Question about Garden
Featherlite fx26 weedeater
Need a Carborador kit, or a carborator. For FX26weed eater. Information on it is. 2004 California/USA EPA PH2 4PWES. 0254TK :25CC : TWC Serial # 04068N503070 - 1 (14:08) MOD: FX26 711812 Durability Period 50 Hours.
slohry
  • 87 Answers
SOURCE: fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Posted on Apr 10, 2009
  • 603 Answers
Go to sears.com then parts store then type in model no. You should find a parts breakdown hopefully that will help.
Posted on Apr 13, 2009
#1 Taper
  • 1040 Answers
SOURCE: After rebuild only runs on half choke.Adjusting screw doesn't help
The rebuild you did is correct, but did you clean the small ports in the carb.? I use a Den Tek Brush (used for cleaning teeth). They work great for this job. You may also want to check the small screen in the carb. The smallest of particles can cause this problem.
Jim
Posted on May 26, 2009
jblee1975
  • 15 Answers
SOURCE: new fuel lines, wont stay run, swapt in/out line, wont stay run
Sometimes simply removing the carb and placing it in a carb dip will clean it without tearing it apart, also check or replace the spark plug. Make sure you have compression, good spark, and that fuel is getting to the carb. If that doesnt work, email me and I'll find you a diagram. Jblee1975@yahoo.com
Posted on Jul 12, 2009
  • 279 Answers
SOURCE: Pull string for Weed Eater Featherlite Plus came out
If you have the starter spool out (the one the rope goes in)...Here is what to do. Take the starter spool and change the rope out putting it back exactly as it was. Leave the rope hanging. Hold the spool and set it down on the rewind spring. Turn the spool on the rewind spring until you feel it is tight enough. While turning, hold the rope in the little slot in the spool so it can go around without hanging up. Once it is tight, get the rope in line with the spool opening and SLOWLY let the rope rewind. Put on the handle and put the unit back together.Good luck...Lee
Posted on Sep 06, 2009
How can I start featherlite weedeater with poulan carburetor sst 25?
Your Poulan should have a green button on the side of it. Push and hold it. While most models have a green button, your may not. In that case, obtain the model number off the weedeater, go to Poulan.com/customer service and download the manual for your machine
Sep 01, 2014 | Poulan Recertified - Weed Eater...
I need a parts list for a featherlite weed eater with ser#00031n500592-4. the other #'s on it are ypwes0183lt:em, and 2000us epa ph1, also it's a18cc. hope you can help. thanks
Find your model on this page. I cannot from the problem you stated. I hope you can. Click on your model, (or one similar to it) for complete parts breakdown lists with diagrams and prices too.
http://www.ereplacementparts.com/weed-eater-trimmer-parts-c-17589_17626.html
Sep 05, 2011 | Garden
I have a weed eater featherlite gas trimmer serial #98058N701741-3 how much oil do you mix with the gas? Oil and gas goes in to one plastic bottle.
Hi salston139
Use a 50 to One mixture for your weedeater...(1 pint of 2 cycle oil to 6 gallons of gasoline)
Free Answer...Please rate me
May 30, 2011 | Garden
I am needing a repair kit for gas tank on the weedeater featherlite 1500 where do I get repair parts at?
I have a Weedeater Featherlite SST and need to replace the fuel lines but do not know where they go is there a diagram that will show me this?
Nov 11, 2009 | Poulan Featherlite Gas Blower, with Low...
I have 2 weed eater brand weedeaters 18cc Featherlite and when i use both of them after a while they quit running ! I am using the correct fuel/oil mixture and i have changed the plugs and checked the air...
Possible coil break down. These cheap weed eaters only have a life expectancy of about 50 hrs Plus or Minus. You can buy new for less that it cost to repair them.Sorry that's the facts.
Oct 21, 2009 | Poulan Garden
I am having the same problem with acceleration speed on my blower
If the units is like mine, the adv. shafts, hi & low are knurled around the sides. you must find something to slip over them, (almost Impossible).I have a thin hawksaw blade and i sawed a slot in the end of each shaft.Check your head bolts. Yours, Knowitnothing
Jul 04, 2009 | Poulan Featherlite Gas Blower, with Low...
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
