Question about Pool & Spa
Proline pool test kit
I have dual test kit KK 029BL I don't know how many drops to use for testing no instructions were included
3 Suggested Answers
briones93
  • 119 Answers
SOURCE: I just put up an
I sometimes have the same issue with mine.. One thing missing that helps protect the chlorine from burning off in the heavy sun is (Cyanuric Acid)or (CYA) You should be around 30-50ppm.. To bring this level up to 30-50, they sell a conditioner that raises this level.. Don't add too much if your already close to the 30-50ppm.. Other than that, you can continue to run the system as you already do.. Seems like it's maintaining clean and clear... Hope this helps???
Posted on Sep 01, 2011
badfish6686
  • 563 Answers
SOURCE: 24' X 52" intex pool, I am having trouble with my cholinator not producing chlorine in the water. there are no signals or lights flashing. but when I test for the free chlorine on the strips is do
If you can remove your generator try and bench test it. Fill with pool water and do a chlorine test. Run the generator for a few minutes, unit should produce bubbles when the cells are turned on. Run another chlorine test and make sure it is higher than original test. You should also test your combined chlorines to make sure you don't have excess chloramines in the water. Also check for any buildup on the generator plates which should be acid washed, and verify salt concentration.
Posted on Apr 10, 2013
Pool stabilizer
Their are no test kits available for residential home owners. Wherev you can take your water sample to will be able to test for cyanaric acid(stabilizer). They will give you the value to add to the water. Follow the instructions on the stabilizer container to add the amount based on the water volume you have for your pool. Most recommend adding it into a stocking and hanking it from the ladder or inside the skimmer to allow for slow dissolving
Jun 28, 2013 | Arch Chemical HTH Pool 4 LB Stabilizer &...
C9 champion digital alarm
Since you don\'t know how to turn it off, the alarm will give you simple instructions. Just stop pressing the buttons. Is there a symbol or an alarm or clock on any of the buttons?
May 10, 2013 | Watches
My pro form zt3 treadmill is making a noise whenever it's running...I've looked under the hood, but I don't know what's causing that noise.
Dear Sir:Please Lube THE machine in according with the instruction manual maintenance, May be you have a worn Decknad replace it.2) Test the rollers bearing and lube front and rear 3) Test the main motor for bearing Lube 4) Drive belt test and replace if necessary.
sincerely. God bless you
May 03, 2012 | Exercise & Fitness
2005 chevy silverado 1500 the radio, windshield wipers, indicator lights and heater controls don't work all fuses are good and have already changed ignition switch all fuses give a dime light on
Do you know what a automotive electrrical wiring diagram is ? How to use a DMM- digital multi-meter ? Pick one system an diagnose an you will probably fix all the syatems . Voltage drop testing . Voltage or ground side problem .
Mastering Voltage Drop Testing with Pete Meier and Jerry Truglia
Free wiring diagrams http://www.bbbind.com/free-tsb Enter vehicle info. year , make , model an engine size. View wiring diagrams an test the circuits.
Mar 06, 2018 | Cars & Trucks
How Do I fix the convergence on my 2001 Hitachi Projection Tv
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos aroundimages.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 05, 2012 | Hitachi 53UWX10B 53" Rear Projection...
Have a NG unit need to convert to LP gas. wath can i do.????
Unfortunately, there is absolutely nothing you can safely do to convert it from Natural Gas to LPG.
Each unit is manufacutered and tested for the specific gas type. Attempting to change it, puts all the liability on you, if something should go wrong. There are some on this site that will tell you all you have to do, is change the pilot orifice. That's fine for a Vented heating appliance, but not a Vent-free Heater like yours. In your case, you'd need a new control valve assembly, pilot assembly, burner, etc. That alone is about the cost of a new LPG Vent-free Heater. Besides, DESA Interantional has been out of business for 3 or 4 years now. So, parts would be an issue.
Sell the heater to someone who has Natural Gas and use the proceeds toward a new LPG Vent-free Heater. Always remember and don't every forget, it's always safety first when it comes to gas appliances.
Hope this helped you and thanks for choosing FixYa.
Aug 18, 2011 | Desa International GWN30T GLOWARM® Gas...
Picture has gotten darker over recent months regarless of signal source and continues to get darker. Brightness is set to maximum.
  • Screen looks 3D
Aug 02, 2011 | Hitachi 53SDX01B 53" Rear Projection...
How much chlorine does this pool need to consume and how often?
for pools that size just get the dissolving tabs sold at most stores, as long as the water stays clear and free from green moss your fine, over adding is worse than adding not enough,, with less you can always increase it, if you don't drain the pool much and its sitting in direct sunlight most the time, you will need to add it more often, you can buy cheap test kits for around 10 dollars that will help a lot in determining what you need
Jul 20, 2011 | Intex Easy Set Swimming Pool 10 x 30 Liner...
SMALL HOLE BOTTOM OF 15 x 4 metal frame pool. believe a small pebble caused it. water leaking out is there a way to save the poolwithout draining and taking it apart?
Try this....
You will need;
Pool liner patch kit
Goggles
Body weight to hold you down while doing repair under water.
Most liner repair kits have instructions on wet applications. Cut a piece of the liner kit fabric to cover the entire hole plus at least 1/2" around. You will need to dive in with a mask/goggles to see the hole. Put a thin layer of glue on the patch and spread evenly.. Fold in half on the glue side and go down to the bottom of the pool. Note...The weights will help you stay at the bottom for this part of the repair.. QUICKLY!!! while holding the patch next to the hole. open the patch and place on the hole and push firmly for a few seconds. Come up and place your foot on the patch and hold for 3 minutes or so. Should work...It took me several times to master this technique when I had a hole at the bottom of my pool... Caution!!! You don't need a lot of weight to stay at the bottom. Test from light to heavy until you think you have enough to do the repair..
Good luck and hope this will help you!! If this works for you, please rate!
Jul 19, 2011 | Intex Easy Set Pool 15x36
Pool & Spa Logo
83 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
