Question about Hayward 100,000 Btu Heater For Ag Pool And Spa H100id1
My Hayward heater turns on, then I can hear the ignition start and smell the gas, but it never lights. The air coming out of the side vent stays cold and I can occasionally smell the natural gas. Why is it not lighting?
    Top Expert:
  • Hayward Master
  • 5,056 Answers
Replace ignitor
Posted on Mar 19, 2016
SOURCE: Hayward Heatmaster will not light
Also if the filter is heavy with dirt, try recycling the filtering element, (sand od Diatomea sand) add new for a fresh start, this use to solve my problem.
Posted on Apr 25, 2009
  • 8 Answers
SOURCE: I just installed a new Hayward H400FDN and it will not stay lit.
I had the same issue...you don't have enough gas pressure.
Posted on May 12, 2009
  • 12 Answers
SOURCE: hayward h100ID ignitor not starting
There are many different things it could be with the fan comming on that means the heater is trying to fire. Make sure gas supply is on first of all. Depending on the gas line run you may have to try several times of turning on and off the heater to reprome the line. If no luck with that the next step is the igniter follow the small tube comming off the gas valve and folliw it to the burner tray try poking a small peice of wire through it from a wire brush it probally is plugged. Heater should fire after that.
Posted on Jun 26, 2009
  • 3 Answers
SOURCE: hayward natural gas h1001d wont ignite
has anyone found the solution? I think I have
Posted on Aug 08, 2009
  • 990 Answers
SOURCE: Heater won't stay lit
On your main gas manifold you have orfaces that screw into it at each burner. Remove these and see if their are small spider webs in them. They will look like little lint balls. They can keep your main burner from getting gas and in turn keep the heater from sensing flame. The pilot lights and the heater starts but no flame at the main will shut it rite down. See if this helps.
Posted on Dec 18, 2009
Why won't my Hayward H series heater ignite
Not much info to go by here Patty.
A gas fired heater needs spark and fuel to ignite. We need to start by to determining which is missing.
The H series has seen a few progressions. Does yours have no lights, 3 lights, or a lcd display? Propane or natural gas? Standing pilot or spark ignition?
Do any lights or display come on? Do you hear any clicking?
Apr 22, 2017 | Hayward Pool & Spa
My hayward swimpro abg100 powers on but nothing happens. I can hear a buzz coming from it but it does not ignite or anything. What can I do?
Warranty status? Probably gas control valve and its connections to the "buzz" ignitor system. Gas is not a DIY thing!
Jun 07, 2015 | Hayward Pool & Spa
Heater wont light,seems like all the safety switches have been met,has spark but dosen't seem to be getting propane
About when the sparking starts you should hear a louder snap that should open the gas valve. If you hear this and if there is gas pressure the spark gap is in the correct location it will light (you should also smell gas). On the other hand if any of these things aren't right it won't light. There is a plug on the incoming side of the valve that can be loosened to tell if there is gas available. If you leak enough gas to purge the gas line then that will eliminate a possible air problem. Make sure there is no source of ignition anywhere near during the purging process. Once the plug is closed tightly and you have waited 5 minutes you can try again. If you can't hear the valve come on then you can use a volt/ohm meter to measure the voltage going to the coil of the gas valve. When the ignitor is sparking there should be 115 VAC between these two wires. If you have further questions I should be able to answer them.
Aug 31, 2011 | Hayward 100k Btu Propane Gas Pool Heater...
We had to switch propane tanks and run more copper tubing, our old tank ran empty. We are trying to relight heaters but they won't light. Is there something we need to do to the heater so they will...
yes - your husband is right, there is a auto cut off on the regulator itself. there is a chance that the cut off has failed. you can check this by simply undoing the gas line that leaves the regulator and cracking open the valve and see ( hear/smell ) if gas is coming out,, if gas is coming out then the cut off is working and the problem is down the line somewhere ( like another valve right at the heater ) ---... if you hear no gas coming out then the cut off is bad and you will need to replace the regulator with a new one.
also check for the smell and sound of gas at the heater while you are trying to light it -- ( NOTE: don't hold the gas button down to long if you do hear/smell gas and it is not lighting , because as soon as it does start it will flash in a BIG fire ball,,, between testings -- always let it air out some and then try again ) --- if the igniter is not lighting the fuel then use a lighter or a propane torch to get it going,, I have seen the thermo coupler go bad on the units and that will only allow the flow of gas during ' pilot ' light mode but will go out right away when you move the switch to ' ON '. ( just food for thought ).
stay warm out there ---
c...
Jan 21, 2011 | Blue Flame Charmglow 30K BTU NG Vent Free ...
Green light comes on , can smell gas and hear buzzing from igniter but shuts down after 3 seconds and green light goes out
Make sure you have no soot build up on your ignitor. It will conduct elect so you can hear a buzz instead of a clear spark. Without a clean spark it wont fire and for safty it shuts down to keep gas from building up in the cabnit.
Sep 29, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
HEATER WAS WORKING FINE TILL I HAD PROPANE TANK TOPPED OFF
The Pressure Regulator may be stuck, Try closing the propane valve releasing the pressure,, gently tap the regulator( on the propane inlet side) and Very Very slowly open the propane tank valve, and attempt to light
Jul 30, 2009 | Hayward H Series
Hayward 100,000 Btu Heater For Ag Pool And Spa H100id1 Logo
118 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
