Question about Panasonic SV-MP020 MP3 Player
My panasonic SV-MP020 mp3 player does not turn on. and when i plug it into the USB, it's stuck on hello. help me pleaz!
  • 4 more comments
  • Shyra Feb 20, 2008
    When I turn my mp3 player on its says hello then wait. And It doesnt pop up on the CPU
  • Anonymous Mar 01, 2008
    same problem here, I think it has to do with passing the 2 g limit
  • Anonymous Mar 28, 2008
    When I turn it on and its set to hold, it stays on hello and never gets to hold so i can't reset it. :(
  • im2chingon Mar 28, 2008
    i have the same problem, but i cant reset it because even if i put it on hold, it is stuck on hello and it never gets to say hold. I CANT EVEN RESET IT. WAT DO I DO? HELP
  • kidsinthehal Jul 29, 2008
    it wont turn on but when i put the usb cord in it turns on
  • Anonymous Jan 03, 2009
    my device just dont turn on.
    i have changed the battery and nothing.
    i dont know what can i do
Try reseting the unit.
1) Slide the hold switch to on
2) Turn power on.
3) While unit screen says hold, push: (mode)(-)(+)(-)(+)(mode)(+)(mode)
This should reset it.
Source: http://www.fixya.com/support/t129568-frozen_displays_wait
Posted on Mar 28, 2008
SOURCE:
I can't get my music to play.
Don't worry about it, simply go plug in your mp3 player to the computer and sign in to Rhapsody. Go to your play list and the songs should be there. Unplug your MP3 player and it should work. You have to do this because the warrant or license on your songs is up and you have to plug in your mp3 player to renew that license to keep listening to it. Hope this helps! It worked for me!
Dec 01, 2008 | Panasonic SV-MP020 MP3 Player
Panasonic SV-MP020 Wait Problem
Make sure the usb jack is all the way in the player. Mine had a couple of mm of metal showing and felt like it was in, the display lit up, said 'wait' and then 'goodbye' :-(. Only later did I realise the jack still could be pushed fully in a bit further, and then *bingo*, a working mp3 player
Jun 18, 2008 | Panasonic SV-MP020 MP3 Player
Someone good with panasonic sv-mp020 please help me!!!what does OVER LIMIT mean?
Try resetting the mp3 player. You can do this by sliding the hold button over and then turning it on. While on it should say hold. Then you push mode (-)(+)(-)(+)Mode(+)Mode(+)
Granted, that will deleted all the songs you have on there so make sure you have them backed up somewhere you can place them back on there.
I hope this helps.
Jun 10, 2008 | Panasonic SV-MP020 MP3 Player
Connection
should have at least windows 2000 sp4 or xp sp1 as operating system. plug into usb port on computer while computer is turned on. computer should recognize and install it as mass storage usb device and assign it a drive letter. sometimes xp will recognize it as a panasonic mtp device. this doesn't matter, you can still drag and drop files on it through windows explorer file manager.
Nov 15, 2007 | Panasonic SV-MP020 MP3 Player
Won't Upload Songs
player has problems with windows media player 11. works with wmp 10. player also has problems with vista. firmware was designed for xp. no firmware updates available. you can try dragging and dropping through windows explorer, treating it as a usb mass storage device. it will play folders and songs this way. to get vista to recognize it, format the player through the player's menu ( set-system-format ) not through the computer. take out the battery for 15 minutes. reboot your computer. put battery back in. plug into usb port. hopefully vista recognizes it as usb device
Nov 02, 2007 | Panasonic SV-MP020 MP3 Player
Computer won´t recognize my player
format the player from the player ( set-system menu) not from the computer. pull the battery from the player and leave it out for 15 minutes.
reboot your computer. put the battery back in the player.
plug it into the usb port on the computer. worked for me
Oct 19, 2007 | Panasonic SV-MP020 MP3 Player
Over the Limit
maximum number of files is 999 regardles of how many songs you have. maximum number of folders is 99. maximum number of sub folders is 5 per root folder. delete any excess or format the player from the player menu ( mode-set-delete or mode-set-system-format ) not through the computer. you will lose all your songs if you format the player.
Jun 01, 2007 | Panasonic SV-MP020 MP3 Player
Protected
Sounds like you have bought protected music that will only play on your computer. There are a couple of companies that do this with the music that you buy from them. goto the music file that you are trying to upload to your MP3 player, right click on it, and choose "properties". at the top, there are 3 tabs, you'll only want to pay attention to "summary" look down in the "origin" category...is it protected? If it is, then this is why your MP3 player isn't playing it. It will only play on your PC.
Apr 04, 2007 | Panasonic SV-MP020 MP3 Player
Firmware issue
go to www.panasonic.com. look for the tab near the top that says downloads or support. enter your model number in the search box. download the firmware. follow the instructions that come with it.
Apr 10, 2007 | Panasonic SV-MP020 MP3 Player
Panasonic SV-MP020 MP3 Player Logo
464 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
