have a reverse stitch but normal model was by hand and with control box was both automatic and manual.
DDL-8700 was manual reverse stitch.
best regards
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
Aug 12, 2014 | Juki DDL-8700
How do I adjust the stitch length on my Juki DDL 552?
hello, i recently purchased an old juki ddl-552, and it don't have a stitch locater, and a reverse button! how do i adjust the stitch length ??? thanks
May 31, 2013 | Ludwig LG8B2 Industrial Sewing Machine
My bobbin stitch is too tight on my Juki DDL 8500-7, how can I fix this?
Hi LJ,
Look on the bobbin case, and see if there is a small screw. Usually that is the tension of the bobbin. You can adjust that until there is only slight tension on the bobbin thread.
Hope this helps
Joe
Sep 17, 2011 | Juki DDL-8300
Hi, I have a Juki ddl 552 that does not have te stich setting nob. I am wondring how can I change my stich seting? please help.
Here is a threading diagram for this industrial machine
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_552_553_555_227_Threading_Diagram.htm
You can also buy a manual here
http://www.sewusa.com/Sewing_Machine_Manuals/Juki_Manuals/Juki_Industrial_Sewing_Machine_Manuals/227-552-553-555_Instruction_Manual.htm for this model.
I would have thought there would be some sort of screw or adjustment to control stitch length but I can't find an image for your model.
However this image might help, http://www.johnharbsew.com/images/threading/JUKI-DNU-241-TD.jpg, my Singer 20U, has a dial like this with numbers on that you adjust for length, is there something similar on the Juki?
Apr 19, 2011 | Juki MO-644D Mechanical Sewing Machine
I want to have my Juki MO-2516n do a mock safety stitch/4 thread
I have a Juki MO 2516N. It does not have the capability to serge 4 threads. The only options are 2, 3, and 5.
Apr 28, 2009 | Juki Sewing Machines
Sewing Machines Logo
12 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
